		Paul Valovich
				 Posted: Thu Aug 30, 2007 7:20 am    Post subject: Precision Airmotive Eagle EMS |
				Indecision is once again the key to flexibility! After several job-related delays, I’m REALLY at the engine-ordering stage of my -8A project. I’ve decided on an Aerosport 180 hp fuel injected engine and initially thought dual Lightspeed ignition was the way to go. However, I’ve now heard of the Precision Airmotive Eagle EMS and am somewhat intrigued.
 Anyone have any experience – or opinions?
 Paul Valovich
 Ridgecrest, CA
 N192NM Reserved
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ronlee(at)pcisys.net Guest
				 Posted: Thu Aug 30, 2007 9:31 am    Post subject: Precision Airmotive Eagle EMS |
				While it sounds interesting I would like to see  reasonable field use reports.
  I am not one to be an early adopter of new aviation  items like this.  Nor am
  I a fan of FADEC like systems.  I have seen  one and it struck me as too
  complex, expensive, possible heavy and it "may"  have been at fault in the
  forced landing of a 7A that was essentially  destroyed.
  I like to lean my mixture after start up to taxi  and after landing to minimize
  plug fouling.  That apparently is not possible  with this system so I would
  guess (not verified) that foiled plugs may be more  common than with my
  carbureted, manually leaned system.
  I definitely see no reason to change from what I  have.  With a new purchase
  it may make sense for some but with my perhaps  close-minded view, I would
  stick with your original plan.
  A mag and one Lightspeed do provide different  ignition failure modes.
  Ron Lee
				 Posted: Thu Aug 30, 2007 9:33 am    Post subject: Precision Airmotive Eagle EMS |
				I just reread your ignition choice and see that you  are planning DUAL
  Lightspeeds versus my one (plus a mag).   Lightspeed is the only system
  that I would do that with.
  Ron Lee
		Bret Smith
  Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
				 Posted: Thu Aug 30, 2007 10:09 am    Post subject: Precision Airmotive Eagle EMS |
				I talked with them this year at SnF and was also  intrigued.  I really don't know where I would install the large CPU module,  though.  I also understand that it is still in development with only one  model actually being tested..i.e. there is NO history yet on how well it  performs.
  Gonna watch closely...
  Bret Smith
 RV-9A "Fuselage"
 Blue Ridge,  GA
 www.FlightInnovations.com
  [quote]   ---
  _________________ Bret Smith
RV-9A (Emp) |
				 Posted: Fri Aug 31, 2007 7:03 am    Post subject: Precision Airmotive Eagle EMS |
				Another opinion.  This is from today's AOPA  newsletter.  Note the part about the FADEC resetting.
  DOUBLE ENGINE  FAILURE PROMPTS DIAMOND AD PROPOSAL
 The FAA is  proposing an airworthiness directive  (AD) for the Diamond DA42 Twin Star. The AD would require additional backup  batteries for the full authority digital engine controls (FADECs) on TAE125-01  and TAE125-02-99 engines. This action was prompted by the in-flight shutdown of  both TAE 125-01 engines on a DA42 flying over Germany in March. The pilot of the  aircraft took off with an insufficiently charged aircraft battery. During a  moment of low voltage when the aircraft's landing gear was retracting, the FADEC  reset. This shut down the engines and caused the propeller blades to feather.  Diamond has said that it will cover the cost of the battery installation,  regardless of an AD. For more information, see Diamond's service bulleti!  n."
 Source AOPA ePilot, Volume 9, Issue 35 • August  31, 2007
