		thane
				 Posted: Wed Nov 25, 2009 5:22 pm    Post subject: G-430/W  wont aquire gps signal |
				Just  wanted to see if anyone has had a similar problem??
  I have a  G-430 /W and after 6 weeks of down time to complete Conditional Inspection, I am  unable to get the unit to aquire a signal and thus position.  It has done  this in the past maybe 5-6 times but always came up within 5 minutes or  so.
  Today I  was unable to get to work  by powering the unit down.
  Any ideas  or input would be great.
  Thane  States
  N321BY
  80  hrs.
  [quote] 	  | Quote: |
 href="http://www.aeroelectric.com">www.aeroelectric.com
 href="http://www.buildersbooks.com">www.buildersbooks.com
 href="http://www.homebuilthelp.com">www.homebuilthelp.com
 href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
  | 	  [b]
  _________________ Working on finish kit: I hate fiberglass!! |
				 Posted: Wed Nov 25, 2009 5:40 pm    Post subject: G-430/W  wont aquire gps signal |
				You may need to ensure the time is correct and  give it a rough idea of where it is located.  Also, make sure it is outside  and can 'see' the satellites (not trying to be a smart (at)ss)  - I used an  extension cable on my GPS antenna to put it outside the hangar when I couldn't  roll my plane around.  Also, part of my oil-change requires me to remove my  GPS antenna (it's mounted under the cowl and is in the way of the wrench to  loosen the fliter) - so I test mine after each oil change too...just some  thoughts
  Before I swapped out my GX60 for a GNC420W,  the GX60 needed a little help in figuring out where it was.
  Something to try - haven't had this problem  with the new 420W....
  [quote]   ---
		jim(at)CombsFive.Com Guest
				 Posted: Wed Nov 25, 2009 5:47 pm    Post subject: G-430/W  wont aquire gps signal |
				Couple of things to check:- Make sure you are not in a metal hanger (Visible Sky).  Sounds silly, but the unit must be able to see the sky.- Check the cable to the GPS antenna.  It is an active antenna and gets DC power from the 430W.  Make sure the connections are good and no stray shield wire strands are creating shorts.- Make sure antenna location is optimum.  On the top of the instrument panel, top of the fuselage or way out under the cowling away from the firewall.Jim C (N312F - Flying 140 hours - almost ready to do first condition inspection)--------------------------------------------------Just wanted to see if anyone has had a similar problem??I have a G-430 /W and after 6 weeks of down time to complete ConditionalInspection, I am unable to get the unit to aquire a signal and thusposition.  It has done this in the past maybe 5-6 times but always came upwithin 5 minutes or so.Today I was unable to get to work  by powering the unit down.Any ideas or input would be great.Thane StatesN321BY80 hrs.   [quote][b]
		Deems Davis
				 Posted: Wed Nov 25, 2009 6:27 pm    Post subject: G-430/W  wont aquire gps signal |
				I've had this problem before, after being down for some period of time.
 The solution for me was to let the GPS search for up to 20-30 minutes.
 I'm not a rocket scientist, but the position of the satellites has
 likely changed since  you went down for inspection, and when I talked to
 the GPS gurus' (at) Freeflight they said it could easily take 20 + minutes
 particularly if the plane was moved from it's last 'on' position.
 Deems Davis
 N519PJ
 www.deemsrv10.com
 Thane States wrote:
  	  | Quote: | 	 		   Just wanted to see if anyone has had a similar problem??
  Thane States
  N321BY
  80 hrs.
		thane
				 Posted: Thu Nov 26, 2009 9:11 am    Post subject: G-430/W  wont aquire gps signal |
				Deems, thanks for that info, that may be what it needs.  I was not able with
 the short flight's to be airborn for more than 10 minutes or so.  I  hope
 that is it.
 Thane
		Deems Davis
				 Posted: Thu Nov 26, 2009 10:51 am    Post subject: G-430/W  wont aquire gps signal |
				Try dragging the plane out of the hangar, powering it up and let it
 'search for 30 minutes.
  able with the short flight's to be airborn for more than 10 minutes or
  so.  I  hope that is it.
  Thane
		Nick Nafsinger
				 Posted: Fri Nov 27, 2009 2:46 pm    Post subject: Re: G-430/W  wont aquire gps signal |
				You can also try a factory reset. Hold down the CLR key when powering up. This clears the internal memory, including any user points and flight plans...  Then let it reaquire (10-20 min).
  _________________ RV-10  40569
Flying! |
