		DAVELEIKAM(at)wi.rr.com Guest
				 Posted: Mon Dec 17, 2007 9:44 pm    Post subject: OAT probe location |
				Has anyone installed their OAT probe on a  wing?  If so, where and how?  I want to make this decision before I  close my wings.
  Dave Leikam
  40496
  N89DA reserved
		ron.mcgann(at)baesystems. Guest
				 Posted: Mon Dec 17, 2007 10:06 pm    Post subject: OAT probe location |
				Hi Dave,
 I mounted mine in a rubber grommet in the right wing centre inspection plate.
 cheers,
 Ron
 187 Moving to the hangar !!
		dmaib@me.com
  Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
				 Posted: Tue Dec 18, 2007 5:10 am    Post subject: OAT probe location |
				I have not installed mine yet, but plan to install it in the next to most outboard panel on the left wing.
 David Maib
 40559
 Dave Leikam
 40496
 N89DA reserved
  	  | Quote: | 	 		  http://www.matronics.com/contribution
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
		billderou(at)yahoo.com Guest
				 Posted: Tue Dec 18, 2007 9:04 am    Post subject: OAT probe location |
				I installed mine on the wing 18" outside the tip of the propeller in an inspection plate. Drilled a small hole and sealed with Proseal,  added a connector for servicing. No issues.
   Bill DeRouchey
   N939SB, flying
 David Maib <dmaib(at)mac.com> wrote:
   [quote]I have not installed mine yet, but plan to install it in the next to most outboard panel on the left wing.
   David Maib
   40559
   Dave Leikam
   40496
   N89DA reserved
 [quote]http://www.matronics.com/contribution  href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List  href="http://forums.matronics.com">http://forums.matronics.com
		mike(at)learningplanet.co Guest
				 Posted: Tue Dec 18, 2007 9:42 am    Post subject: OAT probe location |
				On my RV-9A I installed the OAT probe in the left inboard access panel. It works great and it is removable for inspections and whatever.
 There are a few pictures here:
 http://www.my9a.com/finish15.asp#090905
 Mike Schipper
 RV-10 #40576 - Fuse - www.rvten.com
  	  | Quote: | 	 		  0559
   Dave Leikam
   40496
   N89DA reserved
		GenGrumpy(at)aol.com Guest
				 Posted: Tue Dec 18, 2007 6:03 pm    Post subject: OAT probe location |
				Mine is in the left NACA vent, and it works great!
  grumpy
  N184JM
  DO NOT ARCHIVE
  In a message dated 12/18/2007 11:07:25 A.M. Central Standard Time,  billderou(at)yahoo.com writes:
   	  | Quote: | 	 		     I installed mine on the wing 18" outside the tip of the propeller in an    inspection plate. Drilled a small hole and sealed with Proseal,     added a connector for servicing. No issues.
    Bill DeRouchey
    N939SB, flying
     	  | Quote: | 	 		  I      have not installed mine yet, but plan to install it in the next to most      outboard panel on the left wing.
      David Maib
      40559
      Dave Leikam
      40496
      N89DA reserved
  	  | Quote: | 	 		  http://www.matronics.com/contribution  href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List  href="http://forums.matronics.com">http://forums.matronics.com
 ://www.matronics.com/contribution">http://www.matronics.com/contribution
 .matronics.com/">http://forums.matronics.com
 [/b] |
 See AOL's top rated recipes and easy ways to stay in shape for winter.
				 Posted: Tue Dec 18, 2007 8:10 pm    Post subject: OAT probe location |
				If you install the OAT anywhere inside the propeller diameter from front to tail it will be 10-15 deg F high. This is not important for the EIS (or other) engine monitor but it is very important for an EFIS or air data computer to calculate true airspeed correctly.
   Bill DeRouchey
   N939SB, flying
 GenGrumpy(at)aol.com wrote:
   [quote]      Mine is in the left NACA vent, and it works great!
   grumpy
   N184JM
   DO NOT ARCHIVE
   Bill DeRouchey
   N939SB, flying
   David Maib
   40559
   Dave Leikam
   40496
   N89DA reserved
  href="http://forums.matronics.com">http://forums.matronics.com        ://www.matronics.com/contribution">http://www.matronics.com/contribution  ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List  .matronics.com/">http://forums.matronics.com    [/b] |
		John Ackerman
  Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
				 Posted: Tue Dec 18, 2007 10:07 pm    Post subject: OAT probe location |
				not to mention the "i" word.John Ackerman 40458  Plugging along
 do not arcive
 On Dec 18, 2007, at 9:08 PM, Bill DeRouchey wrote:
 [quote]If you install the OAT anywhere inside the propeller diameter from front to tail it will be 10-15 deg F high. This is not important for the EIS (or other) engine monitor but it is very important for an EFIS or air data computer to calculate true airspeed correctly.
   Bill DeRouchey
   N939SB, flying
 GenGrumpy(at)aol.com (GenGrumpy(at)aol.com) wrote:
    	  | Quote: | 	 		        Mine is in the left NACA vent, and it works great!
   grumpy
   N184JM
   DO NOT ARCHIVE
   In a message dated 12/18/2007 11:07:25 A.M. Central Standard Time, billderou(at)yahoo.com (billderou(at)yahoo.com) writes:
   Bill DeRouchey
   N939SB, flying
   David Maib
   40559
   Dave Leikam
   40496
   N89DA reserved
  href="http://forums.matronics.com">http://forums.matronics.com     |
       See AOL's top rated recipes and  	  | Quote: |
 face="courier new,courier">http://www.matronics.com/contribution
  | 	  [b]
