		Dave Nixon
				 Posted: Mon Jan 14, 2008 1:51 pm    Post subject: Inspection Check-List |
				I went on both the FAA site and the Zenith site for help in this area.  The FAA (apparently) doesn't want you downloading Form 8000-38 because I couldn't get to it.  And I thought I was good at back dooring things. Guess not.  And a review of the Builder's area on the Zenith site does not yield a builder checklist for the 601 XL.  What am I missing here?   Dave Nixon
  CH 601 and Jabiru 3300
  92% Done with 85% To Go
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		bearup(at)ida.net Guest
		planecrazydld(at)Yahoo.co Guest
				 Posted: Mon Jan 14, 2008 2:45 pm    Post subject: Inspection Check-List |
				I posted it as an attachment a couple of days ago
 Dave Nixon <adnasap(at)bellsouth.net> wrote:  [quote]      v\:* {behavior:url (#default#vml);}      v\:* {   BEHAVIOR: url (#default#vml)  }        FLAVOR00-NONE-0000-0000-000000000000  4.0  ;            I went on both the FAA site and the Zenith site for help in this area.  The FAA (apparently) doesn't want you downloading Form 8000-38 because I couldn't get to it.  And I thought I was good at back dooring things. Guess not.  And       Be a better friend, newshound, and  [quote][b]
		planecrazydld(at)yahoo.co Guest
				 Posted: Mon Jan 14, 2008 3:09 pm    Post subject: Inspection Check-List |
				Thanks for the posting to the original document Stan. The attachment that I made is a Word file that has exactly the same contents as the form in the PDF but is not as fuzzy (and can be filled in as a text document).
 Stan Bearup <bearup(at)ida.net> wrote:  [quote]    v\:* {   BEHAVIOR: url (#default#vml)  }      v\:* {   BEHAVIOR: url (#default#vml)  }        FLAVOR00-NONE-0000-0000-000000000000  4.0  ;      Click on the link below to download FAA Form 8000-38 - FABRICATION ASSEMBLY OPERATION CHECKLIST
   Stan
				 Posted: Mon Jan 14, 2008 3:26 pm    Post subject: Inspection Check-List |
				Dave,
  I just opened your Word doc up and found I like it much more than the  pdf file version on the FAA site, and is now permanently saved on my computer.  Thanks for sharing it with us.
  Stan
  [quote]   ---
				 Posted: Mon Jan 14, 2008 4:55 pm    Post subject: Inspection Check-List |
				I did not generate it Stan. I found it a while back and saved it for exactly the same reason!
 Stan Bearup <bearup(at)ida.net> wrote:[quote]     Dave,
  Stan
  [quote]   ---
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Tue Jan 15, 2008 10:01 am    Post subject: Re: Inspection Check-List |
				Guys,
 Would a copy of the FAA form 8000-38 that Zenith filled out to establish that the kit meets the 51% rule be something that would be good to show the DAR or FAA when getting our planes inspected for an airworthiness certificate?
 Comments appreciated.
 Tim
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		bryanmmartin
				 Posted: Tue Jan 15, 2008 12:05 pm    Post subject: Inspection Check-List |
				The FAA maintains a list of kits that have been found to meet the 51%
 rule, the C601XL is already on that list so you shouldn't have to bother
 with this form.
 See: http://tinyurl.com/2fw7wb
 Tim Juhl wrote:
  Guys,
 Bryan Martin
 Zenith 601XL N61BM
 Ram Subaru, Stratus redrive
  _________________ --
Bryan Martin
do not archive. |
