heat transfer compound
williamtsullivan(at)att.n
PostPosted: Mon Jun 02, 2008 8:32 am    Post subject: heat transfer compound Reply with quote
Do you have to use a heat transfer compound on plugs in a 447?
Bill Sullivan
Kolb Firestar/447
Windsor Locks, Ct.
Roger Lee
PostPosted: Mon Jun 02, 2008 11:35 am    Post subject: Re: heat transfer compound Reply with quote
The 2 strokes do not get any paste, lube or anti-seize at all. They are supposed to be a dry thread and torqued because the heads on the 2 strokes are softer aluminum (different materials than the 4 strokes) and can be damaged with improper torque. This can happen whether they are dry if you use to much torque, but more susceptible if lubricated.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
imap8ntr(at)cox.net
PostPosted: Mon Jun 02, 2008 12:42 pm    Post subject: heat transfer compound Reply with quote
Roger
On my 582 the US Dealer/Distributor had me put antiseize on the sparkplugs
(silver colored antiseize.)
Ivan
Roger Lee
PostPosted: Mon Jun 02, 2008 3:54 pm    Post subject: Re: heat transfer compound Reply with quote
Hi Ivan,
I went back through all the 2 stroke manuals and it doesn't say anything about the use of anti-seize on 2 stroke plugs, but it is taught not to use anything on 2 stroke threads in the Rotax classes. If the manual doesn't say use it there must be a reason for it.
It does say to torque them on a cold engine only. Remember the heads are aluminum and the plug threads are steel. No gorilla arms when tightening plugs.
The maint. manual says to torque the plugs on a cold engine to 238 in/lbs or 19.8 ft/lbs. page 11-4 sec. 11.8
The installation manual says to torque the plugs with a CHT sensor ring in place to 133 in/lbs. or 11 ft/lbs pg 20-1 fig. 49
This is quite a difference. Might help to call Lockwood for a clarification.
Roger Lee
Tucson, Az.
Cell 520-349-7056
imap8ntr(at)cox.net
PostPosted: Mon Jun 02, 2008 4:32 pm    Post subject: heat transfer compound Reply with quote
Thanks for the info. Kemmeries Aviation, the US importer for Air Creation
Trikes which all come with Rotax engines, gave me this info. I will double
check it this month.
Ivan
Float Flyr
PostPosted: Mon Jun 02, 2008 4:46 pm    Post subject: heat transfer compound Reply with quote
I've been criticized for this before but I always torque the plugs on my 582 to 220 in.lb. intentionally. I tend to check my plugs quite often (5-10hr) and have never had a problem with the lower torque. I do check my torque wrench annually for calibration at that torque. I also never use anything on the threads of my plugs except a soft clean cloth. Whenever I remove all the plugs I will put a clean shop towel over the plug openings to keep any grit from getting into the combustion chambers.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Roger Lee
PostPosted: Tue Jun 03, 2008 11:52 am    Post subject: Re: heat transfer compound Reply with quote
Hi Noel,
I don't see any thing to criticize. You torque the plugs within 1 ft/lb. Not a big deal since many don't torque them at all.
Roger Lee
Tucson, Az.
Cell 520-349-7056
Float Flyr
PostPosted: Tue Jun 03, 2008 4:31 pm    Post subject: heat transfer compound Reply with quote
I'm a bit anal about torque and using a calibrated wrench. I have been
criticized for doing the lower torque but I do it for two reasons. 1. I
pull my plugs a lot... I never really trust the EGTs to do more than give me
a trend. Plugs will always tell the whole story. 2. I feel the 20 in. Lb.
will create less stretching of the heads. I've been torquing plugs into
outboard engines, snowmobiles etc.. for more years than I like to think
about and I've yet to strip a thread.. I've also yet to lose a plug from
having it too loose.
The important thing is consistency. You can only get that if you use a
torque wrench or for the real small stuff a torque meter.
Thanks for the reply Roger
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
