		AirMike
				 Posted: Tue Feb 17, 2009 4:55 am    Post subject: Tie rods on baffles and chafe |
				I am trying to install the tie rods on the bottom of the engine and am getting interference from the aluminum oil lines down there. Is there an anti-chafe material that I can use there or do I have to cut new oil lines to avoid any contact with the tie rods. It seems like kind of a foolish system for controlling the baffles. Why not just screw tabs on each cylinder?
  _________________ See you OSH '18
Q/B - sold. |
		dlm46007(at)cox.net Guest
				 Posted: Tue Feb 17, 2009 5:17 am    Post subject: Tie rods on baffles and chafe |
				High temp spital wrap from McMaster Carr
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Tue Feb 17, 2009 8:01 am    Post subject: Re: Tie rods on baffles and chafe |
				I don't have the plans here but if I remember correctly, the plans calls for cutting some of the provided clear plastic tubing.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
		Deems Davis
				 Posted: Tue Feb 17, 2009 8:39 am    Post subject: Tie rods on baffles and chafe |
				Slip a length of tubing over the tie rods.  The lower parts of the
 baffles don't have to be perfect .... tighten the nuts  to snug the
 aluminum up but not stretch the tab.  Also, use washers under the nuts
 (bigger is better) and Locktite one nut so that you can remove the other
 nut and slip the tierod out.
 Linn
 AirMike wrote:
  OSH '08 or Bust (busted) be there in "09
  Q/B Kit - wiring and FWF
  http://forums.matronics.com/viewtopic.php?p 30636#230636
		AirMike
				 Posted: Tue Feb 17, 2009 8:10 pm    Post subject: Tie rods on baffles and chafe |
				Note that the build manual seems to recommend that you use the supplied plastic pipe (it only says something about 1/4" tube. )
 The supplied tube that I see is Parker Parflex N 1/4" x .035 tube.
 This tubing is only good to 193 degrees if it is the Nylon tube shown in Parker's manual.
 Correct me if I am wrong......please
Q/B - sold. |
		Dave(at)AirCraftersLLC.co Guest
				 Posted: Tue Feb 17, 2009 8:54 pm    Post subject: Tie rods on baffles and chafe |
				Mine melted like wax.  But somehow the tie rod doesn't rub the oil lines, so
 the tubing isn't needed in my case.  But those lines are pretty delicate and
 if anything is close to touching them, then you'll have to do something to
 prevent contact..
 Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA
 831-722-9141
 831-750-0284 CL
 www.AirCraftersLLC.com
