uvtreith(at)t-online.de Guest
Posted: Sat Jul 25, 2009 2:09 am Post subject: AW: NPT threads |
Svein,
You have to use a Teflon sealing.
Normally for instrumentation (industry) we are using Teflon tape, but there is also a Teflon sealing fluid (pasta) on the market.
Maybe that this is better for “tank” connectors to avoid getting parts of the Teflon tape into the fuel system
Best Regards,
Bruno
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Sidsel & Svein Johnsen
Gesendet: Samstag, 25. Juli 2009 11:16
An: europa-list(at)matronics.com
Betreff: NPT threads
Should I use any kind of sealing on NPT threads in the fuel system (e.g. Locktite) or do these threads seal just by using the recommended torque?
Svein
LN-SKJ | Quote: | | [b]http://www.matronics.com/Navigator?Europa-List[b] | 0123456789
rampil
Posted: Sun Jul 26, 2009 5:05 am Post subject: Re: AW: NPT threads |
Hi Svein,
Never use teflon tape in the Fuel system.
The reason is that tape shreds and those shreds can get into the
fuel stream and clog your carb, especially if the particular fitting
is downstream from filters.
Use instead PTFE Pipe compound as suggested. it is a paste
available at places like Home Depot or plumbing shops.
Good Luck,
Ira
