		Crvsecretary(at)aol.com Guest
				 Posted: Sat Mar 17, 2007 8:57 am    Post subject: 601 NR#4 Problems |
				Hello Listers:
  I'm building the right wing of my 601XL using the 15 gal. fuel tanks and  wing spars made for 12 gal. tanks.  I never read in the prints or photo  guide the instruction to cut the bracket for NR#4 so I drilled out the rivets  and removed the bracket.
  What kind of trouble did I get myself into?  Am I screwed?
  I appreciate all responses.
  As always, thank you.
  Tracy Smith
  Naugatuck, CT
  601XL N458XL (reserved)
 AOL now offers free email to everyone.  Find out more about what's free from AOL at AOL.com.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Sat Mar 17, 2007 9:13 am    Post subject: Re: 601 NR#4 Problems |
				You're screwed......just kidding, I couldn't resist.   If you haven't closed the LE up yet I would suggest filling the hole if possible.   A driven rivet would be best but I think a bolt or machine screw would suffice....You might add a little stiffener while you are at it but I don't think it matters.
 I'm sure one of the more experienced guys on the group will give you other suggestions as well.
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		taffy0687(at)yahoo.com Guest
				 Posted: Sat Mar 17, 2007 9:18 am    Post subject: 601 NR#4 Problems |
				Tracy,
    If I were you,  I'd go straight to Zenith with this question---- Fritz
 Crvsecretary(at)aol.com wrote:
   [quote]    Hello Listers:
   Tracy Smith
   Naugatuck,  TV dinner still cooling?
 [url=http://us.rd.yahoo.com/evt=49979/*http://tv.yahoo.com/]Check out "Tonight's Picks"[/url] on Yahoo! TV. [quote][b]
		zodierocket(at)hsfx.ca Guest
				 Posted: Sat Mar 17, 2007 9:21 am    Post subject: 601 NR#4 Problems |
				Your not screwed, Install rivets back in place of the ones you removed. Same type in same hole. The caution is that a rivet that is drilled out is not replaced, this is not acceptable. You must not leave a hole that is not filled.
 Mark Townsend
 Can-Zac Aviation Ltd.
 president(at)can-zacaviation.com (president(at)can-zacaviation.com)
 www.can-zacaviation.com
		dredmoody(at)cox.net Guest
				 Posted: Sat Mar 17, 2007 12:03 pm    Post subject: 601 NR#4 Problems |
				As long as you have already drilled out the rivets, check to see if you can  re-install the angle of the aft side of the spar. Do you have access to a  pneumatic riveter or a squeezer with the correct inserts? If not wait until you  have that done before blocking your access to both sides of the spar at that  point. Even if you just set rivets back in the holes you  will be fine. You'll make actual mistakes later on.... save the sweat for those  episodes.
  Dred
  [quote]   ---
		TxDave
				 Posted: Sat Mar 17, 2007 1:23 pm    Post subject: Re: 601 NR#4 Problems |
				Gee whiz! I'm looking at that big  95mm lightening hole in my spar web and am wondering how a tiny little rivet hole is going to create a problem. But then again, I would listen to Mark Townsend. He certainly is more knowledgeable than most of us amateurs on this forum.
 Dave Clay
 601XL scratch builder
 Temple, TX
 http://www.daves601xl.com
		naumuk(at)alltel.net Guest
				 Posted: Sat Mar 17, 2007 3:41 pm    Post subject: 601 NR#4 Problems |
				Mark and Jon are experts through the school of hard knocks. They've made
 just as many mistakes as we have, and even show them on their DVDs. (Along
 with ways to minimize the loss). Very refreshing. Listen to the voice of
 experience!
 Bill Naumuk
 HDS Fuse/Corvair
 Townville, Pa
				 Posted: Sat Mar 17, 2007 5:05 pm    Post subject: 601 NR#4 Problems |
				I may be losing it but I don't recall a lightening  hole in the spar web. You don't perhaps mean the wingtip spar  extension?
  Dred
  [quote]   ---
		TxDave
				 Posted: Sat Mar 17, 2007 6:35 pm    Post subject: Re: 601 NR#4 Problems |
				Hey Dred,
 There's a 95mm flanged lightening hole in the outboard end of the spar web. There is another in the tip extension. Page 6-W-3. Mark set me straight on the need to address an unfilled rivet hole in the spar web. Like I told him, this airplane building business is a continual learning process. Aren't we fortunate to have this forum?
 Dave Clay
 Temple, TX
				 Posted: Sun Mar 18, 2007 3:41 am    Post subject: 601 NR#4 Problems |
				I had forgotten about the other hole in the spar. I  still can't "see it" in my mind's eye. I'll check that page of the drawings just  to get my mind right. Do you have a rivet gun or someone close by who does?  I think the mania for not leaving holes can be exaggerated at times but in the  spar, I try to walk the line. In a low stress area, an unfilled hole is a  lightening hole as long as there is adequate edge distance. When I have a  useless hole drilled where I don't need it, I just pull a rivet in it or dimple  it and set a solid countersunk one if something has to sit flush on it. That  happened on the baggage deck because I didn't think far enough ahead of what I  was doing.
  This list bailed me out when Tom Henderson offered  to cut and bend me 12 extra standard L-angles for $2 apiece. I had run out due  to waste and extra use where the plans did not demand it. Zenith wanted over $7  each for them despite the material costing less than $1.70 each. I sent Tom $35  to make sure he didn't come out behind on the shipping.
  Dred
  [quote]   ---
		planecrazydld(at)yahoo.co Guest
				 Posted: Sun Mar 18, 2007 4:53 am    Post subject: 601 NR#4 Problems |
				when you talk to Zenith, make sure that you ask to speak to an engineer. Ask him if you could use a CherryMax of the appropriate size (assuming they make them that long). Somewhere in my past I recall that CherryMax rivets are considerd a structural equivalent to AD driven rivets - I do not know if that is a figment of my imagination or not!
 Edward Moody II <dredmoody(at)cox.net> wrote:  [quote]        As long as you have already drilled out the rivets, check to see if you can re-install the angle of the aft side of the spar. Do you have access to a pneumatic riveter or a squeezer with the correct inserts? If not wait until you have that done before blocking your access to both sides of the spar at that point. Even if you just set rivets back in the holes you will  be fine. You'll make actual mistakes later on.... save the sweat for those episodes.
   Dred
   [quote]  ---
				 Posted: Sun Mar 18, 2007 4:57 am    Post subject: 601 NR#4 Problems |
				shear in a "shear web" with properly engineered flanged lightening holes and shear transfer across a structure that is stiffness and buckling critical is completely different. I assumed that he drilled out the holes common to the spar caps and shear web... holes in the shear web would be best "filled" - with almost anything. Holes in the cap/web structure usually "must" be filled or it becomes a locally soft area to buckling loads.
 TxDave <dclaytx2(at)hotmail.com> wrote:  [quote]--> Zenith-List message posted by: "TxDave"
 Dave  Zodiac 601XL/Corvair?
    Don't be flakey. [url=http://us.rd.yahoo.com/evt=43909/*http://mobile.yahoo.com/mail]Get Yahoo! Mail for Mobile[/url] and
 [url=http://us.rd.yahoo.com/evt=43909/*http://mobile.yahoo.com/mail]always stay connected[/url] to friends. [quote][b]
