lbcopas
Posted: Sun Jan 10, 2010 3:39 pm Post subject: Milk more power from the 532? |
What's the BIGGEST carb for the 532? I read about tuned exhaust but such a narrow power band - (usually, where you don't need it) OR, melting pistons or disturbing the neighbors... How about larger carbs? .. Which, Where? How much? Tnx, Larry
dave
Posted: Mon Jan 11, 2010 4:33 am Post subject: Re: Milk more power from the 532? |
532 -- don't bother a larger carb as gains will be minimal if anything.
your muffler is limiting your power more so than the carb.
532 work ok stock.
You want more power get a 912
or if you want to experiment and get gobs of power but won't be the best cruise machine.......
do a rotax 670 -- you will get 110 to 130 HP and climb well over 2000 fpm. you might see close to 3000 fpm if your plane is light enough WWOOOOOOOOOOOOOOOOW !!
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Mon Jan 11, 2010 12:15 pm Post subject: Milk more power from the 532? |
I don’t think larger carbs would do the trick… maybe nitrous or supercharging but I wouldn’t want to do either on a two stroke engine.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of larry copas
Sent: January 10, 2010 7:53 PM
Subject: Milk more power from the 532?
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Pat Reilly
Posted: Mon Jan 11, 2010 12:56 pm Post subject: Milk more power from the 532? |
Dave, Are there any of those 630 Rotaxes available? I have never seen one for sale. You state "It won't be the best cruise machine". Why? Is it strictly gas burn rate or something else? What does a 630 weigh in comparison to a 582?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
On Mon, Jan 11, 2010 at 6:33 AM, dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
[quote]--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
532 work ok stock.
Rotax Dealer, Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://rotaxaircraft.com/forum/
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p=280996#280996
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
Matt Dralle, List Admin.
dave
Posted: Mon Jan 11, 2010 1:40 pm Post subject: Re: Milk more power from the 532? |
Pat, First off it is a 670 Rotax not a 630.
Weight about the same give or take 5 lbs.
670 have RAVE vavles which open up the exh. port but not till over 6000 rpm ......... you max HP will start to happen 6500 to 8500 rpm. with a decent pipe. You have to mod the crankcase and cut the PTO of crank a bit shorters and make a smaller morse taper in to to fit the Rotax gear box.
Fuel burn at wide open throttle will go from 7 gal a hour to 11 to 15 gal hour. HP come s at a price .
quote="Pat Reilly"]Dave, Are there any of those 630 Rotaxes available? I have never seen one for sale.�You state "It won't be the best cruise machine". Why? Is it strictly gas burn rate or something else? What does a 630 weigh in comparison to a 582?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
On Mon, Jan 11, 2010 at 6:33 AM, dave <dave> wrote:
| Quote: | --> Kitfox-List message posted by: "dave" <dave>
532 -- � don't �bother a larger carb as gains will be minimal if anything.
532 work ok stock.
do a rotax 670 �-- �you will get 110 to 130 HP �and climb well over 2000 �fpm. you might see close to 3000 fpm if your plane is light enough � WWOOOOOOOOOOOOOOOOW � !!
Realtime Kitfox movies to separate �the internet �chatter from the truth
[b] |
Pat Reilly
Posted: Mon Jan 11, 2010 2:07 pm Post subject: Milk more power from the 532? |
Dave, Thanks for quick reply. I realized after I sent the message it was a 670. Sounds like there are other issues with, retro fitting the crankcase, PTO, HP and torque not available until higher RPM, narrow power band, that make the engine less than desireable for our application.
Â
Pat ReillyÂ
On Mon, Jan 11, 2010 at 3:40 PM, dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
Pat, Â First off it is a 670 Rotax not a 630.
 Pat Reilly
 Mod 3 582 Rebuild
 Rockford,IL
| Quote: | your muffler is limiting your power more so than the carb.
532 work ok stock.
| Quote: | Â Matt Dralle, List Admin.
> Â =====
http://forums.matronics.com/viewtopic.php?p=281087#281087
bscription,
://www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
Float Flyr
Posted: Mon Jan 11, 2010 3:03 pm Post subject: Milk more power from the 532? |
Will a C or E box handle that kind of power?
Noel
Kitfox III-A
larry huntley
Posted: Mon Jan 11, 2010 4:25 pm Post subject: Milk more power from the 532? |
How about a Swiss muffler? Larry
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Float Flyr
Posted: Mon Jan 11, 2010 6:04 pm Post subject: Milk more power from the 532? |
Will a Rotax box take that kind of horsepower?
Noel
Kitfox III-A
dave
Posted: Tue Jan 12, 2010 2:51 am Post subject: Re: Milk more power from the 532? |
| Float Flyr wrote: | Will a Rotax box take that kind of horsepower?
Noel
sure , but use a c or E box
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Pat Reilly
Posted: Tue Jan 12, 2010 2:54 pm Post subject: Milk more power from the 532? |
Tom, Thanks for the Rotax 670 add. I don't need one at the moment, but am noting the shop offering it. It appears they specialize in Rotax.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Tue, Jan 12, 2010 at 7:49 AM, Tom Jones <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)> wrote:
[quote]--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
670 Rotax
http://www.barnstormers.com/classified_394349_KING+KONG+670+ROTAX+DUAL+IGN..html
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=281156#281156
ist Un/Subscription,
lbcopas
Posted: Wed Jan 13, 2010 12:00 pm Post subject: Re: Milk more power from the 532? |
OK Guys, I'm beginning to see a pattern, here. I'll just leave her the way she is. I guess I spoiled myself with a mod3 w/912. The older mod2 with the 532 seemed a bit puny and I was hoping for a cheap, easy way to boost it's performance. But, you're right, she flys just fine the way she is. I do think that I'll look into VGs for both of 'em, though. Thanks a lot, guys. I've learned a lot in the past few days. Adios for now, larry
