		vincent
				 Posted: Sun May 17, 2009 1:27 pm    Post subject: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
				Someone had an idea where to install a garmin GPS 296 in a yak 52 cockpit ?
				 Posted: Sun May 17, 2009 3:09 pm    Post subject: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
				I mounted my 295 initially (now changed to 396) to the ventilation tube
 between my legs. I used a RAM-B-108 base with strap clamp (P/N 11-02003) to
 attach the ball base to the side of the tube. I then used the RAM-B-138-GAZ
 (P/N 11-01766) to mount the ball clamp parallel to the tube with Garmin
 sitting in front of the flat plate on the vent tube. I bought the mounts
 from Aircraft Spruce.
 Hope this helps.
 Doc
		LawnDart
				 Posted: Fri May 22, 2009 5:22 am    Post subject: Re: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
				I use RAM mounts.  They have one that will mount to the glare shield and hold the 296.  It is very sturdy and does not vibrate in flight.
 Mount: RAM-B-177-GA7U
 http://tinyurl.com/pyojro
 I mounted mine in the center.  Does cover up the artificial horizon when mounted.
		yakplt(at)yahoo.com Guest
				 Posted: Sat May 30, 2009 2:52 pm    Post subject: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
				Bought N66PW.
  Mark
 To: yak-list(at)matronics.com
 Sent: Monday, May 18, 2009 7:05:44 PM
 Subject: RE: Install a GARMIN GPS 296 in a YAK 52 cockpit ?
 --> Yak-List message posted by: "Roger Kemp M.D." <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)>
 Hope this helps.
 Doc
				 Posted: Sat May 30, 2009 4:15 pm    Post subject: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
				You did! Cool. Let me know when you are going to tooling through central Al if you are going to go back to NC across the lower US.
 Doc
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Yak Pilot
  Sent: Saturday, May 30, 2009 5:52 PM
  Subject: Re: Install a GARMIN GPS 296 in a YAK 52 cockpit ?
 Bought N66PW.
 Mark
  Hope this helps.
  Doc
