		rvdave
				 Posted: Tue Aug 04, 2009 7:01 pm    Post subject: mounting steps |
				I'm in the process of mounting steps on a QB, the steps were pre-drilled and according to the drawings the weld should be flush with the skin, which it isn't, and the measurement from rear spar should be 45 1/2, which it's about 46 with fuselage leveled.  I could either let it go as is, move step to correct position and re-drill 90 deg from previous hole, or order new steps and align with existing hole.  What are your experiences as to how your steps came out in relation to plans?
 Dave Ford
  _________________ Dave Ford
Cadillac, MI |
		jeff(at)westcottpress.com Guest
				 Posted: Tue Aug 04, 2009 8:13 pm    Post subject: mounting steps |
				Hi Dave,
  From what I remember of a conversation with Vans, the step position
 relative to the rear spar has more to do with clearing the flaps when
 extended than anything else.  If your step is canted a bit further aft
 than specified, I don't think you have a problem.  You don't say how
 far from flush the weld is to the skin.  Mine stopped at the edge of
 the widest edge of the weld bead... which didn't seem all that "flush."
 Jeff Carpenter
 40304
 Doors.  Ugh!
 On Aug 4, 2009, at 8:01 PM, rvdave wrote:
  Dave Ford
  Dave Ford
  RV6 flying
  RV10 building
  Cadillac, MI
  http://forums.matronics.com/viewtopic.php?p 56093#256093
		johngoodman
				 Posted: Wed Aug 05, 2009 3:40 am    Post subject: Re: mounting steps |
				I wouldn't worry about it too much. Some of the weld will be visible but no big deal. As long as you clear the flaps, it should be fine.
 John
  _________________ #40572 Phase One complete in 2011 |
