		johnd(at)data-tech.com Guest
				 Posted: Wed Oct 10, 2007 9:30 am    Post subject: Instrument Panel Access |
				Hi All,
 I'm just wrapping up my electrical work and am getting close to putting
 on the front skin over the panel area. Riveting it per the factory seems
 to be a poor choice since I wont have any easy access to the rear of the
 panel.
 So it seems like the options are:
 A) Install nutplates or similar and make the entire skin removable. As I
 have a QB kit their are already 90+ rivet holes that would have to be
 fitted, so thats a lot of work.
 B) Install the skin permanently but add a couple of access panels on the
 top. Seems like several folks on the list are doing this. My only
 concern with this approach would be water leaking under the access
 panel. Any ideas as to how to prevent/avoid this issue ?
 Your thoughts/Ideas ?
 Thanks in advance,
 John Davis
 Burnsville, NC
 601XL QB - Jab 3300
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Jaybannist(at)cs.com Guest
				 Posted: Wed Oct 10, 2007 11:23 am    Post subject: Instrument Panel Access |
				John,
 I have posted drawings of my access panel.  Let me know if you would like me to e-mail them to you.  I set the doubler in silicone sealant. When I install the cover plate, I will run a bead of silicone around the exposed part of the doubler  and cover that with Saran before temporarily fastening the cover.  When the silicone has cured, I will remove the cover and Saran and have a "permanent" gasket.
 Jay in Dallas 601XL N2630J
 John Davis <johnd(at)data-tech.com> wrote:
 Hi All,
 panel.
 Thanks in advance,
 John Davis
 Burnsville, NC
 601XL QB - Jab 3300
		SkipperClyde
				 Posted: Wed Oct 10, 2007 12:45 pm    Post subject: Instrument Panel Access |
				I have seen sheet metal screws used instead of rivets.
 phil
		Gig Giacona
		VideoFlyer(at)aol.com Guest
				 Posted: Wed Oct 10, 2007 1:42 pm    Post subject: Instrument Panel Access |
				In a message dated 10/10/2007 , wr.giacona(at)suddenlink.net writes:
  <<<<I'm using J-Nuts and screws all the way around the top  skin>>>
  I did the same thing.
  Dave
  N618PZ
  601XL/Corvair
 S>  [quote][b]
		graeme(at)coletoolcentre. Guest
				 Posted: Wed Oct 10, 2007 2:07 pm    Post subject: Instrument Panel Access |
				I think the savanna has a good idea for instrument panel.
 The hole instrument panel panel is a removable, screwed (probably with
 rubber insulation for vibration) to
 a riveted in frame for easy access.
 Graeme Cairns
				 Posted: Wed Oct 10, 2007 2:10 pm    Post subject: Instrument Panel Access |
				Are you guys aware that the cowling overlaps the forward top skin?  Therefore, you will have to remove the cowling to remove that skin for access. At least for the WW cowling, there is a tapered channel that fastens to the nose bowl and the top skin to support and locate the nose bowl.  Seems like having to remove the cowling kinda' defeats the purpose, or at least makes access a pretty involved process. Hopefully, you will never have to access it and then difficulty becomes a moot point.
 VideoFlyer(at)aol.com wrote:
 Dave
 N618PZ
 601XL/Corvair
		GLJSOJ1
  Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
				 Posted: Wed Oct 10, 2007 2:48 pm    Post subject: Re: Instrument Panel Access |
				HI JOHN
 WHAT I DID WAS MARK WHERE THE CANOPY TOUCHED THE FORWARD TOP SKIN AND MADE A SET OF ACCESS HOLES ON BOTH SIDES JUST SMALLER SO I COULD PUT ANCHOR NUTS AND SCREWS TO HOLD IT IN PLACE.  THEN I MADE A LARGE COVER TO COVER BOTH SIDES.  IT'S NOT TOTAL ACCESS, BUT I CAN AT LEAST GET BEHIND THE PANEL
 GLENN
  _________________ 601XL N676L  FLYING PHASE I
CHESAPEAKE VA |
		davgray(at)sbcglobal.net Guest
				 Posted: Wed Oct 10, 2007 4:30 pm    Post subject: Instrument Panel Access |
				The tapered top center section of the cowl for the WW nose bowl has hinges
 that allow access to the engine compartment from the top.  There are only
 about four screws in the center that hold this to the top forward skin and
 about 6 to 8 screws that hold it to the center top section of the nose bowl.
 This part can be removed in under 1 minute.
  When you remove the top center section of the cowl you expose the firewall
 forward to the nose bowl while the top forward skin covers the firewall
 backward to the instrument panel.  With a nutplated system I can open my
 aircraft from the instrument panel to the nosebowl in less than 3 minutes
 and replace it in under 5 minutes in two pieces.
 Total work to dimple and rivet nutplates was about 2 to 3 hours extra work
 and it makes it easy access when wiring, troubleshooting, repair,
 inspections or modifications.  I have removed it at least 15 times during
 construction and during the first year. I did mine with # 8 floating
 nutplates, #8 machine screws made flush with a dimple die in my rivet
 squeezer.
 The only problem I had was setting rivets in curved sections of the firewall
 flange.  Pulling the nutplate down with a screw to make the nutplate conform
 to the curve prior to setting the rivets made it accurate and easy.  Also
 avoid crimped sections of the firewall when placing the nutplates.
 Gary Ray
		shilcom
				 Posted: Wed Oct 10, 2007 4:43 pm    Post subject: Instrument Panel Access |
				Caution here Jay.  I did the silicone thing on  a Cessna once and never could get them to quite sticking.  Tried powder,  which worked the best, but every annual they were stuck tight.  Bob U.
  [quote]   ---
				 Posted: Wed Oct 10, 2007 5:22 pm    Post subject: Instrument Panel Access |
				Bob, Thanks for the heads up.  I just might have to rethink my sealing method. Maybe a thin foam tape? - Jay
 "Bob Unternaehrer" <shilocom(at)mcmsys.com> wrote:
 [quote]Caution here Jay.  I did the silicone thing on a Cessna once and never could get them to quite sticking.  Tried powder, which worked the best, but every annual they were stuck tight.  Bob U.
		purplemoon99(at)bellsouth Guest
				 Posted: Wed Oct 10, 2007 6:29 pm    Post subject: Instrument Panel Access |
				Any chance of getting a couple picts?  I'am doing a lot on the panel,and
 have to take the whole dash top off every time It's a real pain. I was
 thinking of a over lap where the cowl would be atached to a short section
 that was pop riveted to the top of the fire wall and could ovre lap inside
 the plane with screws etc.    Joe N101HD 601XL/RAM
		tonyplane(at)bellsouth.ne Guest
				 Posted: Wed Oct 10, 2007 7:54 pm    Post subject: Instrument Panel Access |
				John,
  One of the BEST decisions I made was to make  the fwd top skin removable.  I used rivnuts and 6-32 SS screws.   Others have used nutplates and J clips?? etc.
  With the skin removed, you have access not only to  the instrument panel, but to the inside fwd firewall, rudder peddles and cables,  steering rods, brakes, etc.
  Also, I have removal of the top skin part of my  annual condition inspection to check wiring, and other areas under the  instrument panel that would be a real problem to inspect with the skin in  place.
  I also have a removable panel aft of the canopy  "line" on the top skin.  On it, I have provisions to mount 1 or 2 Garmin  GPSs (One for the pilots side and one for my spouse's side) and have also  mounted a vertical compass card..  Coming through this panel I have compass  lighting wiring and hard wiring for the GPS's  through  grommeted  holes that have a slots leading to the holes from the edge of the  panel..  When I remove the top skin, I remove this panel first and can  leave the wiring intact by passing it through the slot.
  You can see my instrument panel at http://www.zenithair.com/zodiac/6-photo79.html   (Zenith Photo Library #79) as originally finished, but since I have added some  "Stuff" , such as a switch and a blinking light to show "Wig-wag"  taxi/landing lights, another switch to use either Garmin GPS to drive my AP, a  light to show when I have the aux fuel pump on,  a Tru-Track T&B,   and ...
  I really like what you can easily do with your  airplane when it is "Experimental".  If I had to drill out the top skin  rivets to gain access to the instrument panel aft areas, it would not be as much  fun and also I believe would result in a real mess to clean up.
  Tony Graziano
  XL/Jab3300; N493TG; 304 hrs
              Subject:              Instrument Panel      Access        From:              John Davis (johnd(at)data-tech.com ([email]johnd(at)data-tech.com?subject=Re:%20Instrument%20Panel%20Access&replyto=470D085D.6000304(at)data-tech.com[/email]))        Date:              [b]Wed Oct 10 - 10:30        AM[/b]  	  | Quote: | 	 		   	  | Quote: | 	 		  Hi All,
 panel.
 Thanks in advance,
 John Davis
 Burnsville, NC
 601XL QB - Jab 3300
		shilcom
				 Posted: Thu Oct 11, 2007 3:42 am    Post subject: Instrument Panel Access |
				I'm not sure why you need anykind of  sealing.   I've never seen any seals on certified airplanes, but there  may be.  My wife sometimes applies a phrase to me that might apply  here....Don't over think it bob.  My purpose was to tighten them up  and prevent vibration and coming loose, but I don't think that is necessary  now.  I do use nylon washers on the SS screw heads.   Bob U.
  [quote]   ---
		archerm
				 Posted: Sun Oct 14, 2007 5:12 am    Post subject: Instrument Panel Access |
  _________________ Matt
www.zodiacxl.com |
		archerm
				 Posted: Sun Oct 14, 2007 5:13 am    Post subject: Instrument Panel Access |
				I put hatches in the forward top skin.  This has really been valuable to get
 at stuff and seems to work well.  I was a little concerned about the canopy
 interference but now that the canopy is on I haven't had a problem.  Check
 it out.
 http://www.zodiacxl.com/Fwd%20Top%20Skin.htm
 Matt
 www.zodiacxl.com
www.zodiacxl.com |
				 Posted: Sun Oct 14, 2007 12:18 pm    Post subject: Instrument Panel Access |
				Very Nice!  Going to use your idea  , if you don't mind.  Lot's of room to
 work .Perfect place for fire ext.too, Did you use short self tappen   screws
 when you mounted the fire ext bracket to the spar?        Joe N101 HD
 601XL/RAM
 ----- Original message -----
 To: <zenith-list(at)matronics.com>
 Sent: Sunday, October 14, 2007 9:07 AM
 Subject: Re: Instrument Panel Access
  get at stuff and seems to work well.  I was a little concerned about the
  canopy interference but now that the canopy is on I haven't had a problem.
  Check it out.
  Matt
  www.zodiacxl.com
		rge177(at)yahoo.com Guest
				 Posted: Mon Oct 15, 2007 7:07 pm    Post subject: Instrument Panel Access |
				Nice job Matt.  I did something similar, but didn't
 hinge them, and they are a little smaller, but very
 helpful getting behind the panel.  I put a pic in the
 photo share.
 Ron
 601XL-3300
 Time: 06:13:36 AM PST US
  to get
 concerned about the
  canopy
 had a problem.
   Check
 it out.
 Matt
 www.zodiacxl.com
		archerm
				 Posted: Wed Oct 17, 2007 8:54 am    Post subject: Instrument Panel Access |
				I ended up riveting the extinguisher bracket to the spar.  I had to drill
 some new holes in it but it worked fine.
 Good Luck
 Matt
 www.zodiacxl.com
www.zodiacxl.com |
		Ron Lendon
				 Posted: Wed Oct 17, 2007 6:13 pm    Post subject: Re: Instrument Panel Access |
				What kind of effect will those holes have on the integrity of the center spar?  Has anyone given that consideration or better yet, structural analysis.  Inquiring minds want to know.
  _________________ Ron Lendon
CH 601 XLB
N601LT  - Flying
Corvair Engine Prints:
