		cffd(at)pgrb.com Guest
				 Posted: Sun Jul 29, 2007 9:45 am    Post subject: 701 Takeoff w flaps |
				Has anyone tried partial flaps on the 701 to shorten takeoff roll?  Results?
 Chuck D.
 N701TX
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		n801bh(at)netzero.com Guest
				 Posted: Sun Jul 29, 2007 10:22 am    Post subject: 701 Takeoff w flaps |
				Any amount of flaps will shorten the take off roll in a 701-801. I hardly ever use them on my 801. At the full flap setting the flaperons reduce ALOT of roll control and unless the wind is calm I will not use them, don't ask how I know... On a side note I just returned from OSH and met alot of  nice fellow builders. Zenith builders dinner was good and the room was full....
 Ben Haas
 N801BH
 www.haaspowerair.com
 -- "Chuck Deiterich" <cffd(at)pgrb.com> wrote:
 --> Zenith-List message posted by: "Chuck Deiterich" <cffd(at)pgrb.com>
 Chuck&=========================          - Thhe Matronics List Features Navigator to brarch & Download, 7-Day Browse, Chat, F========================             great content now also available via ============================================
		NYTerminat(at)aol.com Guest
				 Posted: Sun Jul 29, 2007 1:18 pm    Post subject: 701 Takeoff w flaps |
				Chuck,
  I use 1/2 flaps for takeoff from my grass strip, no flaps elsewhere. It  does shorten the takeoff roll, not necessary from pavement.
  Bob Spudis
  701ZX/912S/120hrs
  In a message dated 7/29/2007 1:46:51 P.M. Eastern Daylight Time,  cffd(at)pgrb.com writes:
   	  | Quote: | 	 		  -->    Zenith-List message posted by: "Chuck Deiterich"    <cffd(at)pgrb.com>
 Chuck  D.
 N701TX
		jetboy
				 Posted: Sun Jul 29, 2007 2:54 pm    Post subject: Re: 701 Takeoff w flaps |
				Nearly always use 16 deg (full flap on rev-4 and later designs) for T/O and climbout as it gives better cooling and about the same climb rate (at) 50 KTs. Also at the point of liftoff the pitch up response is less pronounced.
 Ralph
  _________________ Ralph - CH701 / 2200a |
				 Posted: Mon Jul 30, 2007 6:44 am    Post subject: 701 Takeoff w flaps |
				Ralph,
 I used ZAC's 701 specs when I built my hanger.  It turns out they had
 changed the landing gear
 and so the rudder was a bit too high.  I put a 2" block between the nose
 strut and nose
 wheel fork.  The tail now fits and there is a slight nose up attitude on the
 ground.  I noticed
 that the ZAC factory 701 pitched up at lift off too.  I hold a bit of back
 pressure and my 701
 lifts off smoothly with no ptich up.
 I will try some flaps, thanks,
 Chuck D.
 N701TX
 Time: 03:55:29 PM PST US
 Subject: Re: 701 Takeoff w flaps
 climbout
 Ralph
		stol701(at)yahoo.com Guest
				 Posted: Mon Jul 30, 2007 7:36 am    Post subject: 701 Takeoff w flaps |
				Ralph,
  Could you send me a picture of the "2" block". I am going to want to raise the nose wheel and put larger main tires on. The plane at this website http://www.qualitysportplanes.com/ has larger mains, I just need to figure out how to do it.
  Rob
