		shinden33
				 Posted: Sat May 09, 2009 4:44 pm    Post subject: After market Tach |
				On that note, anyone use an aftermarket tach?  Any recommendations?
 S
				 Posted: Sat May 09, 2009 7:51 pm    Post subject: After market Tach |
				Look at the Dynon EMS system for one. JPI also has one with a bunch of bells
 and whistles. It reports as rpm though not as % rpm. I have talked to tech
 support at Dynon about this. According to them, it is a simple software
 change but not enough people have asked for it for them feel it might be of
 benefit.
 Also check with West London Aeroclub in England. I thought I saw a tach
 drive generator on their website.
 But before you press off buying a new generator, have you looked to see if
 you have a broken wire in the sim plug? That is the most common cause for
 Tach Drive Generators to fail.
 Viperdoc
		pfstelwagon(at)earthlink. Guest
				 Posted: Sat May 09, 2009 10:17 pm    Post subject: After market Tach |
				Check out the HORIZON tach.  They can set it up for what ever you want.
 Fran  N23021
				 Posted: Sun May 10, 2009 5:28 am    Post subject: After market Tach |
				Doc suggestion is a very good choice.  If you're looking  for JUST a tach, take a look at the Horizon Instruments P-1000 tach.   You can order it configured to you needs.  Just installed one in a CJ with  an M14.
  Dennis
  [quote]   ---
		shinden33
				 Posted: Sun May 10, 2009 9:08 am    Post subject: Re: After market Tach |
				Doc - already tried the cannon plug.  I pulled the tach gen off and the shaft no longer turns the guts.
 Dennis & Fran - The horizon can be set up for %?
 S
		barryhancock
				 Posted: Sun May 10, 2009 9:54 am    Post subject: Re: After market Tach |
				I was first introduced to the Horizon Tach several years ago when I installed an M14P in the "Super Pickle".  Since then I have come to know the company pretty well as they have programmed a couple of 337 tachs for the stock Housai for us.  It's a great product with super customer support.  It is a good diagnostic tool, very readable, and very reliable.  The gauges are STC's for other applications.
 For a stand alone replacement, I'm not aware of a product that comes close.  And for about the same money as a tach generator, you get a solid state replacement that is dead nuts simple to wire (off the P-leads at the mag switch).
 FWIW,
 Barry
  _________________ Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com |
				 Posted: Sun May 10, 2009 11:13 am    Post subject: After market Tach |
				Yes.  The factory will do that for you.
  Dennis
  [quote]   ---
		Yak52w(at)aol.com Guest
				 Posted: Sun May 10, 2009 11:14 am    Post subject: After market Tach |
				I second that suggestion. I have the Horizon tach in my 52 and  have been very pleased with it. a digital indication for mag drop and you can  get the indicator lights set for max continuous which provides a good "idiot"  light for rpm while flying formation.
  Tim Stevens
   In a message dated 5/10/2009 1:55:44 P.M. Eastern Daylight Time,  bhancock(at)worldwidewarbirds.com writes:
   	  | Quote: | 	 		  -->    Yak-List message posted by: "barryhancock"    <bhancock(at)worldwidewarbirds.com>
 FWIW,
 Barry
 Barry    Hancock
 Read this topic online    here:
 http://forums.matronics.com/viewtopic.php?p=243406#243406===============================================
 _-=   e  ties  Day  ================================================               - MATRONICS WEB FORUMS  ================================================             - List Contribution Web Site  sp;                             ===================================================
  The Average US Credit Score is 692. See Yours in Just 2 Easy Steps!
				 Posted: Sun May 10, 2009 6:56 pm    Post subject: After market Tach |
				West London Aero Club Russian Engineering has them listed on their website
 if you want to stay orginal.
 I have a mix in my pane. The Dynon and the steam gauges mixed. In the 50,
 the AS indicator is perfect for snap shots on final as is the % RPM. For a
 snap shot, the position of a needle on a dill works better for me than tapes
 and digital printouts. Now if I had the bucks to project the info on Beveled
 Glass on the windscreen AKA HUD, well then the steam gauges would be gone.
 Doc
