hsdexo
Posted: Thu Jul 09, 2009 7:59 am Post subject: Hot` |
I know this is an old topic, just wandering if anyone has found the magic solution to the hot tunnel and subsequent hot cabin at low altitudes in the 10.
I have the VANS mod dumping fresh air in the tunnel, I have insulated the tunnel, I have the firewall insulated inside, nothing on the outside. I have louvers about twice the size that came with the kit installed on the bottom of the cowling.
Any suggestions short of air conditioning.
I don't have a problem with the engine or oil temps.
R/Harry
gengrumpy(at)aol.com Guest
Posted: Thu Jul 09, 2009 12:08 pm Post subject: Hot` |
I just followed the plans, used Van's kit parts, and only have one
heat muff connected to the inlet valve.
I also installed a butterfly valve ahead of the heat muff intake,
which stays closed most of the time.
No problem with heat in the tunnel.
grumpy
N184JM
On Jul 9, 2009, at 10:59 AM, hsdexo wrote:
R/Harry
http://forums.matronics.com/viewtopic.php?p 52291#252291
