AirMike
Posted: Mon Jan 05, 2009 4:29 am Post subject: Spread the load CSK washers on wheel pants |
Has anyone use the "hat" style CSK washers on the wheel pants or on other fiberglass parts to prevent the fiberglass from cracking. I remember that I had a bunch of them on my Piper to prevent the cheap ABS from cracking on the pants?
If you have used them would you consider them to be effective at spreading the load and preventing cracking?
Spruce sell them pretty cheap
_________________ See you OSH '18
Q/B - sold. |
Posted: Mon Jan 05, 2009 5:50 am Post subject: Spread the load CSK washers on wheel pants |
Piper liked them for a good reason ..... they cover up a multitude of
sins ..... mostly wide tolerances in the ABS parts ..... and they look
good. We (the collective experimental plane builder 'we') take a lot of
time to make our removable fasteners fit really nice so I'm not sure
that I'd wallow out the holes to install the finish washers. I would,
however use them for the same reason that Piper does ..... after hard
use has already wallowed out the holes.
Linn
AirMike wrote:
OSH '08 or Bust (busted) be there in "09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p 22941#222941
Dave(at)AirCraftersLLC.co Guest
Posted: Mon Jan 05, 2009 11:56 am Post subject: Spread the load CSK washers on wheel pants |
We use them on everything we can. I didn't put the on my -10 wingtips since
there are so many screws there already, but just about everywhere else.
Especially the wheel pants and the four screws at the front of the cowl.
FWIW, I like to use #10 screws up there too. They seem to hold up better.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
ron.mcgann(at)baesystems. Guest
Posted: Mon Jan 05, 2009 1:39 pm Post subject: Spread the load CSK washers on wheel pants |
Mike,
I was just reinstalling the front wheel pant the other day and noticed
that the pant sidewall at the bracket attach screws was particularly
thin. With the pant countersunk to take the -8 screw head, there is
very little material to support the head. Given the amount of vibration
the pant will be subject to on our not so smooth strips, I will be using
Tinnerman washers to reinforce the attach points on the pants.
Cheers,
-187, fiddly bits and paperwork.
