Tailplane balance mass
frans(at)paardnatuurlijk.
PostPosted: Tue Nov 24, 2009 6:52 am    Post subject: Tailplane balance mass Reply with quote
Gentlemen, I have an important question.
How did the tailplane balancing work out for you with the Europa
supplied counter weights? How much did you need to remove from the
weights, or did you need to add some weight?
I have a large weight, a middle sized one, and three smaller ones. Prior
to filling and painting, one of each size was sufficient to roughly
balance the tailplanes. The tailplanes were built by the factory and
have not been modified (except for the mandatory mod, but this was at
the axis of the tailplane and shouldn't have much influence on the balance).
Now, my airplane is painted, and I discovered that with all 5 weights on
the balance arm, I'm still slightly out of balance.
The manual strongly suggests that it should be "more than likely" that
some weight has to be removed, and that it is very unlikely that one
needs additional weight. But I need additional weight, and I want to
know whether this is normal, and if not, what the reason is.
As I said, the controls where factory built, and I had no reason to
believe that they were heavier than average.
My airplane has been filled and painted by a well respected painter who
has not only built himself an airplane as well, but has filled and
painted many airplanes from the Dutch homebuilders club. It is not
likely to assume that he has done a bad job on my airplane or used non
suitable materials, but at the moment it starts to look like he added
quite some weight to my airplane. Also the ailerons appeared to be
heavy, as they appeared in balance without any of the material removed
from the lead blocks.
Knowing the weight I needed to add to balance the tailplanes I could
roughly work out that each tailplane gained about 1 Kg of filler and
paint. Is this reasonable?
So, I would very much like to know whether it could be somewhat normal
that the balance weighs are just a tad to light for their task.
I plan to weight my airplane soon, but I'm getting quite worried about it...
Frans
kheindl(at)msn.com
PostPosted: Tue Nov 24, 2009 7:19 am    Post subject: Tailplane balance mass Reply with quote
Frans C
My tailplanes are in the house and I just weighed the port one. It is 5.9 kg.
Karl
Date: Tue C 24 Nov 2009 15:50:08 +0100
Subject: Tailplane balance mass
--> Europa-List message posted by: Frans Veldman <frans(at)paardnatuurlijk.nl>
Gentlemen C I have an important question.
weights C or did you need to add some weight?
I have a large weight C a middle sized one C and three smaller ones. Prior
to filling and painting C one of each size was sufficient to roughly
have not been modified (except for the mandatory mod C but this was at
Now C my airplane is painted C and I discovered that with all 5 weights on
the balance arm C I'm still slightly out of balance.
some weight has to be removed C and that it is very unlikely that one
needs additional weight. But I need additional weight C and I want to
know whether this is normal C and if not C what the reason is.
As I said C the controls where factory built C and I had no reason to
has not only built himself an airplane as well C but has filled and
suitable materials C but at the moment it starts to look like he added
heavy C as they appeared in balance without any of the material removed
So C I would very much like to know whether it could be somewhat normal
I plan to weight my airplane soon C but I'm getting quite worried a=====================
_=======
Brian Davies
PostPosted: Tue Nov 24, 2009 7:29 am    Post subject: Tailplane balance mass Reply with quote
Frans,
I built my own tailplanes and they required less weight than that supplied.
I recently helped someone balance their tailplanes who had used factory
built parts. We needed all of his weights plus what was left over from my
weights. His aircraft was painted by an auto guy and could be on the heavy
side regarding filler and paint. 1 Kg per TP sounds a lot to me but I did
not do a "before and after" weigh so I will leave it to others to comment.
Hope that helps.
Brian Davies
rlborger(at)mac.com
PostPosted: Tue Nov 24, 2009 7:45 am    Post subject: Tailplane balance mass Reply with quote
Frans,
Lovely aircraft! Almost as pretty as the young lady sitting on the wing with you.
For what it's worth, my tailplane balanced with one big, one middle and two small weights positioned using washers behind them such that the weights were held full forward against the roll pin. The weights had all been bead blasted to remove some thin rust then primed and painted. So they might be a tiny bit heavier than plain weights.
I not only static balanced the tailplane, but also "dynamically" checked the balance. That is, I made sure the tail was in balance and had no tendency for the weights to raise or fall on their own. For the dynamic balance check, I quickly lifted and lowered the tail to ensure that the tailplane did not move when the tail was moved. This was easier to accomplish with my Monowheel than it might be with your tri-gear.
Check six,
Bob Borger
On Tuesday, November 24, 2009, at 08:50AM, "Frans Veldman" <frans(at)paardnatuurlijk.nl> wrote:
PostPosted: Tue Nov 24, 2009 10:05 am    Post subject: Tailplane balance mass Reply with quote
Mine are 6.3 and 6.4...
Indeed quite heavy.
I wish I had weighed them before they went to the painter... Now I don't
know whether the factory made them heavy or the painter...
If it is the factory, I'm lucky. If it was the painter, well, ehm, let's
see. If the tailplanes are 1 Kg heavier than they should be, the how
much should the main wings be overweight? And the fuselage?
Frans
rparigor(at)suffolk.lib.n
PostPosted: Tue Nov 24, 2009 10:31 am    Post subject: Tailplane balance mass Reply with quote
Hi Frans" Karl Heindl wrote: My tailplanes are in the house and I just weighed the port one. It is 5.9 kg. Mine are 6.3 and 6.4... Indeed quite heavy."When building flying wing slope planes just a little extra finishing weight makes them go tailheavy quite easily. Same story withEeuropa stabialtors.Going forward adding an extra weight if you have space or making them out of lead or with tungsten inserts or both should not cause you much problem.I don't know where your CG comes in at, but if you are tending towards nose heavy, perhaps consider making a synergistic harmonazation, add a little tailweight and remove about 15% of the stresses on the mass balance arm and stabilator drive pins?[url=http://www.europaowners.org/gallery2.php?g2_itemId 8658]http://www.europaowners.org/gallery2.php?g2_itemId 8658[/url]compared to just adding weight to mass balance arm which will increase stresses on pins.Ron Parigoris [quote][b]
fklein(at)orcasonline.com
PostPosted: Tue Nov 24, 2009 10:37 am    Post subject: Tailplane balance mass Reply with quote
My starboard tailplane is 5.8 kg.
Karl,
Would those weights be with or without the anti-servo trim tabs?
Fred
A194
craigb(at)onthenet.com.au
PostPosted: Tue Nov 24, 2009 11:58 am    Post subject: Tailplane balance mass Reply with quote
Frans, rather than adding more weight, can you make the effective weight
more by lengthening the arm,
at present, mine is balanced with the big weight and one small one, if i
slide it right out to the end
or two small ones if right back, maybe a small increase right at the end of
the arm, with say a lead weight
might allow for less overall weight, just a thought.
craig
jan_de_jong(at)casema.nl
PostPosted: Tue Nov 24, 2009 12:59 pm    Post subject: Tailplane balance mass Reply with quote
craig
Or replace drilled out steel by lengths of tungsten electrode:
http://www.lasplaza.nl/catalog/product_info.php?cPath=175&products_id=1182
Same thought, but keeping the supplied weights.
Jan de Jong
PostPosted: Tue Nov 24, 2009 1:43 pm    Post subject: Tailplane balance mass Reply with quote
Ok, thanks. The problem however is not how to solve this. I just wanted
to know if it could be somehow acceptable that I have to add weight, or
that it indicates that something is terribly wrong.
I will weigh the total aircraft to see how bad it is. Hopefully just the
factory built controls or filling work is somewhat heavy, and the rest
of the airplane is ok.
Frans
PostPosted: Tue Nov 24, 2009 1:52 pm    Post subject: Tailplane balance mass Reply with quote
Probably not. I have the batteries (2 x PC310) under the bagage bay, and
a heavy fixed (mandatory) ELT behind the D-panel. If it turns out that
I'm still nose heavy, I will move the ELT as far away in the tail as
neccessary to get into the desired range. Then I have found at least one
usefull purpose for the ELT. Wink
Your solution is nice, but only if you otherwise have to fly around with
useless weight in the tail. It will cost more weight to balance the
tailplanes by making the leading edge heavier, instead of adding weights
to the balance arm.
Frans
grahamsingleton(at)btinte
PostPosted: Tue Nov 24, 2009 4:45 pm    Post subject: Tailplane balance mass Reply with quote
Frans
if you cut some lead sheet washers and use them instead of the small
steel weight that will reduce the extra weight requiref. You might also
polish some paint off the back of the tail Wink
Be interested to know the all up weight
Graham
Frans
kheindl(at)msn.com
PostPosted: Tue Nov 24, 2009 4:48 pm    Post subject: Tailplane balance mass Reply with quote
Fred C
That is for the fully assembled unit. Only extras are chromed brass pip pin hole covers C and my mod of replaced ss TP5 with long aluminum tube. Only filler used was for filling in the weave. I assume that most tailplanes are around the same weight.
Karl
Subject: Re: Tailplane balance mass
Date: Tue C 24 Nov 2009 10:35:01 -0800
Karl C
Fred
A194
lectric.com
/">www.buildersbooks.com
ebuilthelp.com
ww.matronics.com/contribution
ronics.com
