kearney
Posted: Sun Oct 11, 2009 8:52 am Post subject: Final Fitting of the canopy |
Hi
Yesterday was a red letter day as I put my canopy on for the last time and glassed it into the door frame. I am no looking at riveting up the side flanges to the fuse. I do have a question however. The plans suggest sealing the rear canopy flange to the tail cone forward top skin to prevent leaks.
Is there any need to do something similar to the side flanges that fit inside the fuse skins and rest on top of the longerons?
Inquiring minds need to know…..
Les
40643 – 90% finished with the cabin top f/g – only 90% to go
Jim Berry
Posted: Sun Oct 11, 2009 9:05 am Post subject: Re: Final Fitting of the canopy |
Les,
I think most people are putting a layer of fiberglass over the rivet line to hide the pull rivets, which effectively water proofs this area. Congratulations on getting the canopy anchored. Now you can get on to fitting the doors. Have fun with that.
Jim Berry
40482
N15JB
kearney
Posted: Sun Oct 11, 2009 11:43 am Post subject: Final Fitting of the canopy |
Hi Jim
I was wondering about glassing that rivet line.
If the truth be known, I have my doors fitted already. I just clecoed the
top on while fitting the doors. This, as it turns out, was a good thing as
it allowed the port door sill (fibreglass) to be relocated about 1/8"
inboard so my door seals weren't compressed too much. This makes the door
very easy to close. I expect as the seals get a memory it will be easy
still. FYI, I am using the McMaster Carr seals and had them installed when
fitting the doors.
I all I have to do now is to adjust the door gap and then I can move on to
something that doesn't involve sanding.
Cheers
Les
Ron B.
Posted: Mon Oct 12, 2009 2:15 pm Post subject: Re: Final Fitting of the canopy |
That's what you think. It never ends.
Ron
Phil.Perry(at)netapp.com Guest
Posted: Tue Oct 13, 2009 7:05 am Post subject: Final Fitting of the canopy |
Is this the Fiberglass tape that everyone is using to hide those rivet
lines on the side of the canopy and cowling?
http://www.aircraftspruce.com/catalog/cmpages/etapes.php
Phil
Jim Berry
Posted: Tue Oct 13, 2009 8:29 am Post subject: Re: Final Fitting of the canopy |
Phil,
I used 2 oz. tape for this. Heavier(thicker) tape is going to make it harder to get a smooth transition from the canopy to fuselage. I also used 2 oz. to cover the hinge rivet lines on the cowling and control surface fairings.
Jim Berry
40482
N15JB
MauleDriver(at)nc.rr.com Guest
Posted: Tue Oct 13, 2009 8:56 am Post subject: Final Fitting of the canopy |
Where did you get the 2oz tape?
Bill Watson
40605
Jim Berry wrote:
Phil,
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p 67753#267753
Posted: Tue Oct 13, 2009 10:24 am Post subject: Final Fitting of the canopy |
Aerospace composite products:
http://www.acp-composites.com/home.php Great site with so many goodies.
| Quote: | Date: Tue C 13 Oct 2009 12:55:41 -0400
Subject: Re: RV10-List: Re: Final Fitting of the canopy
--> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Bill Watson
40605
Jim Berry wrote:
> --> RV10-List message posted by: "Jim Berry" <jimberry(at)qwest.net>
> Phil C
> Jim Berry
> 40482
> N15JB
> http://forums.matronics.com/viewtopic.php?p=267753#267753
&g============
Jim Berry
Posted: Tue Oct 13, 2009 11:01 am Post subject: Re: Final Fitting of the canopy |
Bill,
I got the 2 oz. tape from my local West Systems dealer, although it is not a West System product. I think most any fiberglass supplier will have it.
Jim Berry
40482
