Tim Olson
Posted: Sat Jul 28, 2007 6:34 pm Post subject: Trim Problem with Ray Allen Relays |
I have an interesting new problem that has crept up with my trim.
I was comparing notes at OSH with Scott and he's having the same issue,
and both of us have only had the problem for less than 2 weeks or so.
The issue is, you may be trimming your plane nose up or down, and when
you stop trimming in one direction, it won't operate in the opposite.
For instance, I overshot on nose down trim, but then it wouldn't let
me trim it back nose up. It happened once the week before OSH, and
I got it to release by adding more nose down trim, and then doing the
nose up. The downside to this is that if it stays stuck, you're now
even MORE nose down trimmed. It happened again on the way to OSH, and
then it happened during the show and I had to land with lots of
pressure pulling back on the stick.
Scott got to Ray Allen's booth first and discussed it with them and
I followed afterwards and had the same discussion. They said that
the REL-1 is now replaced with the REL-2 which is more heavy duty, but
that the REL-1 had operated for years with no issues, until recently.
Within the last couple years, the REL-1's have been produced as
RoHS compliant, (lead free) and now they're seeing them come back
with issues. They gave both of us replacements free, as we were both
experiencing the same problem. For a photo of these relays,
check these 2 links. The first one is the original relay, and the
second is the new one.
http://www.aircraftspruce.com/catalog/elpages/rel1.php
http://www.aircraftspruce.com/catalog/elpages/servoRelayDeck.php
I'll be replacing mine in the next day or so, but thought it
good to give a heads-up on this. It will probably be something that
you run into if you have the REL-1 and got it within the last
couple years.
Also, rapping on the relay does get it to release...I tried that
today. So, it's physically sticking inside. Normally, the relay
grounds both wires to the trim servo when not active, and I think
from what they told me that the sticking is actually the result
of it not completing it's previous trim operation fully, returning
to that ground-ground postion.
Here is some additional info on the relays from Ray Allen.
http://www.rayallencompany.com/RACmedia/instructionsREL.pdf
http://www.rayallencompany.com/products/accessories.html
Tim - 260 hours and counting
wayne.e(at)grandecom.net Guest
Posted: Sun Jul 29, 2007 4:26 am Post subject: Trim Problem with Ray Allen Relays |
HI Tim,
I'm having the same problem with my trim. I though it was something we did wrong. I'm glad to hear there is a quick solution.
Thanks for the heads up.
Wayne Edgerton #40336
flying
Tim Olson
Posted: Sun Jul 29, 2007 7:08 am Post subject: Trim Problem with Ray Allen Relays |
Just got word from Vic that he replaced his MAC relay last year too,
and now he *thinks* it's happening again (at least once). That
would seem to show a trend...he's got over 400 hours, and I've got
260 and Scott in the low 200's I think. So it looks like perhaps
the REL-1's will only go so long and you'll start having them
stick. The prudent thing would be to replace them before that
happens.
Wayne Edgerton wrote:
| Quote: | HI Tim,
flying
n8vim(at)arrl.net Guest
Posted: Sun Jul 29, 2007 8:27 am Post subject: Trim Problem with Ray Allen Relays |
Hey Y'all...
I'm an EE, and one question keeps popping into my head on the relay issue:
Why are you using a *mechanical* relay? Does it give you any advantage
over a solid-state relay or equivalent circuit?
Just curious... Neither right or wrong implied....
-Jim 40384 (just unpacking fuselage kit between downpours.. Woohoo!)
Tim Olson wrote:
happens.
> HI Tim,
> flying
> do not archive
Tim Olson
Posted: Sun Jul 29, 2007 9:09 am Post subject: Trim Problem with Ray Allen Relays |
Jim,
Man, while I agree with you, it's a tough one to call, because either
way you can have a failure. I guess I'm just as uncomfortable
having one than the other, but right now there isn't a commercial
alternative that is in ready-to-use form, and I myself will be
happy to just snip and solder to get it working well. From the
sounds of it, they've been abusing and testing the heck out of
their REL-2, so I would hope we wouldn't continue to see issues
after that swap. If someone came out with a pretty foolproof
commercial solid state relay for the task, complete with
interchangeable wire harness, I'd probably look at it too.
I'm a build-it-yourself guy, but on this one I'm not only lazy, but
I'd want to see someone's schematic first.
James Hein wrote:
Hey Y'all...
> happens.
> Tim Olson - RV-10 N104CD - Flying
> do not archive
>> HI Tim,
>> flying
>> do not archive
planesmith(at)hotmail.com Guest
Posted: Sun Jul 29, 2007 12:08 pm Post subject: Trim Problem with Ray Allen Relays |
In Ray Allen's documentation, that comes with the 207 hand grip, it shows a way to direct wire the stick controls without the rely. However, if a second grip or the panel mounted rocker switch is used the alternative shown is a DPDT switch that transfers the function for one control stick to the other or panel rocker switch. Not as elegant as the relays but it is an option.
Vern Smith #324 fuselage systems
| Quote: | Date: Sun, 29 Jul 2007 12:06:40 -0500
Subject: Re: Trim Problem with Ray Allen Relays
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Jim,
James Hein wrote:
> --> RV10-List message posted by: James Hein <n8vim(at)arrl.net>
> Hey Y'all...
>> happens.
>> do not archive
>>> HI Tim,
>>> flying
>>> do not archive
Don't get caught with egg on your face. Play Chicktionary! [quote][b]
LarryRosen
Posted: Sun Jul 29, 2007 1:39 pm Post subject: Trim Problem with Ray Allen Relays |
Aircraft Extras has a relay board for the Ray Allen relays.
<http://www.aircraftextras.com/RelayBoard1.htm>
Any experience out there with these relays. Just about ready to mount
the pair I have.
Larry Rosen
RV-10 #356
http://lrosen.nerv10.com
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27724 Location: Toledo Washington (KTDO) USA
Posted: Sun Jul 29, 2007 5:54 pm Post subject: Trim Problem with Ray Allen Relays |
At 02:35 PM 7/29/2007 Sunday, you wrote:
Any experience out there with these relays. Just about ready to mount the pair I have.
Larry Rosen
RV-10 #356
Our Matronics Governor MkIII does a similar function and includes speed control in a small, reliable package:
http://www.matronics.com/governor/
There are over 1000 RVs flying with the Governor MkIII!
Best regards,
Matronics
_________________ Matt Dralle
ddddsp1(at)juno.com Guest
Posted: Mon Jul 30, 2007 3:42 am Post subject: Trim Problem with Ray Allen Relays |
Matt,
Are you saying a person can just replace the RE-1 relays with your MK governor? How is yours different from the ray Allen (besides speed control) internally?
Dean
805HL
s.
font> [quote][b]
Ray.R.Doerr(at)sprint.com Guest
Posted: Mon Jul 30, 2007 5:38 am Post subject: Trim Problem with Ray Allen Relays |
Exactly. I've designed and built my own Ailron, Elevator and Flap controller using solid state MOSFET drivers. I have 290 hours on my RV-10 now and all the trim motors are working perfectly. The problem with relays over time is they can stick or build up carbon on the leads from opening and closing all the time. I very small circuit board could be made with the H MOSFET driver on it and a DB-9 connector.
Thank You
Ray Doerr
40250
N519RV
sam(at)fr8dog.net Guest
Posted: Mon Jul 30, 2007 6:19 am Post subject: Trim Problem with Ray Allen Relays |
Could you pass along a parts list and a schematic?
Sam Marlow
30hrs
Doerr, Ray R [NTK] wrote: [quote] [quote]--> RV10-List message posted by: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com> (Ray.R.Doerr(at)sprint.com) Exactly. I've designed and built my own Ailron, Elevator and Flap controller using solid state MOSFET drivers. I have 290 hours on my RV-10 now and all the trim motors are working perfectly. The problem with relays over time is they can stick or build up carbon on the leads from opening and closing all the time. I very small circuit board could be made with the H MOSFET driver on it and a DB-9 connector. Thank You Ray Doerr 40250 N519RV --
Tim Olson
Posted: Mon Jul 30, 2007 7:28 am Post subject: Trim Problem with Ray Allen Relays |
No kidding, Ray, that would be awesome if you have a schematic and parts
list. Would be a good way to go. I did get my new relay swapped in
yesterday so I'm good to go now, but when the next one sticks I'd
just re-do everything electronic...as long as it's fully wiring compatible.
Sam Marlow wrote:
[quote] Could you pass along a parts list and a schematic?
Sam Marlow
30hrs
> Thank You
> Ray Doerr
> 40250
> N519RV
Posted: Mon Jul 30, 2007 7:53 am Post subject: Trim Problem with Ray Allen Relays |
At 04:38 AM 7/30/2007 Monday, you wrote:
| Quote: | Matt,
Dean
805HL
Yes, exactly. The Governor MkIII replaces the functionality of the RE-1 plus adds the speed control functionality. The Governor MkIII uses exceptionally high quality components and we've had little issues with them when installed according to the instructions. They are available from Van's Aircraft and direct from our website: http://www.matronics.com/governor .
