		baremetl(at)gvtc.com Guest
				 Posted: Tue Jun 19, 2007 4:27 pm    Post subject: LP4-3 Rivets |
				Does anyone know if Aircraft Spruce sells a rivet  that is equivalent to the LP4-3 that Van's supplies? I'm assembling an order for  ACS but don't see the same rivet that Van's sells. I'm hoping to avoid an extra  shipping and handling charge just for a few rivets.
  Ivan Haecker   -4  1370 hrs.   S.Cen.TX
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		tsneidin(at)wisc.edu Guest
				 Posted: Tue Jun 19, 2007 5:33 pm    Post subject: LP4-3 Rivets |
				I tracked this down when I first needed to order more:
 AVEX RIVETS (LP4-3) http://www.airpartsinc.com/catalog_gif/page18.htm
 Non-structural blind rivet.
 Aluminum rivet on steel stem. 1/8" diameter has 165 lbs. shear, 230 lbs. tensile.
 5/32" diameter has 255 lbs. shear and 375 lbs. tensile.
   1661 ( Low Profile ) Dome
 View this page
 Dia 	grip range 	Part # 	Price Each/100
 1/8 	.031 - .187 	1661-0410	$7.95
 5/32 	.046 - .250 	1661-0512i	$7.95
 Aircraft Spurce Cherry Rivets
 MINIMUM RIVET SHEAR AND TENSILE STRENGTH (Ibs.)
 RIVET
 DIA.
 BS SERIES   ALUM RIVET / STEEL MAND. GRADE 19
 MS SERIES   MONEL RIVET / STEEL MAND.GRADE 40
 CC SERIES   STAINLESS RIVET / STAINLESS MAND. GRADE 51
 Shear 	Tens 	Shear 	Tens 	Shear 	Tens
 3/32 	125 	175 	200 	300 	230 	280
 1/8 	200 	325 	350 	525 	450 	600
 5/32 	325 	450 	600 	900 	750 	1000
 3/16 	430 	650 	750 	1100 	1000 	1300
 1/4 	750 	1050 	1450 	2150 	1700 	2250
 When I asked Vans about using these:
 Could you please provide me with the shear and tensile strength
  	  | Quote: | 	 		   numbers for the lp4-3 and lp4-4 rivets?
 They're around 170 shear, 220 tensile, a little less than the BSP type.
  Who makes these rivets?
 Gesipa Mfg, NC
  	  | Quote: | 	 		   > Would the Cherry BSPS-43(44) or the AD41BS be _*fully*_ equivalent to
  > the LP series?
 They'd be an acceptable substitute, but they're more expensive.
 Vans
 Todd Neidinger
 9A - fuse.
 Waunakee, Wi
 H.Ivan Haecker wrote:
  	  | Quote: | 	 		   Does anyone know if Aircraft Spruce sells a rivet that is equivalent
				 Posted: Tue Jun 19, 2007 5:38 pm    Post subject: LP4-3 Rivets |
  	  | Quote: | 	 		   Does anyone know if Aircraft Spruce sells a rivet that is equivalent to
 http://www.hansonrivet.com/
				 Posted: Wed Jun 20, 2007 10:36 am    Post subject: LP4-3 Rivets |
				Tod,
 Thanks for the info. Exactly what I was looking for. Glad to see the list
 still works.
 Ivan            Do not archive
