				 Posted: Fri Jul 06, 2007 6:11 pm    Post subject: New FireFly Tail Wheel Spring System |
				Kolbers, and FireFlyers,
 I really wanted to get away from the tension spring and to use a clevis
 spring.  I could not find small light weight clevis springs.  After several
 iterations, I have a new system that uses compression springs in a way that
 is equivalent to clevis springs.  The new system can be seen at:
 http://www.thirdshift.com/jack/firefly/firefly133.html
 I believe the FireFly responds better to rudder pedal input than before,
 especially in grass.  Shaved off 1.5 ounces.  While I was at it I bushed the
 holes through which the hinge pin bolt passes.
 I hope you have a good 7/7/07.
 Jack B. Hart FF004
 Winchester, IN
		WhiskeyVictor36(at)aol.co Guest
				 Posted: Fri Jul 06, 2007 7:18 pm    Post subject: New FireFly Tail Wheel Spring System |
				In a message dated 7/6/2007 10:12:00 P.M. Eastern Daylight Time,  jbhart(at)onlyinternet.net writes:
   	  | Quote: | 	 		  | I hope    you have a good 7/7/07 |
  Jack,
  Make that 07/07/07
  BV
 See what's free at AOL.com.
