		Michael Bolton
				 Posted: Tue Oct 02, 2007 5:09 am    Post subject: M-14b Timing |
				Does anyone out there know the initial Mag timing  for the M-14b?  yes that is a "B"  I only have the manual for the P  model.  The "B" has mags with centerfugal advance.
  Thanks for any help you guys might be able to  supply.
  Michael J. Bolton, Vice President
 Young Forest  Products, Inc.
 (O)803.438.4259
 (C)803.427.0604
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue Oct 02, 2007 5:33 am    Post subject: M-14b Timing |
				I'm working on it Michael and will get back to you with the  information.
  Dennis
  [quote]   ---
		cliff(at)gesoco.com Guest
				 Posted: Tue Oct 02, 2007 10:39 am    Post subject: M-14b Timing |
				The  spark advance for  the M14 series engines is  22-24 degrees BTDC.
 If you have M9-35M magnetos, there is a degree stamp on the mating face
 of the magneto body under the mag cap.
 This stamp is typically between 23 and 37 degrees.
 To compensate for the centrifugal advance of the mag use the following
 formula:
 23 - (degree stamp / 1.25) = timing mark on the cylinder pointer in #4
 cylinder.
 If you're timing the engine via prop flange, then you will need to
 multiply the above result by the reduction gear ratio.
 On M14-P it's .658
 On M14-B it's .787
 So....with a "36" degree stamped magneto-
 23- (36/1.25) = -5.8 or 6 degrees *after* top dead center as seen on the
 cylinder pointer.
 at the prop flange of an M14-P: 5.8 * .658 = 3.8 or 4 degrees ATDC
 at the prop flange of an M14-B: 5.8 * .787 = 4.5 degrees ATDC
 Cliff
 Michael Bolton wrote:
  	  | Quote: | 	 		   Does anyone out there know the initial Mag timing for the M-14b?  yes
  (O)803.438.4259
  (C)803.427.0604
				 Posted: Tue Oct 02, 2007 1:56 pm    Post subject: M-14b Timing |
				The only thing I would add is be sure the Mags are M9-35's as stamped on the
 data plate just above the P lead and coil cover.  If they are other than the
 M9-35's, please post to the list.
 Dennis
		wlannon(at)cablerocket.co Guest
				 Posted: Tue Oct 02, 2007 3:17 pm    Post subject: M-14b Timing |
				Dennis;
 They could be M9-25M mags (23 to 27 degs of advance) on the M14B. I suspect
 that the "B" is a lower RPM engine than the "M".  In any case Cliff's
 instructions would still apply.
 Walt
				 Posted: Tue Oct 02, 2007 4:35 pm    Post subject: M-14b Timing |
				That's what I believe they are Walt.  But I certainly could be wrong.
 Dennis
				 Posted: Tue Oct 02, 2007 10:06 pm    Post subject: M-14b Timing |
				Hi Cliff;
 Could you expand on the use of the factor of  "/1.25" in calculating the
 ignition advance angle?
 What does that factor represent?
 Thanks.
 Walt
				 Posted: Wed Oct 03, 2007 4:13 am    Post subject: M-14b Timing |
				Cliff had an oops.
 I got my engines crossed between M462 and M14B.
 I was going from memory about gear reduction ratio for the M14-B engine.
 I'll go hit the books and make a final determination if needed.
 Doug pointed out that many people are running the "B" engine with a "P"
 nose case which makes the point moot anyway.
 In any event, if you time by the sparkplug pointer, then the gear
 reduction doesn't come into play.
 Cliff
 In any event
 Cliff Coy wrote:
  face of the magneto body under the mag cap.
  formula:
  cylinder.
  On M14-P it's .658
  On M14-B it's .787
  the cylinder pointer.
  Cliff
 > (O)803.438.4259
 > (C)803.427.0604
				 Posted: Wed Oct 03, 2007 4:32 am    Post subject: M-14b Timing |
				The mag turns 1.25 times per crank revolution.
 Dividing the retard angle by the drive ratio gives the offset from
 "running" position of the rotor-which is what you are ultimately timing to.
 To verify this, we can take an M9-F magneto with 0 retard angle and run
 it through the formula:
 23 - (0/1.25) * .658 = 15.1
 So 23 degrees BTDC (crank position) translates to 15 degree BTDC (prop
 flange position).
 Cliff
 Walter Lannon wrote:
  Hi Cliff;
  the ignition advance angle?
  Thanks.
  Walt
				 Posted: Wed Oct 03, 2007 9:51 am    Post subject: M-14b Timing |
				Hey...add another 1 in there...that should read
 "the mag turns 1.125 times per crank revolution"
 <sigh>
  timing to.
  run it through the formula:
  flange position).
  Cliff
 > <wlannon(at)cablerocket.com>
 > Hi Cliff;
 > Thanks.
 > Walt
