Posted: Tue Feb 05, 2008 7:35 am Post subject: Duckworks with tip tanks |
Does anybody who is using HID lights in the leading edge have tip tanks? Is there any concern about a fuel leak causing problems with electricity in that area? There is power in the wingtip anyway, and at the heated pitot anyway, and the wings are not sealed anyway, but just wanted to see what opinions there were out there on this issue.
Does anybody know what Vic had for landing lights? I know he had the SafeAir tip tanks.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
Tim Olson
Posted: Tue Feb 05, 2008 8:42 am Post subject: Duckworks with tip tanks |
Vic has the duckworks kit...
http://www.myrv10.com/miscphotos/VicsRV10/plane/IMG_4217.html
Jesse Saint wrote:
| Quote: | Does anybody who is using HID lights in the leading edge have tip tanks?
SafeAir tip tanks.
Jesse Saint
jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
Cell: 352-427-0285
Fax: 815-377-3694
patrick.pulis(at)seagas.c Guest
Posted: Tue Feb 05, 2008 2:49 pm Post subject: Duckworks with tip tanks |
ron.mcgann(at)baesystems. Guest
Posted: Tue Feb 05, 2008 4:24 pm Post subject: Duckworks with tip tanks |
Patrick is having problems with his IS mafia - their filtering process
is a little 'aggressive' shall we say. He asked me to post this:
Hi there Jesse,
I'm in the process of installing HID lights into my outboard leading
edges and I'm also plumbing aluminium fuel line through the leading edge
ribs to enable connection of the tip tank in each wing to the outboard
side of the main fuel tank.
My wing tips will be converted into fuel proofed integral tip tanks
(giving approximately 28 litres/7.5 USG either side), by Flymore
(http://www.flymore.com.au/), a local RV and experimental aircraft
construction and modification company operated by Jon Johanson
(http://www.vansaircraft.com/public/jj-persn.htm). They have
significant experience in modifying RV's and extending their range,
which was necessitated when Jon decided do his record breaking around
the world and Antarctic flights, requiring conversion of his RV-4 into a
wholly 'wet wing'.
I will be installing a fuel isolation valve (12V solenoid valve designed
for fuel applications) adjacent to the connection point to the wing tip
tank and have installed an access panel (Vans access panels) on the
under side of the outboard leading edge to enable access to the solenoid
valve and connections and another access panel inboard to enable access
to the connection point to the outboard side of the main tank.
Conversion of the Van's tips into fuel tanks includes a tunnel to enable
the electrics for the lights in the tip to be run separately from any
fuel and away from any HID lights in the leading edge. To date this
conversion has been highly successful and has been applied to RV's
ranging from the 4 to the 10 with no reported fuel leaks or operational
faults.
If anyone would like some photos of a friends RV-7 which features this
modification please drop me a line (patrick.pulis(at)seagas.com.au) and
I'll send them to you separately off-line. I have discussed the tip
tank modification (inclusive of strengthening the attach points) with
some local aeronautical engineers and they have given it the tick of
approval. Obviously all up weight must be kept in check and fuel from
the tips should be used first on longer flights.
I hope this helps you out.
Patrick Pulis
#40299 VH-XPP
Adelaide, South Australia
Posted: Tue Feb 05, 2008 5:57 pm Post subject: Duckworks with tip tanks |
Patrick and others,
This is exactly the type of feedback I was hoping for. Basically, no
"Oh my goodness I can't believe you would even consider that a viable
option" comments. Thanks.
do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Hi there Jesse,
edge
into a
wholly 'wet wing'.
designed
tip
solenoid
access
enable
operational
faults.
Patrick Pulis
#40299 VH-XPP
dasduck(at)comcast.net Guest
Posted: Wed Feb 13, 2008 8:58 am Post subject: Duckworks with tip tanks |
Jesse,
to increase clearance, you could move the lights one bay inboard from the tip.
Don
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Tuesday, February 05, 2008 7:27 AM
Subject: Duckworks with tip tanks
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
lbgjb10
