jrlark
Posted: Wed Aug 05, 2009 5:10 am Post subject: proseal |
Hi guys
I came home with a quart of Proseal and hardener from Airventure and recall
people putting the Proseal in a freezer to extend its shelf life.
The expiry date is Nov 2009, and since I won't be starting the tail section
until at least Sept, I am wondering if it's unopened, if it matters? Also
did anyone freeze the hardener as well?
Thx in advance.......
Rick
#40956
Southampton, Ont
flysrv10(at)gmail.com Guest
Posted: Wed Aug 05, 2009 5:44 am Post subject: proseal |
I store it in the frig not the freezer. It seems to work even after
couple of years of storage.
do not archive.
On Aug 5, 2009, at 9:05 AM, Sandra & Rick Lark wrote:
<jrlark(at)bmts.com>
Hi guys
recall
section
matters? Also
Rick
#40956
Southampton, Ont
AirMike
Posted: Wed Aug 05, 2009 5:48 am Post subject: proseal shelf life |
I do not know about the freezer, it is not water based. Refer might be preferred if there is no smell.
I do know that I had Van's 2 oz kit (bought last Oct) in my very cold garage all winter, and have used it with good results all this summer. Garage is in the 40's most of the winter.
_________________ See you OSH '18
Q/B - sold. |
drfred(at)suddenlinkmail. Guest
Posted: Wed Aug 05, 2009 5:55 am Post subject: proseal |
Rick;
I do keep the proseal in the freezer. I have used it about a year over
exp date for non essential areas. I wouldn't hesitate using it on the
trailing edges/to bond the rudder/elevator if it was a little over the
exp date. I would not use it for the tanks. All you have to do is look
at the recent posts with all the trouble one has to go thru if you have
a leaking tank. Some have even repainted their airplanes. Messes up
the paint scheme which can take months to develop.
Dr Fred.
Hi guys
recall
section
Also
Rick
#40956
Southampton, Ont
planesmith(at)hotmail.com Guest
Posted: Wed Aug 05, 2009 5:57 am Post subject: proseal |
Hi Rick C
I put both parts in the refrigerator. It's a little stiff when you take it out but it has worked fine. Can't comment on the freezer idea.
Vern Smith (N44QT finishing)
| Quote: | From: jrlark(at)bmts.com
Subject: proseal
Date: Wed C 5 Aug 2009 09:05:48 -0400
--> RV10-List message posted by: "Sandra & Rick Lark" <jrlark(at)bmts.com>
Hi guys
The expiry date is Nov 2009 C and since I won't be starting the tail section
until at least Sept C I am wondering if it's unopened C if it matters? Also
Rick
[quote] _=====
Get back to school stuff for them and cashback for you. Try BingT now.
Kelly McMullen
Posted: Wed Aug 05, 2009 6:08 am Post subject: proseal |
I know some manufacturers had/have FAA approval for storing in
freezer, followed by microwaving so many seconds(of course only works
for non-metal sem-tubes). Like others, I store mine in hangar
refrig..adds to beer and soda flavor.
On Wed, Aug 5, 2009 at 6:30 AM, Rob Kermanj<flysrv10(at)gmail.com> wrote:
I store it in the frig not the freezer. It seems to work even after couple
do not archive.
> Hi guys
> recall
> section
> Rick
> #40956
> Southampton, Ont
A&P/IA, EAA Tech Counselor
KCHD |
rene(at)felker.com Guest
Posted: Wed Aug 05, 2009 6:22 am Post subject: proseal |
I would recommend keeping it cool at least, you will need it later in the
project and it will keep for a long time if it is kept out of the heat. In
the winter I kept my in the garage and in the spring, summer and fall, I
kept it in the refrigerator. I did not have any problem with it setting up.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Tim Olson
Posted: Wed Aug 05, 2009 6:24 am Post subject: proseal |
Put it in the freezer and it should be fine for the tail kit.
You may want to buy a quart or more of new when you get to
the fuel tanks. This stuff you can use for misc. jobs
for a couple years at least if you keep it in the freezer,
but use new for your fuel tanks.
Tim Olson - RV-10 N104CD
Hi guys
Rick
#40956
Southampton, Ont
Posted: Wed Aug 05, 2009 10:36 am Post subject: proseal |
Doesn't have to be in the freezer .... just keep it cold. The hardener
is the part that goes bad with age. I've tested really old Proseal with
fresh hardener and it cured.
Linn
Hi guys
Rick
#40956
Southampton, Ont
msausen
Posted: Wed Aug 05, 2009 11:05 am Post subject: proseal |
I put leftover proseal from my tanks in the freezer for 3-4 years now. I needed to use some for the cabin top riveting recently and actually threw both parts in the microwave to warm up enough to mix (I wouldn't recommend this for any large qty) and had no problems with it. Setup just like it was new. YMMV and I would recommend a test batch for any that is past the recommended date.
Michael
jrlark
Posted: Wed Aug 05, 2009 1:25 pm Post subject: proseal |
Thx for all the replies with regards to proseal. It's already sitting beside the BudLight in the shop refrigerator.
Rick
#40956
Southampton, Ont
Kelly McMullen
Posted: Wed Aug 05, 2009 2:15 pm Post subject: proseal |
I hear it is Light sensitive. Probably safer next to Molson.
On Wed, Aug 5, 2009 at 2:22 PM, Rick and Sandra Lark<jrlark(at)bmts.com> wrote:
| Quote: | Thx for all the replies with regards to proseal. It's already sitting
Rick
#40956
Southampton, Ont
KCHD |
jeff(at)westcottpress.com Guest
Posted: Wed Aug 05, 2009 2:16 pm Post subject: proseal |
Bud Light? I thought you all drank Labatts up there?
On Aug 5, 2009, at 2:22 PM, Rick and Sandra Lark wrote:
| Quote: | Thx for all the replies with regards to proseal. It's already sitting beside the BudLight in the shop refrigerator.
Rick
#40956
Southampton, Ont
