vicster_26
Posted: Mon Oct 15, 2007 4:15 pm Post subject: Fuel Flow Sensor |
Hello,
I am trying to find a suitable location for my fuel flow sensor between the fuel pump and the Bendix injector (between the injector and flow divider is out of the question) on my Lycoming AEIO-540, At the moment the simplest location has the sensor longitudinally angled downward at about 40 deg angle (the outlet being lower than the inlet). This location also ensures a straight line prior to the inlet. I've read on previous post that it is better to have the sensor level, how critical is this?
Vic
panamared5(at)brier.net Guest
Posted: Tue Oct 16, 2007 6:49 am Post subject: Fuel Flow Sensor |
Don Rivera at Air Flow Performance recommends placing the sensor
between the fuel servo and the flow divider. In most cases this
would mount the sensor vertically. I questioned him about this and
he said, he tested it and it really makes no difference.
I like the idea, because it seems to be the easiest solution. But,
at this time, I do not have a need for a fuel flow data so I have not
installed one.
RV6
"Wicked Witch of the West"
At 07:15 PM 10/15/07, you wrote:
Hello,
Vic
http://forums.matronics.com/viewtopic.php?p=140177#140177
randy(at)romeolima.com Guest
Posted: Tue Oct 16, 2007 8:40 am Post subject: Fuel Flow Sensor |
My flow sensor is mounted vertically as described below and is functioning
perfectly.
YMMV,
Randy Lervold
www.rv-3.com
rice737(at)msn.com Guest
Posted: Tue Oct 16, 2007 10:04 am Post subject: Fuel Flow Sensor |
Hey Vic,
I put mine inside the firewall downstream of the electric fuel pump. Works fine, I think the directions were written by a lawyer, say that it need to be between the mech fuel pump and the divider. As I have to of the same sensors on my boat installed prior to the mech fuel pump drawing more gph for the last ten years without a problem, I think this location will be suitable on our planes as well.
Paul Rice
N64PR
RV8
| Quote: | Subject: Fuel Flow Sensor
Date: Mon, 15 Oct 2007 17:15:45 -0700
To: rv-list(at)matronics.com
--> RV-List message posted by: "vicster_26" <vicster(at)netvigator.com>
Hello,
Vic
