| frans(at)paardnatuurlijk. Guest
				|  Posted: Fri Apr 17, 2009 9:32 am    Post subject: Trike nose wheel castor spindle and yoke failure.    Europa |   |
				| hi Karl,
  	  | Quote: |  	  | Sorry to butt in again, but you say that ACS don't have a matching wall thickness spindle.
 They have exactly the same, I gave you the part number.
 The part number you gave has a smaller wall thickness than what I
 measured on the original. Maybe Europa changed the tubing size somewhat?
 My solution is to order 03-04800 and 03-06600, which will give me a
 combined wall thickness of .240
 The largest wall thickness of 1" steel tube offered by ACS (your part
 number) is .188, and that is smaller than what I measured. I measured an
 I.D. of .5
 Given the fact that some people experienced problems with a bending
 nosewheel spindle, I'd rather stick to the original wall thickness.
 Also, an inner I.D. of .5 allso provides a snug fit of the AN8-bolt to
 be inserted.
 Has anyone else measured the wall thickness and/or inner diameter of the
 nosewheel spindle? Maybe there are two versions supplied? Which explains
 why some people experience problems and some others not (bad landings
 excluded of course!
  ) Another difference I experienced is that my nosehweel spindle is not just held by the famous roll pin, but also
 "glued" with something (probably locktite).
 Of course I can't exclude the possibility that I didn't measure
 correctly. In that case, I will just get a stronger nose wheel spindle
 than original.
 Frans Veldman
