Posted: Thu Mar 06, 2008 3:41 am Post subject: axle fitting |
Thanks Larry. I think I do have the thin ones. I also have some bent gear legs that came with the plane-3?- that maybe could be straightened. They are aluminum. Right now, the plane has one bent leg. The other side has a much stiffer leg- the taper starts further down. I have new legs of the lighter type that will be installed. I asked TNK about putting steel legs on, and they advised me to stay original because a hard landing could transmit the shock up to the main frame- maybe causing very expensive problems. Very good advice from TNK, as I am very inexperienced. Like 40 years out of practice. When in doubt, go with the factory advice. Yes, they do want to sell parts- but not unless they have to. I have to check the "A" frame for cracks while I'm in there. There is also a skid plate on the nose, so I think one of the former users was in the habit of rough landings.
Bill Sullivan
old FS
l
ElleryWeld(at)aol.com Guest
Posted: Thu Mar 06, 2008 3:53 am Post subject: axle fitting |
My Old Firestar is going to be listed on Barnstormers today as the guy that has it in MN has a problem with motion sickness and has to give up his flying
You can get a good deal on it with trailer and skis
Ellery in Maine
In a message dated 3/6/2008 6:41:57 A.M. Eastern Standard Time, williamtsullivan(at)att.net writes:
| Quote: | Thanks Larry. I think I do have the thin ones. I also have some bent gear legs that came with the plane-3?- that maybe could be straightened. They are aluminum. Right now, the plane has one bent leg. The other side has a much stiffer leg- the taper starts further down. I have new legs of the lighter type that will be installed. I asked TNK about putting steel legs on, and they advised me to stay original because a hard landing could transmit the shock up to the main frame- maybe causing very expensive problems. Very good advice from TNK, as I am very inexperienced. Like 40 years out of practice. When in doubt, go with the factory advice. Yes, they do want to sell parts- but not unless they have to. I have to check the "A" frame for cracks while I'm in there. There is also a skid plate on the nose, so I think one of the former users was in the habit of rough landings.
Bill Sullivan
old FS
l
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
