		AZFlyer
				 Posted: Mon Mar 19, 2007 3:03 pm    Post subject: OAT (Outside Air Temp. probe) location |
				Hi all,
 Any suggestions as to best location for OAT probe.  Am thinking fuslage, but not sure of best (undisturbed location).
 Looking for input...
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember,  "the second mouse gets the cheese"! |
		bryanmmartin
				 Posted: Mon Mar 19, 2007 3:53 pm    Post subject: OAT (Outside Air Temp. probe) location |
				Someplace where the sun can't shine on it and heat from the engine
 can't flow over it. Maybe under the wing root?
 On Mar 19, 2007, at 7:03 PM, AZFlyer wrote:
  	  | Quote: | 	 		   Any suggestions as to best location for OAT probe.  Am thinking
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
				 Posted: Mon Mar 19, 2007 4:50 pm    Post subject: OAT (Outside Air Temp. probe) location |
				Hi Bryan,
 I placed my OAT at the outside edge of the belly angle, right side and
 fed it thru the forward foot channel from the side.
 The readings seem to match my thermometer at the hangar during run up.
 At least it keeps the wires out of the way.
 Larry McFarland at www.macsmachine.com
 Bryan Martin wrote:
  <bryanmmartin(at)comcast.net>
  --Bryan Martin
  N61BM, CH 601 XL,
  do not archive.
		zodierocket(at)hsfx.ca Guest
				 Posted: Mon Mar 19, 2007 5:26 pm    Post subject: OAT (Outside Air Temp. probe) location |
				Locate on last bulkhead just below Stabilizer. 6-B-12-3
 Mark Townsend
 Can-Zac Aviation Ltd.
 president(at)can-zacaviation.com
 www.can-zacaviation.com
				 Posted: Mon Mar 19, 2007 5:49 pm    Post subject: OAT (Outside Air Temp. probe) location |
				Another good spot I have used is the NACA duct for fresh air in the
 cabin.
 Mark Townsend
		dredmoody(at)cox.net Guest
				 Posted: Mon Mar 19, 2007 7:00 pm    Post subject: OAT (Outside Air Temp. probe) location |
				For mine, I was told that the underside of one  wing, back about half of chord length would be the best place. If you go with a  location on the fuselage try to keep it underneath where it will be in the  shade. The bottom of the fuselage does get the exhaust stream so the wing is a  better place.
  Dred
  [quote]   ---
		jeffrey_davidson(at)earth Guest
				 Posted: Mon Mar 19, 2007 7:14 pm    Post subject: OAT (Outside Air Temp. probe) location |
				Do not archive this either, but Piper seems to be intent on placing it up high right smack in the middle of the windshield - must be about the worst place I can think of ….
 Jeff D.
 From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Edward Moody II
  Sent: Monday, March 19, 2007 11:01 PM
  Subject: Re: OAT (Outside Air Temp. probe) location
 Dred
		caspainhower(at)aep.com Guest
				 Posted: Tue Mar 20, 2007 6:22 am    Post subject: OAT (Outside Air Temp. probe) location |
				I am mounting mine in the NACA vent duct. I have seen numerous similar
 installations on both certified and experimental aircraft.
 Craig
 N601XS, 601xl, 0-235 lyc, wiring in progress
 Hi all,
 but not
 This e-mail message and all attachments transmitted with it from the
 Nuclear Generation Group of American Electric Power are for the sole
 use of the intended recipient(s) and may contain confidential and
 privileged information.  Any unauthorized review, use, disclosure or
 distribution is prohibited.  If you are not the intended recipient, please
 contact the sender by reply e-mail and destroy all copies of the original
 message.
