GrummanDude
Posted: Thu Mar 12, 2009 9:08 am Post subject: Horizontal braces |
I found bent vertical braces in the area in contact with the stub spar that goes through the fuselage on a Tiger with no other noted damage to anything. Â I cannot imaging how that vertical brace can be bent unless the horizontal twisted so much that it deformed the vertical braces. Â
Just a heads up
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
az_gila
Posted: Thu Mar 12, 2009 9:53 am Post subject: Horizontal braces |
Could it be a "tail skid touch" landing that
forced the aft fuselage up a little, and the mass
of the horizontal resists it and causes the buckle in the vertical angles?
The damage to mine was similar to your
description - previous owner landings though...:^)
gil A
PS ..can we attach pictures now?
At 10:06 AM 3/12/2009, you wrote:
| Quote: | I found bent vertical braces in the area in
Just a heads up
grumpyparts
Posted: Thu Mar 12, 2009 2:05 pm Post subject: Re: Horizontal braces |
Yes you can put pictures up on the Matronics Email Lists Forum Index -> TeamGrumman-List under the same topic name.
Discover
Posted: Thu Mar 12, 2009 3:33 pm Post subject: Horizontal braces |
Not the vertical but I saw the horizontal brace cracked.
A fellow Tiger owner on my field was pushing his Tiger into the T-hangar and struck the hangar with the elevator. He came and got me to see the damage. The right stabilizer was seperated from the fuselage about an inch leaving a gap at the leading edge root where the plastic root fillet usually is up against the fuselage. I held the right stabilizer at the tip and put a little forward pressure on it and heard a big pop. The gap was now gone. Further inspection by the A&P found the top lip of the spar cracked and that is where you could locate the popping sound...
