Vans Manifold pressure fitting replacement
egohr1
PostPosted: Fri Jan 16, 2009 4:15 am    Post subject: Vans Manifold pressure fitting replacement Reply with quote
FYI.
McMaster carr part number 5058K243 ALUMINUM SINGLE-BARBED TUBE FITTINGS, ADAPTER FOR 1/4" TUBE ID X 10-32 UNF MALE, BLUE
This will replace the nylon fitting sent with vans FWF kit for connection to a AFS or other system.
eric gohr
EGOHR86@alumni.carnegiemellon.edu
indigoonlatigo(at)msn.com
PostPosted: Mon Jan 19, 2009 10:52 am    Post subject: Vans Manifold pressure fitting replacement Reply with quote
What is wrong with the nylon one van's sends?? Doesn't work with AFS or is it just the material it is made of.
John G
Subject: Vans Manifold pressure fitting replacement
Date: Fri C 16 Jan 2009 04:15:22 -0800
--> RV10-List message posted by: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu>
FYI.
McMaster carr part number 5058K243 ALUMINUM SINGLE-BARBED TUBE FITTINGS C ADAPTER FOR 1/4" TUBE ID X 10-32 UNF MALE C BLUE
eric gohr
http://forums.matronics.com/viewtopic.php?p=225053#225053
[b]&gt==
ricksked(at)embarqmail.co
PostPosted: Mon Jan 19, 2009 11:11 am    Post subject: Vans Manifold pressure fitting replacement Reply with quote
Hose barb on the. Afs sensor is 1/4 inch vans is 1/8
Sent via BlackBerry by AT&T
Date: Mon, 19 Jan 2009 10:51:37 -0800
To: RV 10 group<rv10-list(at)matronics.com>
Subject: RE: RV10-List: Vans Manifold pressure fitting replacement
What is wrong with the nylon one van's sends?? Doesn't work with AFS or is = it just the material it is made of.
&nbsp=3B
John G
&gt=3B Subject: RV10-List: Vans Manifold pressure fitting rep= lacement
&gt=3B From: EGOHR86(at)alumni.carnegiemellon.edu
&gt=3B Date: = Fri=2C 16 Jan 2009 04:15:22 -0800
&gt=3B To: rv10-list(at)matronics.com
= &gt=3B
&gt=3B --&gt=3B RV10-List message posted by: "egohr1" &lt=3BEGOH= R86(at)alumni.carnegiemellon.edu&gt=3B
&gt=3B
&gt=3B FYI.
&gt=3B Mc= Master carr part number 5058K243 ALUMINUM SINGLE-BARBED TUBE FITTINGS=2C AD= APTER FOR 1/4" TUBE ID X 10-32 UNF MALE=2C BLUE
&gt=3B
&gt=3B This w= ill replace the nylon fitting sent with vans FWF kit for connection to a AF= S or other system.
&gt=3B
&gt=3B --------
&gt=3B eric gohr
&gt= =3B EGOHR86(at)alumni.carnegiemellon.edu
&gt=3B
&gt=3B
&gt=3B
&= gt=3B
&gt=3B Read this topic online here:
&gt=3B
&gt=3B http://f= orums.matronics.com/viewtopic.php?p=3D225053#225053
&gt=3B
&gt=3B &gt= =3D=3D
&gt=3B
&gt=3B
&gt=3B
_-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - List Contribution Web Site - _-=3D Thank you for your generous support! _-=3D -Matt Dralle, List Admin. _-=3D --> http://www.matronics.com/contribution _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
indigoonlatigo(at)MSN.COM
PostPosted: Mon Jan 19, 2009 11:35 am    Post subject: Vans Manifold pressure fitting replacement Reply with quote
Thanks C I'll order this now and I should need it in a few days. Really appreciate it!!!
John
Subject: Re: Vans Manifold pressure fitting replacement
Date: Mon C 19 Jan 2009 19:09:27 +0000
.ExternalClass .EC_hmmessage P {;} .ExternalClass body.EC_hmmessage {font-size:10pt=3B font-family:Verdana;} Hose barb on the. Afs sensor is 1/4 inch vans is 1/8
Date: Mon C 19 Jan 2009 10:51:37 -0800
Subject: RE: Vans Manifold pressure fitting replacement
 =3B
John G
=3B Subject: Vans Manifold pressure fitting rep= lacement
= >=3B
=3B -->=3B RV10-List message posted by: "egohr1" <=3BEGOH= R86(at)alumni.carnegiemellon.edu>=3B
=3B
=3B FYI.
=3B
=3B
=3B --------
=3B eric gohr
=3B
=3B
=3B
&= gt=3B
=3B
=3B
=3B
= =3D=3D
=3B
=3B
=3B
¦·›~‰í² CÞÙÊ%¢½4ÓM4}§r‹«‰êç{(º¸ž­8^E]t.+-f¢”Z+ºe CzØ^1«k¢xœ°¸¬´Wš¶êÞ°Ö¯Š­¢»hnº0±ëazf§È¸¬¶ëb–+bzË.r¬.+-RÒ¹»®*mЉÀ­Èb½äžj·!Œ'–†�ì6²º0±à¡jÑ(at)(at)øh¶‹!j·š�Ù®r®r¨­æ¡­çá¶Úÿ 0™«k¢xœ±Ê&ü֝Э¢´U×Bâ²Øm¶Ÿÿà &jÚèž' Cr‰¿5«â�«h­uи¬·öŒ4N4€’X(at)E9 I&¦z Þj×(ž×§µ©l¡«ÚŠV›•ëâjØ^YæÅ¢»¦±¨kyøm¶Ÿÿ~ŠîšÉš¶º'‰Ë¢hm¶Ÿÿ~ŠîšÉš¶º'‰Ë¢oÚ.+- ‰í®&î¶*'YæÒŠ×“…©äÊ‹Ÿ¢¼¨º¸�êèºË.¦š+´Æ­´:Ú–W‹ŠË(at)vh§jÞ~m§ÿðà š¶º'‰Ë¢oÜ¢{k‰»­Š‰á¶Úÿ 0™«k¢xœ±Ê&ýÊ'¶¸›ºØ¨Ÿö¿o÷èžßé­ïÛ¡Ü¿†Ù¥ [quote][b]
