john_graham
Joined: 09 Aug 2007 Posts: 45 Location: Algonquin, IL
Posted: Wed Oct 17, 2007 9:56 am Post subject: RPA Checklist |
The RPA checklist for a Yak 52 has been a great help to me. I have 3 questions:
1. During the run up it states to set the prop at 64% and move the throttle and verify the 64% stays constant. What is the purpose of this.
2. Before take off it states to move the flap handle to Neutral. Won't this depressurize the flap system and slam them down when the flaps are lowered?
3. During climb and after raising the gear, it states to put the gear handle in Neutral. Any reason for this or can it stay in th UP position.
Thanks (as always) for the help.
John
N15YK
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
_________________ John Graham
N15YK 1993 Yak-52
CubFlyer1940@Yahoo.com
(847) 641-1330 |
Posted: Wed Oct 17, 2007 10:24 am Post subject: RPA Checklist |
John,
None of that is in my now anciently translated version of the original YAK
student pilot's handbook. It says set the prop at full forward and set
"advance" (manifold pressure) at 70%, check mags for not greater than 3%
drop per side.
It only recommends setting the flaps and gear to the neutral position for
the cockpit that is not commanding the gear or flaps. It only specifies
placing the gear handle in neutral to depressurize the system before
blowing the gear down from the emergency system.
Have not looked at in a while but that is the best that I remember of it,
Doc
dsavarese(at)elmore.rr.co Guest
Posted: Wed Oct 17, 2007 11:05 am Post subject: RPA Checklist |
John,
My comments IAW your question numbers -
1. The purpose is to check the prop governor's ability to hold a constant
RPM.
2. Do NOT do this! You are 100% correct. If your copy of the manual says
this, the manual should be changed immediately and you should notify the
creator of manual that it is wrong.
3. Do NOT do this! You are depressurizing the landing gear actuators AND
the uplock assemblies. Unless you remember to put the gear handle BACK to
the UP position BEFORE moving the gear handle to the DOWN position, the
landing gear actuators will slam down. I guarantee it WILL get your
attention and a neophyte back seater will have the crap scared out of them.
Keep the gear handle in the UP position but DO NOT put the slide lock in
place while the gear handle is in the UP position during flight. Too many
people have lowered the gear handle to the neutral position with the slide
lock in place and "heard" the hiss, thinking the gear was down and locked
when in fact, the gear was just hanging limp. They also did not check for
the green lights and assumed the gear was down AND locked because they 1)
felt the firm stop of the gear handle and 2) heard the hiss of the actuators
depressurizing. When the prop goes "ding", "ding" on the runway, you'll
realize you only had the handle in the neutral position and a very loud "Oh,
SH--" is heard emanating from the cockpit.
As I said, wherever the flight manual is posted, it should have these
instructions immediately corrected. Especially #3 because it is inviting a
potential gear up landing.
Dennis
cliff(at)gesoco.com Guest
Posted: Wed Oct 17, 2007 12:52 pm Post subject: RPA Checklist |
John, it sounds like you have the instructors manual, not the pilot's
manual.
In any event, unless the compressor is having real problems, there's no
real reason to return the handles to the neutral position after selection.
It's certainly not going to damage anything to select gear neutral after
the gear is locked up.
The uplocks are mechanical latches and will not release until the gear
is selected down.
The same is true from the flap system- it's mechanically locked in
either position.
If either of these systems allow movement after they've reached the
selected position, then you have a failure of the locking mechanism-
most likely due to corrosion.
Dennis is absolutely correct about air cushioning. The gear system
*requires* pressurization on the opposite side of the actuator to slow
the movement of the gear. DAMAGE WILL RESULT from slamming the gear up
or down. The uplocks take the damage from slamming the gear up- most
notably the nose gear. If the little roller wheel is bent off to the
side, then the gear's been slammed up.
If you or your mechanic is slamming the gear down during the emergency
gear system test....You're doing it wrong! And eventually the system is
going to crack at the actuator attach points.
So before selecting up, select down first and vice versa.....or simply
never leave the handles in the neutral position.
Sure if you're low on air and you want to conserve what you've got for
starting, then go ahead and select the neutral positions *before opening
the main air valve* and that will only allow the air to be used for
starting and brakes.
Just don't forget to select gear down and flaps up after the engine is
running.
If anyone needs a gear swing checklist let me know off list.
Cheers,
Cliff
A. Dennis Savarese wrote:
<dsavarese(at)elmore.rr.com>
John,
constant RPM.
says this, the manual should be changed immediately and you should
notify the creator of manual that it is wrong.
AND the uplock assemblies. Unless you remember to put the gear handle
BACK to the UP position BEFORE moving the gear handle to the DOWN
position, the landing gear actuators will slam down. I guarantee it
WILL get your attention and a neophyte back seater will have the crap
scared out of them. Keep the gear handle in the UP position but DO NOT
put the slide lock in place while the gear handle is in the UP
position during flight. Too many people have lowered the gear handle
to the neutral position with the slide lock in place and "heard" the
hiss, thinking the gear was down and locked when in fact, the gear was
just hanging limp. They also did not check for the green lights and
assumed the gear was down AND locked because they 1) felt the firm
you'll realize you only had the handle in the neutral position and a
very loud "Oh, SH--" is heard emanating from the cockpit.
inviting a potential gear up landing.
Dennis
cjpilot710(at)aol.com Guest
Posted: Wed Oct 17, 2007 1:39 pm Post subject: RPA Checklist |
In a message dated 10/17/2007 4:53:38 P.M. Eastern Daylight Time, cliff(at)gesoco.com writes:
John,
I agree totally with all below except for one item. At least on the CJ-6 the flaps do not have lock down or lock up. Pressure holds the flaps down as long as either flap handle is in the down position. The rear handle (instructors seat) has presidents over the front handle. Put both handles in the neutral position, takes pressure off both sides of the actuator. A bungee cord in the flap area will pull the flap up. At least on the CJ - I am not sure about the Yak.
One other detail not mention here is that both the gear and flap lines have small conical washer with a hole about .05 dia. These are usually located in the lines where B nuts attach to fittings in the wheel wells. For the flap they are located right where the line attaches to the flap actuator. If you take off these lines for any reason, it is very easy for these to drop out un-noticed. The purpose is to meter the out and in flow. These control to certain extent the rate that gear and flaps retract. Craig Payne went to a great deal of fiddling to get his gear to retract evenly and at the same time, just by adjusting the size of these holes. But you still need the air pressure to work against.
Leaving gear handle in the up position has absolutely no effect on the wear of seals in the actuator. As a matter of fact, some CJ (mine is one) have no up locks at all. The only thing that holds the gear up is the pressure in the system.
Jim "Pappy" Goolsby
[quote]--> Yak-List message posted by: Cliff Coy <cliff(at)gesoco.com>
manual.
is selected down.
either position.
running.
Cheers,
Cliff
[quote] --> Yak-List message posted by: "A. Dennis Savarese"
John,
constant RPM.
Dennis
