Arksey(at)aol.com Guest
				 Posted: Sat Jun 13, 2009 6:22 pm    Post subject: Flat tire (non event) |
				well i am for sure a old pilot....but have not landed with a  flat tire....what you did worked so it was ok .....but did you check the tires  prior to take-off?   if not you should....On my firestar the tires  were sort of old when I purchased it and I noticed a slow leak in one....I  replaced both tires with new tires and tubes...I think it pays to keep good  tires on a plane...I check tires on pre flight by stepping on them....glad  things worked ok for you...
  JIM  SWAN
 firestar ll, 503, N663S
 Eaton Rapids, Mi. 48827
 PH 517-663-8488  runway 2300' E & W (42-28.58N 084-44.69 W  )
  A Good Credit Score is 700 or54365/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JunestepsfooterNO62>See yours in just 2 easy steps!
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
