		hurstkr(at)redzone.com.au Guest
				 Posted: Mon Nov 17, 2008 3:55 am    Post subject: Elevator Trim |
				Just wondering if anybody has installed the trim wheel available at
  www.PerihelionDesign.com/moreproducts.htm  second item down the page.
 If so, would be interested to know how you have found it.
 This device turns the electric MAC elevator trim from a time based control
 to a positional control like in Cessnas etc.
 Cheers
 Kingsley in Oz
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Mon Nov 17, 2008 4:12 am    Post subject: Elevator Trim |
				Kingsley Hurst wrote:
  <hurstkr(at)redzone.com.au>
  control to a positional control like in Cessnas etc.
  Cheers
  Kingsley in Oz
 Sounds like a very good plan,Kingsley. The MAC/Europa trim control is
 very fierce.
 Graham
				 Posted: Mon Nov 17, 2008 4:35 am    Post subject: Elevator Trim |
				 	  | Quote: | 	 		   Sounds like a very good plan,Kingsley. The MAC/Europa trim control is very
  fierce.
  Graham
 Yes Graham, it reads good but I don't yet know the physical size of it or
 it's cost.
 I would prefer the wheel to the standard set-up not that I am saying there
 is anything wrong with the latter. . . I already have it installed !
 Hope you're keeping well Ole mate!
 Kingsley
		paul.the.aviator(at)gmail Guest
				 Posted: Mon Nov 17, 2008 5:04 am    Post subject: Elevator Trim |
				Hi Kingsley,
 I can echo Grahams comment about the trim, but I approached the
 problem a little differently.  Matt Dralle, the guy who runs this
 forum sells a small device that allows you to adjust the speed of the
 MAC servo.  It works really nicely and I can recommend it.
 Regards,  Paul
		rparigor(at)suffolk.lib.n Guest
				 Posted: Mon Nov 17, 2008 9:47 am    Post subject: Elevator Trim |
				Hi Kingsley
 Here is another interesting item that would probably work on a Europa:
 http://www.steinair.com/trim.htm
 Ron Parigoris
		frans(at)paardnatuurlijk. Guest
		malannx(at)bigpond.com Guest
				 Posted: Tue Nov 18, 2008 3:37 pm    Post subject: Elevator Trim |
  	  | Quote: | 	 		   <hurstkr(at)redzone.com.au (hurstkr(at)redzone.com.au)>
  Cheers
   Kingsley in Oz
  I would endorse the 3rd product down  which I believe is in the trim wheel product.
  I have one on my Esqual and the finesse  of control is brilliant. It will adjust the trim that finely that you can hardly  see the trim tab move. Before fitting it was nearly impossible to set the trim  accurately as the motor would overrun past the required setting. I also use the  last products on the page to control heater vents-again brilliant.
                Malcolm Ferguson  Esqual VH-ECO
