aslsa.rng(at)gmail.com Guest
				 Posted: Mon Jul 20, 2009 6:09 pm    Post subject: Changing HKS Throttle from pull open to pull closed |
				Frank, Called the Bing Agency this afternoon and Charlie, the owner, was out. He'll be back on Wednesday and I'll try again. The light bulb went off this evening and I thought of the 912 / 914 Illustrated Parts Catalog. Sure enough in section 22, Bing Carb, I found all the parts. If you don't have a copy it can be had from R.O.A.N. Rather long download. You'll also want a copy of the 912 Installation Manual. On page 96 it shows how the various parts work together and giving instructions for proper set up.
 IPC #      Rotax Part #     Side       # RQD                               Description
 45           963025           cyl 1             1                         Throttle valve lever
  45           963020           cyl 2             1                              "        "       "
 46           241847                               2                         Allen Screw M5 X 12
  47           847740                               2                         Graduated Sleeve
 48           827800                               2                         Washer A 5.5
 49           842030                               4                         Lock Nut M5
  50           938289                               2                         Return Spring
 56           851071           cyl 1             1                         Support
 56           851073           cyl 2             1                             "
  58           241440                               2                         Adjustment Screw M6 X .75
 59           942541                               4                         Hex Nut M6 X .75 height 3mm
 NOTE: The return spring may be the same on both engines, I have no way of telling
 Well, that should be all the parts required to change over from a pull open throttle to a pulled closed one.
 Rick Girard
 I decided to send this again as for the archives so the subject would reflect the content
