		DanM
  Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
				 Posted: Thu Aug 09, 2007 8:55 am    Post subject: Fuel Line Tubing |
				I'm getting ready to install the fuel lines from the wing tanks to the header tank. My kit came with the rubber tubing that is not supposed to be use so I need a replacement. I saw some clear vinyl tubing at the hardware store and thought it maybe suitable. Any opinions out there? Thanks in advance
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
		kitfoxmike
				 Posted: Thu Aug 09, 2007 9:20 am    Post subject: Re: Fuel Line Tubing |
				bing alcohol resistant fuel line:  blue in color
 spruce no.
 3/8 x 1/4  05-00500
 1/4 x 1/8  05-00560
		Fox5flyer Guest
				 Posted: Thu Aug 09, 2007 10:16 am    Post subject: Fuel Line Tubing |
				Dan, the hardware store variety is made of vinyl and in a very short time
 will harden up and be leak prone.  Over a longer period of time it can
 actually get brittle to the point where any excess flexing can cause it to
 crack.  ACS has the Bing lines and also any
 motorcycle/snowmachine/waverunner shop should have the correct stuff to use
 that will hold up.
 Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP 355+ TT
 "If you don't read the newspaper you are
 uninformed, if you do read
 the newspaper you are misinformed."
 Mark Twain
		jimlc
				 Posted: Thu Aug 09, 2007 1:09 pm    Post subject: Fuel Line Tubing |
				I have used the clear vinyl tubing to replace my sight tube and it has worked for over a year and also has not discolored as did the original tubing furnished.
 Jim Crowder
 Series 5
 Installing Jabiru 3300
   -= - T      [quote][b]
		kentk
  Joined: 03 Jan 2007 Posts: 25 Location: College Station
				 Posted: Thu Aug 09, 2007 5:55 pm    Post subject: Re: Fuel Line Tubing |
				I am going to use Tygon tubing to replace the clear plastic with - the shop where I bought it said that it is standard for using with auto fuel.
  _________________ Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done |
		kitfoxfugit(at)yahoo.com Guest
				 Posted: Fri Aug 10, 2007 10:15 pm    Post subject: Fuel Line Tubing |
				Subject: Fuel Line Tubing
 wing tanks to the
  header tank.
 Dan, when I replaced mine a year ago, I used fule line
 from a place that sells snowmobiles, ATV's and
 motorcycles.  It has yellowed a bit in the year, but
 not deteriorated despite lots of gas through it.  We
 have alcohol in our car gas in CA.
 John Allen
 Kitfox IV Speedster w/ 912UL (at) O70
 Choose the right car based on your needs.  Check out Yahoo! Autos new Car Finder tool.
 http://autos.yahoo.com/carfinder/
		kitfoxpilot(at)msn.com Guest
				 Posted: Sat Aug 11, 2007 6:58 pm    Post subject: Fuel Line Tubing |
				I replaced mine with black fuel line I obtained from the local boat dealer,
 been working great!
 Ray
  	  | Quote: | 	 		  From: John Allen <kitfoxfugit(at)yahoo.com>
 Date: Fri, 10 Aug 2007 23:14:52 -0700 (PDT)
 wing tanks to the
   header tank.
 John Allen
 Finder tool.
 Booking a flight? Know when to buy with airfare predictions on MSN Travel.
 http://travel.msn.com/Articles/aboutfarecast.aspx&ocid=T001MSN25A07001
