		Kellym
				 Posted: Wed May 29, 2024 1:55 pm    Post subject: ANL fuse 60 amp. |
				My RV-10 has a 60 amp ANL fuse installed right below the shunt for the
 ammeterr, The fuse has blown, and I cannot find where I got the fuse 10
 years ago. Aircraft Spruce appear to be no help. I know they used to be
 common on experimental airplanes.
 I have a 60 amp Plane power alternator.
KCHD |
		Tim Olson
				 Posted: Wed May 29, 2024 6:03 pm    Post subject: ANL fuse 60 amp. |
				Those things aren’t really aircraft parts. They’re more for car speakers and things like that. Not that they don’t work fine. I have them in my airplanes too. But you can buy them on Amazon, or eBay. I haven’t even ever looked at them in local stores before, but you might have luck if you have a high and car stereo store around you.
  	  | Quote: | 	 		   On May 29, 2024, at 5:01 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
  My RV-10 has a 60 amp ANL fuse installed right below the shunt for the ammeterr, The fuse has blown, and I cannot find where I got the fuse 10 years ago. Aircraft Spruce appear to be no help. I know they used to be common on experimental airplanes.
		Kellym
				 Posted: Wed May 29, 2024 6:36 pm    Post subject: ANL fuse 60 amp. |
				That is what I eventually found. Looks like Home Depot can get within a
 day or two.
 On 5/29/2024 7:02 PM, Tim Olson wrote:
KCHD |
		user9253
  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Wed May 29, 2024 7:02 pm    Post subject: Re: ANL fuse 60 amp. |
				Make sure the connections are tight.  A loose connection gets hot and could
 cause a fuse to blow.  Do you have a lithium battery?
  _________________ Joe Gores |
		Kellym
				 Posted: Wed May 29, 2024 7:14 pm    Post subject: ANL fuse 60 amp. |
				I'll make sure the connections are tight. I just has an Odyssey AGM battery
 Kelly
KCHD |
		Dave Saylor
				 Posted: Wed May 29, 2024 7:32 pm    Post subject: ANL fuse 60 amp. |
				B&C and SteinAir have them.
 On Wed, May 29, 2024 at 7:06 PM Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
  	  | Quote: | 	 		  --> AeroElectric-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
  > On May 29, 2024, at 5:01 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
  > --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
   FORUMS -
  WIKI -
  b Site -
            -Matt Dralle, List Admin.
  ="noreferrer" target="_blank">https://matronics.com/contribution
  _________________ --Dave
KWVI |
		jimkale(at)roadrunner.com Guest
				 Posted: Thu May 30, 2024 4:56 am    Post subject: ANL fuse 60 amp. |
				Large trucks use those fuses try a large truck shopSent from my iPhone
  	  | Quote: | 	 		  On May 29, 2024, at 22:41, Dave Saylor <saylor.dave(at)gmail.com> wrote:
   FORUMS -
  WIKI -
  b Site -
		N1921R
				 Posted: Thu May 30, 2024 6:46 am    Post subject: Re: ANL fuse 60 amp. |
				If you have Amazon Prime
 Search "Blue Sea Systems 5123 ANL Fuse, 60A" within Amazon and select "All Prime"
 $21.04
  _________________ John Bright, RV-6A N1921R, working on FWF.
Single battery, alternator on main bus, Monkworkz generator on engine/essential bus.
My links here |
		user9253
				 Posted: Thu May 30, 2024 9:29 am    Post subject: Re: ANL fuse 60 amp. |
				Read this thread:
 http://forums.matronics.com/viewtopic.php?t=16778818
 Especially the post by Charlie and his picture of fusible links.
				 Posted: Fri May 31, 2024 2:19 am    Post subject: ANL fuse 60 amp. |
				At 10:31 PM 5/29/2024, you wrote:
   	  | Quote: | 	 		  B&C and SteinAir have them.
    Those things aren't really aircraft parts. They're more for
   car speakers and things like that. Not that they don't work
   fine. I have them in my airplanes too. |
       Not sure there is ANY catalog part, fuses and
       limiters included, that you might call an
       'aircraft' part. Catalog components become
       suited to task for aviation 'cause
       they appear on the drawings for a certified
       airplane, military vehicle, spacecraft, etc.
       The ANL/ANN series devices have been used aboard
       aircraft for about 100 years . . . lots of them
       scattered about B17's, KingAirs, LearJets and the
       like. I introduced them to OBAM aviation a few
       decades ago after an abortive decision to try
       the JNN series fuses as bolt-on, in-line fuses
       for b-lead protection.
   http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/JNN_Specs.pdf
       Bad idea, these critters didn't have the mechanical\
       robustness needed for such service. Plan-B was
       the ANL series devices and companion fuse-holders . . .
       certainly ROBUST but rather huge for little
       airplanes.
   http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
    http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/Limiter_FuseBlocks.pdf
       Not too many years after that, the major players
       in fusible protection (Bussman, Littlefuse, etc)
       Brought out some hardened and more attractive
       alternatives to the sheet-metal, limiters common
       to some European cars. Those are illustrated on
       the website as:
   http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Littlefuse/498.pdf
   http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Littlefuse/298.pdf
       A visit to about any big automotive parts store
       will provide sources for devices cited above
       or very similar.
       Holders for the modern devices are simple insulating
       blocks drilled for fuse/wiring and attachment to the
       airframe. I've made many of these things with a table
       or band-saw and drill press.  Phenolic, Delren, Lexan,
       even kitchen cutting boards offer sufficiently
       robust, non-conductive material for a base.
       The car parts stores, amazon, ebay, et.als. will also
       have manufactured holders.
   http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Littlefuse/0498-MIDIFuseholder.pdf
       But I usually build 'em when I need one.
       You could also consider a fusible link. If it were
       my airplane, a 6AWG b-lead protected by a 10AWG
       fusible link would be an attractive up-grade from
       bolt-on current limiters.
       The nagging question is, Why did your original
       limiter open up? Electrical fault or mechanical
       aging?  I think I'd jumper across your original
       ANL mounting space with a hung of 12AWG wire
       and fire up the engine to see how the alternator
       is performing. Without seeing the wiring diagram
       for your airplane, I'm guessing that the ANL was
       for alternator b-lead protection?
       Inquiring minds would like to know . . .
                    (o o)
     ===========o00o=(_)=o00o=========
     < Go ahead, make my day . . .   >
     < show me where I'm wrong.      >
     In the interest of creative evolution
     for the-best-we-know-how-to-do based
     on physics and repeatable experiment.
		Kellym
				 Posted: Fri May 31, 2024 6:29 pm    Post subject: ANL fuse 60 amp. |
				Bob,
 I am procuring tomorrow the necessary pieces to test with a       fusible link, as I have not found what caused the fuse to blow.
 It is 10 years old so age could have been a factor I didn't have       the pieces leftover from my build. I will test the system before       installing a new fuse.
 Kelly
           On 5/31/2024 3:19 AM, Robert L.       Nuckolls, III wrote:
       	  | Quote: | 	 		                  The ANL/ANN series devices have been used         aboard
            Plan-B         was
               airplanes.
               or very similar.
KCHD |
