PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Sun Dec 30, 2007 4:50 pm Post subject: 601XL - Making More Leg Room...? |
Has anyone moved the Rudder Pedals or the Rear Bearing Channel (6B8-3) forward so as to provide increased leg room on the 601XL?
Looking at the drawings, it appears there is little leeway to move the Rudder Pedals/bearings forward, hence the idea of moving the entire Rear Bearing Channel assembly forward.
The obvious limit on the forward side would be interference with the firewall. Immediately aft of the firewall are the Lower Engine Mount Fittings (6B6-5). Perhaps the rearmost bolt through the Lower Engine Mount Fittings could also pass through the Rear Bearing Channel and still leave sufficient room for full rudder pedal travel?
Has anyone done something similar? Any other ideas out there?
Patrick
XL/Corvair
N63PZ
psm(at)ATT.NET Guest
Posted: Sun Dec 30, 2007 5:33 pm Post subject: 601XL - Making More Leg Room...? |
Hi Patrick,
I would not suggest moving the channel forward. If anything you
might get more leg room by moving the channel backward toward the
spar carry-through.
You set the rudder pedal locations by adjusting the length of the tie
rods that go to the nose wheel control column. The pedals freely
rotate in their mounts, so the location of the mounts and the channel
don't play much of a role in the final pedal positions.
I would suggest mounting the rudder pedal support channel as shown in
the drawings.
Paul
XL fuselage
At 04:50 PM 12/30/2007, you wrote:
| Quote: | Has anyone moved the Rudder Pedals or the Rear Bearing Channel
rsteele(at)rjsit.com Guest
Posted: Sun Dec 30, 2007 6:20 pm Post subject: 601XL - Making More Leg Room...? |
I'm very interested in this problems also. I'm even considering
doing away with the toe breaks to get an extra inch or so of forward
movement. Has anybody else done this? The Tecnam I'm flying now has
a single handle in the center console that seems to work Ok, it just
different.
Ron
On Dec 30, 2007, at 7:50 PM, PatrickW wrote:
pedal travel?
Patrick
XL/Corvair
N63PZ
http://forums.matronics.com/viewtopic.php?p=155063#155063
bryanmmartin
Posted: Sun Dec 30, 2007 7:45 pm Post subject: 601XL - Making More Leg Room...? |
With nosewheel steering, you can probably get by just fine with a hand
brake. The toe brakes give a bit more control on a slippery runway
though.
On Dec 30, 2007, at 9:19 PM, Ronald Steele wrote:
has a single handle in the center console that seems to work Ok, it
just different.
Ron
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Trainnut01(at)aol.com Guest
Posted: Mon Dec 31, 2007 3:52 am Post subject: 601XL - Making More Leg Room...? |
Ron
I've been thinking about the single handle brake but I'm not far enough along to have to make a decision yet.
I have flown many Cherokees over the last forty years that were equipped just that way. We have several Challengers and a least one Weedhopper at our local strip that have Black Max brakes. They have a single motorcycle type lever on the stick. Also if you look close at photos of Van's RV12 prototype it appears to have a brake lever on the stick also. Since ZAC designs don't have castering nose wheels I don't really see why it wouldn't work.
Like I said I'm not there yet so I have plenty of time to think about it.
Carroll
See AOL's top rated recipes and easy ways to stay in shape for winter.
skyridersbn(at)yahoo.com Guest
Posted: Mon Dec 31, 2007 3:56 am Post subject: 601XL - Making More Leg Room...? |
I probably fly the same Tecnam you do with the center brake. I hate it. Its hard to get used to. The other thing I miss by having the center brake is the individual brake control over each wheel. It makes it difficult to do a sharp turn around when you can't hold pressure on just one brake - like the Cessna 150-152's I'm used to flying. I'm looking forward to having that individual wheel control back again.
ding(at)tbscc.com Guest
Posted: Wed Jan 02, 2008 5:10 pm Post subject: 601XL - Making More Leg Room...? |
Pat,
I've been late in reading the list lately, so I'm slow in responding
to your post. I'm a tall feller and find my knees in the dash panel in
nearly every plane I climb into. The factory 601 wasn't the worst, but still
too tight for optimal comfort. I very carefully measured, calculated, and
consulted Zenith about repositioning the entire rudder channell forward to
fit me better. To fully evaluate this, you must look at the intended neutral
rudder pedal position, which is more aft than you might think. I ultimately
moved the entire assembly forward 60mm (2 3/8"). I can now sit in the
cockpit, and all is well. I had to shave the rudder pedals slightly to clear
the firewall in the most extreme position, and you would never encounter
this position in flight, only while braking during taxi. At 2" forward, even
this minor mod. wouldn't be necessary. My floor pan was predrilled, so I
had to fill the unused holes with rivets. My firewall slots were cut as per
plans, and still fit the steering rods exactly. Zenith had no problem at
all with this change.
Lynn
Corry, PA 601XL / Corvair
| Quote: | Has anyone moved the Rudder Pedals or the Rear Bearing Channel (6B8-3)
Patrick
XL/Corvair
N63PZ
PatrickW
Posted: Thu Jan 03, 2008 4:45 am Post subject: Re: 601XL - Making More Leg Room...? |
Thanks Lynn. I'm thinking along the same lines as you.
I spoke with Zenith too. They mentioned that I'd have to fill in some pre-drilled rivet holes, but they didn't have a problem with it.
I'll do some measuring & positioning and see how things look as far as exactly how much forward to go on mine.
Pat
XL/Corvair
Posted: Thu Jan 03, 2008 8:34 am Post subject: 601XL - Making More Leg Room...? |
