jridgway
Posted: Sun Dec 20, 2009 4:31 pm Post subject: can someone help me |
RDoss Don't give up on eBay. Ebay will do 90 day daily searches for anyone. Search under the "Camera & Photo" section so you cover all photo items. Possible Searches: First use quotes for all sea
Oh, God! Yeah, I understand that must be really, really tough My classmates does the same thing Just because a surten film shows up, they all suddenly think they're going to High Shcool and live exa
signals within the polypeptide chain and of them failed to display a sufficient bind- the fragileX syndrome RNAbinding protein
morphology, location, and behavior. The Sometimes viruses, like HIV-1, use a coreceptor (yellow) for invade critical sequences within the HCV
Dick Maddux
Posted: Mon Dec 21, 2009 7:00 am Post subject: F210 high readings |
Jack ,
You are probably reading liters instead of gals. I think setting number 2 is gals. Check your operators manual. I have had the unit swap the settings by itself.
Dick Maddux
Milton,Fl
akflyer
Posted: Mon Dec 21, 2009 7:46 am Post subject: Re: F210 high readings |
| jridgway wrote: | HI..
Just installed a F210 on my KF3/582 and getting very very high readings (20GPM). I double checked indicator and it was US GAL/MIN.
I flew today for 1 hard hour and only REALLY burned 6 gal.
Documentation says may be air in line. Anybody else have this problem?
Any ideas??
Transducer is a new replacement.
thanks..jack |
set it to gallons per hour.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
jridgway
Posted: Tue Dec 22, 2009 4:04 pm Post subject: Re: F210 high readings (SOLVED !!!) |
OK...found out today that the F210 seems to reset to liters after engine shutdown. It seems fine when I reset it to gal/hr before each flight. Just made it part of my pre-flight checklist.
thanks for all the comments...Jack
WONDERING if I isolated the F210 during start up if it would work OK..voltage/current spike during start up???
