harvey4(at)earthlink.net Guest
Posted: Mon Nov 30, 2009 10:21 am Post subject: Tracking a high resistance joint |
My alternator is putting out 14+ volts but I'm only seeing low 13's
at the panel bus, suggesting a high resistance joint somewhere on the
way to the panel.
Any ideas on how to diagnose the bad joint would be appreciated. My
limited knowledge of Ohm's law says that the resistance drop across
the bad joint will be too tiny to detect with a standard meter and I
probably won't find it that way.
Thanks for ideas.
Neil C
Posted: Mon Nov 30, 2009 4:41 pm Post subject: Tracking a high resistance joint |
At 12:15 PM 11/30/2009, you wrote:
the way to the panel.
You're right, attempting to measure very small
resistances with the commercial off the shelf
multimeter is not in the cards.
However, the same instrument can measure VOLTAGES
and in particular, DIFFERENCE voltages. Hook your
(+) meter lead to the alternator b-terminal. Fire
up the engine. Turn lots of stuff ON and then probe
the pathway between b-terminal and the bus with the
(-) lead of your voltmeter.
If it's not practical to do this with the engine
running, then temporarily hook a charged AGM battery
from b-terminal to ground. Perhaps you can fabricate
a jumper to run from your hot side of the battery
contactor over to the b-lead. Do this with a piece
of 10AWG or larger and include a series fuse of 30A
at the battery end. . . . make the battery pretend to be
an alternator. Leave the battery master OFF, turn
on lots of stuff and then probe the path from alternator
b-lead to the bus.
In big airplanes, we do this with a constant current
power supply set up to deliver 30 or so amps over the
power path to be explored. I do have a whippy micro-
ohmmeter but prefer the constant current technique
and voltmeter.
When you have access to the power supply, the rest
of the airplane can be OFF while the survey is being
conducted.
( It's MATRONICS FUND RAISER MONTH! )
( Do your part to keep this marvelous )
( tool sharp and available to all our )
( brothers in the OBAM aviation )
( community. )
