		Deems Davis
				 Posted: Wed Nov 29, 2006 4:17 pm    Post subject: Rudder question- ditto |
				I haven't seen a response to John's question, I too would like to know
 how other builders have set them up. when I installed my cable guides
 they were very tight, how tight did you 'fly guys leave them?
 Deems Davis # 406
 Finishing - ( A Misnomer ! )
 http://deemsrv10.com/
 John Hasbrouck wrote:
  	  | Quote: | 	 		   Question regarding rudder bearing blocks and the "nylon" rudder cable
  guides.  How snug should both of these be?  I can tighten the center
  rudder bearing block to the pont where the rudder pedals will not
  move, obviously too tight.  Same with the rudder cable guides.  How
  much play do we need in these?  Are the aerodynamic forces on the
  rudder enough to overcome the situation?  Will there be enough wear in
  to loosen the pedals and the cable?  Inquiring minds want to know
  John Hasbrouck
  #40264
		Tim(at)MyRV10.com Guest
				 Posted: Wed Nov 29, 2006 5:39 pm    Post subject: Rudder question- ditto |
				The cable guides for the rudder can be tight.  You'll be moving
 the pedals with your strong legs.  You wouldn't want the pedals
 loose and flopping around....it'll take a bit of a push to move
 them.  If you can tighten the center block to the point where you
 can't move the pedals, my question is....how much force would
 it take for you to move them...a lot, or a little?  If you
 honestly can't move them, even with huge force, yeah, they're
 too tight.  I can't imagine the hole being drilled right and
 not having it be at least close.   As for the aerodynamic forces,
 there isn't much for force on a trailing rudder....until you
 push it out into the wind, and at that point, there's lots of
 force trying to re-center it.   My guess is everything is just
 fine, as long as everything is moveable in some way.
 Deems Davis wrote:
  Deems Davis # 406
 > John Hasbrouck
 > #40264
		jhasbrouck(at)woh.rr.com Guest
				 Posted: Wed Nov 29, 2006 6:05 pm    Post subject: Rudder question- ditto |
				Tim,
      Thanks for the reply!!  Since I don't have seats installed I can't get
 good read on how the rudders will feel when moved with my legs.  Did you
 torque the bolts for the center block to the values recomended for the AN3
 bolt?  If I do that I can't move the pedals with my hands but that doesn't
 speak to how they'd feel with my legs.  Trying to avoid having to go back
 and adjust stuff  later.  It's much easier when it's all open......john
 #40264
				 Posted: Wed Nov 29, 2006 6:25 pm    Post subject: Rudder question- ditto |
				That seems strange that you couldn't move them at ALL with your hands.
 I mean, it'll take a shove on the bottom of the pedal, and then
 suddenly they break free and swing, but you should at least
 be able to move them.  Is there a huge gap between the block halves
 or something that is allowing it to be super tight, or is it
 basically coming together right when you start to tighten the
 bolts?  I just can't imagine that part being able to be torqued
 so that it pinches too tightly to be good...but I suppose it's
 possible somehow.  If you can't move them with your hands though,
 with even a hard push on the bottom of the pedal, then I'd
 say that is too tight.  Maybe some silicone spray would help,
 or at that point you may want to verify the parts are cut properly.
  Tim,
  get good read on how the rudders will feel when moved with my legs.  Did
  you torque the bolts for the center block to the values recomended for
  the AN3 bolt?  If I do that I can't move the pedals with my hands but
  that doesn't speak to how they'd feel with my legs.  Trying to avoid
  having to go back and adjust stuff  later.  It's much easier when it's
  all open......john
  #40264
				 Posted: Wed Nov 29, 2006 7:30 pm    Post subject: Rudder question- ditto |
				Tim,
      The block halves come together fine but the diameter of the opening has
 been reduced by the width of the saw blade used to cut the block in half.
 While we've been discussing back and forth I've been working the rudder
 pedals and I think they are "wearing in".  The movement seems to be freeing
 up with use and as it does I've tightened the bolts a little more.  My
 biggest concern was that there would be sufficient aerodynamic force to
 re-center the rudder and over come the friction in the system....john
 #40264
		jesse(at)itecusa.org Guest
				 Posted: Thu Nov 30, 2006 6:24 am    Post subject: Rudder question- ditto |
				Tight enough to put some drag, but not really tight.  It helps to keep the
 cables a little snug in their places if they hold on, but you certainly
 don't want it so tight that you can't move it with your hand.  I can't speak
 to whether it will loosen with wear or not, but I wouldn't want to leave it
 that way.
 Just my take on it.
 Jesse Saint
 I-TEC, Inc.
 www.itecusa.org
 W: 352-465-4545
 C: 352-427-0285
