vhicy(at)bigpond.com Guest
Posted: Mon Apr 13, 2009 8:07 pm Post subject: Door Closed switches or not |
I always get the passengers in then I close the passenger door from outside to make sure it is shut properly. Then with normal TMPFISH check I push the front and back of door to make sure its shut and try and pull the handle up without pushing button. I have after marked door guides and not sure if they make things better or not. I also check the door handles when I do fuel radio check each 30 min. They have not moved yet.
One should not need lights buzzers etc for a door it isnt a 747.
Just another opinion ofcourse and I am no expert. Maybe somone can design a door that swivels from the front?
Chris
AirMike
Posted: Tue Apr 14, 2009 7:53 pm Post subject: Door Closed switches or not |
Amen: The 10 should have front hinged doors like Piper - muuuccch safer
_________________ See you OSH '18
Q/B - sold. |
