		kearney(at)shaw.ca Guest
				 Posted: Sat May 31, 2008 5:37 am    Post subject: Wiring Questions |
				Hi
 I am in the process of planning my wiring and have a couple of questions for the list.
 First, I am planning on using Infinity stick grips. When wiring these grips through the control stick tube, how does one protect the wires from undue stress when the control stick is moved?
 Are there any rules of thumb that can be used when deciding what sizes of shrink wrap to be used in an applications – in particular what arte the most common sizes that are used. I would like to order some from ACS but have no idea as to quantities and sizes I should get.
 Lastly, what is the difference between a 4 indent and a 8 indent D-Sub crimper? Which is preferable?
 Inquiring minds need to know….
 Les Kearney
 #40643
		dlm46007(at)cox.net Guest
				 Posted: Sat May 31, 2008 6:06 am    Post subject: Wiring Questions |
				try www.mcmaster.com for spiral wrap. They also have wraps that will take
 under cowl temps
 s easy-to-use spiral wrap installs
 like tape around bundles of wire, tube, and hose.
 Wrap also permits access anywhere along its length.
 Polyethylene—Comes on a spool. Temperature range
 is –76° to +190° F. Sleeving is abrasion and solvent resistant
 and is UL recognized. To Order : Please specify length
 from those listed in the table. Clear wraps are for indoor
 use. Ultraviolet-resistant wrap is black and ultraviolet-stabilized
 for outdoor use in direct sunlight. Choose-a-color
 wraps are for indoor use. To Order : Please specify blue,
 green, orange, red, white, or yellow.
  1/2 to 5 for self-extinguishing nylon sleeving. Lengths are not
 continuous.
 OD
 Bundle Dia.
 Range
 CHOOSE-A-COLOR POLYETHYLENE SELF-EXTINGUISHING NYLON
 Wall
 Thick.
 Each Wall
 Thick.
 Each
 10 ft. 25 ft. 50 ft. 100 ft. 10 ft. 25 ft. 50 ft. 100 ft.
 1 / 8 . . 1 / 16 to 1 / 2 . . 0.032 . . 7378K41 . . . . . . . . . $1.99
 $4.44 $8.11 $14.77 0.015 . . . . . . . . . 7432K56 . . . . . . . . . . .
		wcurtis(at)nerv10.com Guest
				 Posted: Sat May 31, 2008 6:43 am    Post subject: Wiring Questions |
				shrink wrap
 One each of: 1/4'', 3/8'', 1/2'', 3/4'', 1''  48" long
 http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=9639
 William
 http://nerv10.com/wcurtis/
		roadmaps
				 Posted: Sun Jun 01, 2008 4:29 am    Post subject: Wiring Questions |
				I used the Case Mod  sleeving on my stick grip wires. Also used it on several other cables on  the plane - like wing connections. One kit pretty much took care of everything I  needed. It has several sizes. It is tough stuff. You cut (melt) it with a  soldering iron and put heat shrink on the ends (some heat shrink comes with the  kit). Here is the link:
 http://www.xoxide.com/techflex6.html
   John Testement
 jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
 40321
  Richmond, VA
 Painting and final assembly
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les  Kearney
 Sent: Saturday, May 31, 2008 9:35 AM
 To:  rv10-list(at)matronics.com
 Subject: Wiring  Questions
 Hi
 Les  Kearney
 #40643
  | 	  No virus found in this incoming message.  Checked by AVG. Version: 7.5.524 / Virus  Database: 269.24.4/1475 - Release Date: 5/30/2008 2:53 PM
   Checked by AVG.
  5/31/2008 12:25 PM
				 Posted: Sun Jun 01, 2008 7:29 pm    Post subject: Wiring Questions |
				Hi John
 Thanks for the info. Now that I know what to look for, I was able to find it locally.
 Cheers
 Les
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement
  Sent: June-01-08 6:26 AM
  Subject: RE: Wiring Questions
 John Testement
  40321
 Richmond,  VA
 Hi
 Les Kearney
 #40643   	  | Quote: | 	 		  |   href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c |
  Checked by AVG.
  5/31/2008 12:25 PM  0123456789 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  0 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  1 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  2 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  3 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  4
