		Dave(at)AirCraftersLLC.co Guest
				 Posted: Tue Feb 12, 2008 11:52 am    Post subject: SilPruf Window Installation (Here goes...) |
				The rear and door windows in N921AC are installed with an adhesive called
 SilPruf.  It's very thick (viscous) silicone material from GE.
 (http://kbam.geampod.com/KBAM/Reflection/Assets/10412_3.pdf).  SilPruf comes
 in several colors and is avialable from
 The advantages to this method over Weld On are that it leaves a nice looking
 trim ring around the exterior of the window, it prevents the cracking along
 the edge of the bond, and it would allow for the windows to be removed and
 replaced in the future without repainting the area around the window.  BUT
 it's a bit of work.
 We learned this technique from the GlaStar community.  It's a little
 involved and it takes several curing cycles, but the results are really
 nice.  AirLInk has a video describing the process:
 http://mall.igfarm.com/store/merchant.mv?Screen=PROD&Store_Code=airlinktech&
 Product_Code=101-0101-0000
 My description is a bit rushed and I may have left part of it out.  Please
 proofread it and let me know so we have a good record of the process.  It's
 a logical process and if something is missing I think you'll realize it.  I
 wish I had some pictures but I hope the video will help.  One pointer here:
 the video references a completely separate, alternative method using vinyl
 ester resin.  Vinyl ester will not bond well to the top or doors of the
 RV-10.  You could just substitute epoxy for vinyl ester if you decide the
 SilPruf is too much work.
 Please get in touch if I can clarify this.  I suspect there will be some
 questions.
 Here are the steps we followed.  I haven't watched the video lately so the
 order may be a little different:
 1)	Mask the outside of the window.  No sealant ever touches the outside
 surface.  Trim the window to the airframe so it has a 1/8" gap between the
 window and the OD of the joggle.
 2)	Mask the inside of the window except for the edge.  Leave an
 unmasked margin 1/16" wider than the edge of the joggle.  Apply another
 layer of thin masking tape (we used fine line tape from an autobody store)
 to the edge of the margin.  This layer will be removed before the material
 cures.
 3)	Prep the unmasked surface lightly with a cloth moistened with
 acetone to clean and degrease it.
 4)	Apply a very thin layer of SilPruf to the unmasked margin.  The
 purpose of this step is to create the cosmetic "mask" that is seen from the
 outside.  Remove the fine line tape.  Let the mask cure for 24 hours
 minimum.
 5)	While the mask is curing, lay out a bead about 18" long by 1/4"
 diameter of SilPruf on some wax paper.  It will be used later in the
 process.  It doesn't have to be particularly uniform-just a line of SilPruf.
 6)	Trial fit the window into the joggle.  Drill #40 cleco holes every
 2" into the bottom of the groove between the window and the OD of the
 joggle.
 7)	Make a bunch of wooden spacers out of inch-long of popsicle stick or
 similar.  Drill a #40 hole in the middle of each spacer.  Use the spacers
 under a cleco to clamp the window into the joggle.  At this point the window
 will be "below grade" of the outside skin.
  	Now cut the bead of SilPruf into thin wafers and shim the window out
 so it is at or slightly above grade.  Place one wafer approximately at each
 cleco under the cosmetic mask.  The wood strips will bridge from the fuse to
 the window, and the cleco should apply enough pressure to slightly compress
 each wafer.  You will vary the thickness of each wafer to get the window
 flush with the outer skin.  Prep the joggle, then glue the wafers to the
 joggle with SilPruf and let them cure.  They have to be firmly affixed so
 that they stay in place during the final installation.  If they slip around,
 the window will fall below grade and all the sealant will get squeezed out
 by the cleco pressure.
 9)	Mask the inside and outside of the fuselage and apply another fine
 line mask to the inside of the window.
 10)	  Apply the SilPruf to the joggle, all around the wafers.  Be
 careful not to break the wafers off.
 11)	  Put the window back in place and secure it with the clecos and
 wood strips.  Scoop as much as possible out of the groove between the
 window and the joggle.  Some material will remain under the wooden spacers.
 Those sections will be removed later.
 12)	  Remove the fine line mask from the inside.  Let the whole thing
 cure for at least 24 hours.
 13)	  Remove all the masking from the inside, and clean up any drips.
 If you catch them before they cure, that's even better.
 14)	  Remove the clecos and strips.  Remove the SilPruf from the area
 under the strips with a pick, knife, chisel, whatever works.  There should
 be a nice uniform groove between the edge of the window and the airframe.
 Kind of a little moat.
 15)	  Fast forward to final painting of the plane.  Paint the body color
 right up to the edge of the groove, then paint over that with a very thin
 line of glossy paint that matches the color of the SilPruf.  Ours is black,
 about 1/16" to 1/8" outboard of the OD of the joggle.
 16)	  Then mask halfway onto the glossy paint and the entire plastic
 outer surface of the window.  Apply a bead of SilPruf into the groove to
 fill it up.  Smooth it up with a squeegee or your favorite technique, then
 remove all the masking tape before the SilPruf cures.
 That should do it.  Fire away.
 Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA
 831-722-9141
 831-750-0284 CL
 www.AirCraftersLLC.com
  |  | - The Matronics RV10-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Tim_Lewis(at)msm.umr.edu Guest
				 Posted: Tue Feb 12, 2008 3:15 pm    Post subject: SilPruf Window Installation (Here goes...) |
				Dave,
 Have you compared the holding power of SilPruf to that of WeldOn?
 Tim
 Tim Lewis -- HEF (Manassas, VA)
 RV-6A N47TD -- 1000 hrs
 RV-10 #40059 under construction
  it's a bit of work.
  questions.
  cures.
  minimum.
  joggle.
  Dave Saylor
  AirCrafters LLC
  140 Aviation Way
  Watsonville, CA
  831-722-9141
  831-750-0284 CL
				 Posted: Tue Feb 12, 2008 3:59 pm    Post subject: SilPruf Window Installation (Here goes...) |
				Nope.  But I have seen it work very well in many other applications besides
 this one.  The numbers say it would take a catastrophe to break the
 bond--thousands of pounds loading against the window--at which point the
 strength of the bond becomes a moot point.  So, no, I haven't checked, but I
 still I trust the application.
 Also, it's a bit of an apples/oranges comparison because the SilPruf
 stretches so much further before breaking.  That's what makes it nice for
 preventing the hairline cracks.
 Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA
 831-722-9141
 831-750-0284 CL
		kearney(at)shaw.ca Guest
				 Posted: Wed Feb 13, 2008 7:20 am    Post subject: SilPruf Window Installation (Here goes...) |
				Dave
 Many thanks for such a detailed post. Where I live it can go from -40F in
 winter to +90F in summer. Thermal expansion of joints around windows etc is
 an issue that I have been concerned about.
 On the strength of your recommendation, I have ordered the video and hope to
 put it to good use.
 Les Kearney
 #40643
 C-GCWZ (Reserved)
		patrick.pulis(at)seagas.c Guest
				 Posted: Thu Feb 14, 2008 5:01 pm    Post subject: SilPruf Window Installation (Here goes...) |
				Les, once you view the video, could you please post a overview of the
 installation process and your thoughts please?
 Patrick Pulis
 #40299  VH-XPP
 Adelaide, South Australia
 DO NOT ARCHIVE
				 Posted: Thu Feb 14, 2008 8:48 pm    Post subject: SilPruf Window Installation (Here goes...) |
				Patrick
 Hi from the northern end of the Commonwealth!
 I know next to nothing about composites, but am trying to learn. I'll
 certainly pass on comments etc once I have seen the video.
 Cheers
 Les Kearney
 #450643
 C-GXWZ (reserved)
