rickofudall
Posted: Fri Oct 09, 2009 2:53 am Post subject: FAA AC 20-27G |
The FAA has released the latest version of Advisory Circular 20-27G, "Certification and Operation of Amateur-Built Aircraft". Topics covered are:
(1) Certificating and operating your amateur-built aircraft,
(2) What to do and know before building an amateur-built aircraft,
(3) Designing and constructing your amateur-built aircraft,
(4) Fabricating and assembling your amateur-built aircraft,
(5) Registering your amateur-built aircraft,
(6) Identifying and marking your amateur-built aircraft,
(7) Applying for certification of your amateur-built aircraft,
( FAA inspection of your amateur-built aircraft,
(9) Issuing an airworthiness certificate for your amateur-built aircraft,
(10) Flight testing your amateur-built aircraft,
(11) Operating your amateur-built aircraft after flight testing,
(12) Amateur-built aircraft built outside the United States and purchased by a U.S. citizen,
(13) Becoming a repairman for your amateur-built aircraft, and
(14) General safety recommendations.
A copy can be downloaded here:
http://www.faa.gov/documentLibrary/media/Advisory_Circular/AC%2020-27G.pdf
Rick Girard
