		gvjantzi(at)yahoo.com Guest
				 Posted: Mon May 07, 2007 5:58 pm    Post subject: 912 ul throtlle choke cabel assembly |
				I am still trying to get information on what I should order an from where. need throttle ,choke cable Assembly . need everything from cockpit to carburetors. for kitfox 5 with rotax 912ul. is there any model 5 drivers that can give me some input. thanks gerry
    TV dinner still cooling?
 [url=http://us.rd.yahoo.com/evt=49979/*http://tv.yahoo.com/]Check out "Tonight's Picks"[/url] on Yahoo! TV. [quote][b]
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		runwayrex(at)juno.com Guest
				 Posted: Mon May 07, 2007 6:39 pm    Post subject: 912 ul throtlle choke cabel assembly |
				Gerry,
    First place to look for parts for your Kitfox would be John McBean and friends over at the Kitfox factory. Great  people with lots of knowledge and parts for our planes. Do you need their contact information?
 Rex in Michigan
 Model 3 / 912UL / Warp Drive / 570 hours
 ">http://www.matronics.com/Navigator?Kitfox-List
 tronics.com
		alnanarthur(at)sbcglobal. Guest
				 Posted: Tue May 08, 2007 8:23 am    Post subject: 912 ul throtlle choke cabel assembly |
				On May 7, 2007, at 6:56 PM, Gerald Jantzi wrote:
  	  | Quote: | 	 		  | I am still trying to get information on what I should order an from where. need throttle ,choke cable Assembly . need everything from cockpit to carburetors. for kitfox 5 with rotax 912ul. is there any model 5 drivers that can give me some input. thanks gerry |
 Sportplane LLC is Info(at)sportplanellc.com (Info(at)sportplanellc.com)
 Kitfox LLC is info(at)kitfoxaircraft.com (info(at)kitfoxaircraft.com)
 John McBean is john(at)kitfoxaircraft.com (john(at)kitfoxaircraft.com)
 Debra McBean is debra(at)kitfoxaircraft.com (debra(at)kitfoxaircraft.com)
 and finally the telephone is 208 337-5111 and the fax is 208 337-5116
  The web page is http://www.kitfoxaircraft.com/contact.htm
		paul.kates(at)pathfinderl Guest
				 Posted: Tue May 08, 2007 4:33 pm    Post subject: 912 ul throtlle choke cabel assembly |
				Sky Star previously sold the throtle assembly, Mine is a common vernier throtle that I cut to fit.  It only has to reach the spliting mechanism.  Choke assemblies can be had at various motorcycle shops that sell models with two carbs, or look for a motorcycle parts supply on the internet for a split choke assembly... mine needs replacing as well so I'll let you know what I find.
 From: owner-kitfox-list-server(at)matronics.com on behalf of alnanarthur
 Sent: Tue 5/8/2007 11:23 AM
 Subject: Re: 912 ul throtlle choke cabel assembly
 Sportplane LLC is Info(at)sportplanellc.com <mailto:Info(at)sportplanellc.com>
 Kitfox LLC is info(at)kitfoxaircraft.com <mailto:info(at)kitfoxaircraft.com>
 John McBean is john(at)kitfoxaircraft.com <mailto:john(at)kitfoxaircraft.com>
 Debra McBean is debra(at)kitfoxaircraft.com <mailto:debra(at)kitfoxaircraft.com>
 The web page is http://www.kitfoxaircraft.com/contact.htm <http://www.kitfoxaircraft.com/contact.htm>
		dan(at)azshowersolutions. Guest
				 Posted: Tue May 08, 2007 5:33 pm    Post subject: 912 ul throtlle choke cabel assembly |
				Due to the recent development of the light sport RV-12, Van's Aircraft has developed what looks to be a solid choke pull for the cockpit. The new -12 is using the Rotax 912s. I just got a brief look at it, but it is said to make the pull a little easier...I'm looking into it.
   FWIW
   Dan B
   Mesa, AZ
   Kitfox IV , Building
 Paul Kates <paul.kates(at)pathfinderlwd.com> wrote:
    	  | Quote: | 	 		  Sky Star previously sold the throtle assembly, Mine is a common vernier throtle that I cut to fit. It only has to reach the spliting mechanism. Choke assemblies can be had at various motorcycle shops that sell models with two carbs, or look for a motorcycle parts supply on the internet for a split choke assembly... mine needs replacing as well so I'll let you know what I  find.
		jdmcbean(at)kitfoxaircraf Guest
				 Posted: Tue May 08, 2007 6:02 pm    Post subject: 912 ul throtlle choke cabel assembly |
				We also offer a simple choke design that works very well…
 <![if !supportEmptyParas]> <![endif]>
  AUTOTEXTLIST \s "E-mail  Signature" <![endif]-->Fly Safe !!
 John & Debra McBean
 208.337.5111
 "It's not how Fast... It's how Fun!"
 <![endif]--><![if !supportEmptyParas]> <![endif]>
 -----Original Message-----
  From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Dan Billingsley
  Sent: Tuesday, May 08, 2007 7:32 PM
  Subject: RE: 912 ul throtlle choke cabel assembly
 FWIW
 Dan B
 Mesa, AZ
   <![if !supportLineBreakNewLine]> <![endif]>
  <![if !supportLineBreakNewLine]> <![endif]>  [quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]>          - The Kitfox-List Email Forum -   --> http://www.matronics.com/Navigator?Kitfox-List              - NEW MATRONICS WEB FORUMS -   --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
		andynfultz(at)bellsouth.n Guest
				 Posted: Tue May 08, 2007 7:18 pm    Post subject: 912 ul throtlle choke cabel assembly |
				John,
     Can't find it on your web page catalog.  Where is  it?
  Andy
  [quote]   --
		cathyboone(at)softcom.net Guest
				 Posted: Fri May 18, 2007 8:06 am    Post subject: 912 ul throtlle choke cabel assembly |
				Gerald,
  Sorry I'm late on my email reply. John McBean has  everything you need at the Kitfox factory. Go online for Sportplane LLC or  Kitfox and you could also call 208 337-5111
  Larry Boone, Denair, CA
 Building Series 5  Outback
 Rotax 912 uls, IVOPROP Med
  [quote]   ---
