		jswanson(at)jamadots.com Guest
				 Posted: Tue Dec 18, 2007 12:07 pm    Post subject: Cesnna split switch |
				Can someone help me find the information I need to  wire a split switch batt/
  alt into Z16 Rotax 912. I only have one buss.
  John S
  CH701 rotax
		nuckolls.bob(at)cox.net Guest
				 Posted: Wed Dec 19, 2007 5:58 am    Post subject: Cesnna split switch |
				At 02:50 PM 12/18/2007 -0500, you wrote:
  	  | Quote: | 	 		  Can someone help me find the information I need to wire a split switch batt/
 John S
 CH701 rotax
   John, did the answer to this not come though?
   A few days ago this exchange was posted
   to the List . . .
 At 11:43 AM 12/14/2007 -0500, you wrote:
 I need help in wiring a cessna style split Master Switch Batt/Alt
 into Z16 Rotax system. I'm using a single buss.
 Not sure how to answer this. The S700-2-10
 switch shown in Z-16 emulates the functions
 of a split-rocker switch. I.e. wiring diagrams
 for both switches is identical.
 You might check the panel of a Cessna but
 the switch as-mounted uses the right side
 rocker as the battery master and the left
 side as the alternator. A check with your
 ohmmeter would confirm that the battery side
 can be ON without having the alternator
 side ON too . . .
     Are there additional questions about this
     problem you're trying to solve?
				 Posted: Wed Dec 19, 2007 8:20 am    Post subject: Cesnna split switch |
				 Posted: Wed Dec 19, 2007 11:36 am    Post subject: Cesnna split switch |
				At 11:18 AM 12/19/2007 -0500, you wrote:
 <jswanson(at)jamadots.com>
				 Posted: Tue Dec 25, 2007 3:46 pm    Post subject: Cesnna split switch |
 John S
 CH701 rotax
    John sent me his split-rocker switch so that I could
    confirm my suppositions as to how it functioned.
    I've published a little 2-pager on interchangeability
    of the various toggle and rocker switch versions
    in the 'Connection's Z-figures.
    See:
 http://aeroelectric.com/articles/Progressive-Xfr_Split-Rocker_Switches.pdf
    John, I'll be mailing your switch back in the
    morning.
