Marshall
Posted: Sat Feb 03, 2007 9:01 am Post subject: Landing Gear |
Hi Kolbers,
Even thought I am working on a Firefly and trying to keep it legal, I think that the Grove aircraft landing gear system is worth a look for most aircraft applications. http://www.groveaircraft.com/index.html
http://www.groveaircraft.com/landing_gear.html
Also take a look at the http://www.zenithair.com/stolch701/7-design-gear.html spring landing drop test curiosity of http://www.zenithair.com/ (a great aircraft and design).
Thank you, Marshall Watkins
Richard Pike
Posted: Sat Feb 03, 2007 11:29 am Post subject: Landing Gear |
I had the pleasure of being at Oshkosh and watching when Zenair first
introduced the CH 701, it was making short field takeoffs and landings, and
they did a max performance short field landing - the main gear spring attach
brackets broke and the main gear leaf spring ripped loose and folded back,
dumping the tail on the ground, and leaving the airplane sitting in the
middle of the runway looking very forlorn. A bunch of Zenair guys promptly
ran onto the field, picked it up and hustled it into immediate repairs
before too many potential customers got a look at it. They had it flying
again that afternoon, but the short field/quick stop landings were a lot
less aggressive. So if you put a leaf spring gear on your Firefly, don't use
just any old Zenair brackets you might have lying around...
Richard Pike
MKIII N420P (420ldPoops)
PS - I have an old Zenair CH 701 radiator out in the hangar. Anyone wants it
can have it for the cost of shipping. Beware - it is BRASS and weighs a ton.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Steve Boetto
Posted: Sat Feb 03, 2007 12:02 pm Post subject: Landing Gear |
A really nice wheel and brake system for the Firefly and other Kolbs is available from www.flyfbi.com
It is an overlooked option that is better than anything I have seen. I don't need wheels or brakes so I have not tried it.
Steve
FF 007 on floats
Posted: Sat Feb 03, 2007 12:37 pm Post subject: Landing Gear |
At 09:01 AM 2/3/07 -0800, you wrote:
Marshall,
If you are trying to save some weight, stay with the Kolb aluminum legs. I
weighed one and it came out to 2 pounds 6.6 ounces.
Jack B. Hart FF004
Winchester, IN
Posted: Sat Feb 03, 2007 12:41 pm Post subject: Landing Gear |
Hi Marshall:
Looked at a lot of different gear legs for Kolbs since 1984. Spring
aluminum gear was one of them. However, there are cheaper and better
ways to go. Aluminum can only be hardened to 7075 (correct me if I am
wrong), ends up weighing a ton, and very expensive.
I use tubular 4130 heat treated to 48 RC. Have been flying with it
for 20 years and many thousand hours. Has been thoroughly proven
through many thousands of landings. A lot of them not too purty.
Some folks say aluminum is better because it will not tear up the
fuselage during a hard landing. I have been able to tear up fuselage
with aluminum as well as steel. If you hit hard enough you will
probably bend the cage with either.
Tubular steel is much lighter than the Grove gear. 25 to 35 lbs is
heavy. I think, IIRC, when we built the steel gear for my mkIII, it
was the same weight as the solid rod aluminum legs.
For what it is worth,
_________________ John Hauck
Titus, Alabama |
d-m-hague(at)comcast.net Guest
Posted: Sat Feb 03, 2007 1:11 pm Post subject: Landing Gear |
At 03:34 PM 2/3/2007, John Hauck wrote:
...Aluminum can only be hardened to 7075 (correct me if I am
wrong), ends up weighing a ton, and very expensive...
7075 isn't a hardness level, it's an alloy. The hardness spec is a dash
number, e.g. 7075-T6. I don't have the numbers handy but 7075 (at any heat
treat level) is quite strong, nearly as strong as unhardened 4130, but it's
susceptible to stress corrosion cracking (cracks start around holes in
stressed areas, or from scratches or nicks). Aluminum has a better
strength to weight ratio than steel, but it's more difficult to weld and
repair (some alloys can't be welded at all).
| Quote: | Some folks say aluminum is better because it will not tear up the
Exactly. The ideal gear, I guess, is just slightly weaker than the
fuselage attachments.
One advantage (which could also be a disadvantage depending on the
situation) aluminum does have is that the modulus of elasticity is 1/3 that
of steel... which means that all other things being equal it'll flex
farther than steel of comparable strength before breaking (or staying bent).
-Dana
Wernher von Braun settled for a V-2 instead of a V-8.
Eugene Zimmerman
Posted: Sat Feb 03, 2007 1:44 pm Post subject: Landing Gear |
Wouldn't "1/3 that of steel" mean exactly opposite of what you said?
The modulus of elasticity of steel is greater than aluminum?
On Feb 3, 2007, at 4:07 PM, Dana Hague wrote:
| Quote: | One advantage (which could also be a disadvantage depending on the
1/3 that of steel... which means that all other things being equal
it'll flex farther than steel of comparable strength before
Posted: Sat Feb 03, 2007 2:16 pm Post subject: Landing Gear |
That's what I said... aluminum's modulus is 1/3 that of steel; steel has 3X
the modulus of aluminum... thus steel takes 3X the force to bend the same
amount (until the elastic limit is reached)... or put the other way, for
the same force aluminum will bend 3X as much. If the breaking force is the
same, that means the aluminum will bend 3X as much before breaking.
-Dana
-Dana
At 04:43 PM 2/3/2007, Eugene Zimmerman wrote:
| Quote: | Wouldn't "1/3 that of steel" mean exactly opposite of what you said?
Posted: Sat Feb 03, 2007 2:30 pm Post subject: Landing Gear |
steel has 3X
| the modulus of aluminum... |
| -Dana
Sorry.
You guys are way over my head. I don't know one modulus from the
other, but my gear works great. Been there and done that.
I do know that 4130 makes a hell of a better spring than 7075-T6. We
adjust the size, shape, and hardness to get the spring we want. I can
do that with 4130, but not 7075.
Steel springs are much more common than aluminum springs. Wonder how
come?
Titus, Alabama |
a58r(at)verizon.net Guest
Posted: Sat Feb 03, 2007 3:00 pm Post subject: Landing Gear |
There once was a modulus named Young
From whom all landing gear sprung.
But one bad day,
While alighting in hay,
The Kolb legs turned softly to dung.
regards,
Bob N. FireFly 070 Old Kolb
DO NOT ARCHIVE
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Sat Feb 03, 2007 7:01 pm Post subject: Re: Landing Gear |
Steve et al,
I have looked at the FBI Black Max brakes online, but haven't talked to anyone who has used them or even seen them first hand. Have you got a chance to look at them in person? They sound great and the price is right. I down-loaded their installation manual and like the well thought out instructions and photos. Has anyone on the list seen a set of these? AC Spruce is listing them on their web site.
Brakeless in Oregon
Posted: Sun Feb 04, 2007 5:06 am Post subject: Landing Gear |
At 10:01 PM 2/3/2007, R. Hankins wrote:
Steve et al,
I have them on my Ultrastar. I haven't flown or even taxied the plane yet
so I can't comment on their performance, but from an engineering standpoint
they look very good, and the previous owner was happy with them. Mine are
set up as heel brakes (just the way I like it) with two master cylinders.
Company service is good though; the 6" wide wheels that came with the plane
(included with the brake package) were too wide for the plane to fit in the
trailer, so I got a pair of 4" wide wheels from FBI and the plane now
fits. I do get the impression (could be wrong) that it's a one man shop;
all my emails to him were answered in the evening.
-Dana
jindoguy(at)gmail.com Guest
Posted: Sun Feb 04, 2007 5:53 am Post subject: Landing Gear |
All, I have them on my trike, and for that application they work just fine. They are certainly better than the nose wheel brake that was standard equipment.
For airplanes, they lack the ability to brake differentially unless you add a second master cylinder as Dana has done. By the time you add that and the necessary components to enable it, I would bet they are a wash with the other sets ou there, pricewise.
Have you checked out the system offered by TNK? Very high quality, the usual great service and you get what no other vendor can offer, i.e the experience of Travis, Donnie and the crew at TNK.
If you're not absolutely wedded to juice brakes, the Azusa mechanical units are impossible to beat for cost. I have the 4 1/2" units on my Mk 3 and they are quite adequate.
Rick
On 2/4/07, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote: | Quote: | --> Kolb-List message posted by: Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
| Quote: | --> Kolb-List message posted by: "R. Hankins" < rphanks(at)grantspass.com (rphanks(at)grantspass.com)>
Steve et al,
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Steve Boetto
Posted: Sun Feb 04, 2007 6:12 am Post subject: Landing Gear |
In a message dated 2/3/2007 10:02:46 P.M. Eastern Standard Time, rphanks(at)grantspass.com writes:
| Quote: | --> Kolb-List message posted by: "R. Hankins" <rphanks(at)grantspass.com>
Steve et al,
Brakeless in Oregon
I spotted the brakes at SNF last year and dragged Bryan,Travis and Bruce down to look at them. Everyone was impressed with the design, weight and cost. Travis was going to handle them and I believe that he ordered some. I will check with Travis on Monday.
In my opinion, the biggest plus was the weight or lack of, if you look at the whole package. This really helps make weight in the Firefly. It also gives you more tire. Kinda a cross between the stock baby tires and the overkill of a wheelbarrow tire.
Also, you are right about the size of the company. It is two guys that design medical equipment if I recall.
They use Cad and have access to the best machining equipment.
BEST TIRE BRAKE COMBO I have seen.
Hmm mm, maybe I can strap some on the bottom of my floats!!
Steve
Wheeless in the Water
DAquaNut(at)aol.com Guest
Posted: Sun Feb 04, 2007 1:32 pm Post subject: Landing Gear |
In a message dated 2/4/2007 7:07:32 A.M. Central Standard Time, d-m-hague(at)comcast.net writes:
-Dana
Dana,
Any idea what the brake set up along with the master cylinder and calipers weighs?
Ed (in Houston FF #62)
Posted: Sun Feb 04, 2007 1:56 pm Post subject: Landing Gear |
At 04:31 PM 2/4/2007, DAquaNut(at)aol.com wrote:
| Quote: | Any idea what the brake set up along with the master cylinder and
calipers weighs?
Never having seen the package off the plane, I couldn't say... but it sure
doesn't look like it's more than a few pounds:
http://flyfbi.com/html/hydraulic_brakes.html
-Dana
Back Up My Hard Drive? I Can't Find The Reverse Switch!
Steve Boetto
Posted: Mon Feb 05, 2007 11:50 am Post subject: Landing Gear |
Talked to Travis this morning.
He has two set of the Black Max in stock and has sold several sets.
All good comments have come back
Steve
