Fuel Filter Service - Access Panel
jkreidler
PostPosted: Mon Feb 01, 2010 5:49 am    Post subject: Fuel Filter Service - Access Panel Reply with quote
I was thinking about how difficult it is to service the fuel filter. First, just to get at it there is a pile of work in removing the tunnel cover. Some have split the tunnel cover so it isn't necessary to remove the entire cover to inspect the tunnel, great idea, for those still building this should be considered. Others have installed an access panel in the side of the tunnel in the foot well. This allows easier access to the fuel filter and fuel pump. One of the things I really dislike about servicing the fuel filter is that you have to break the fuel lines, and this causes some fuel to spill. Add insulation to soak up the fuel and you have a recipe for disaster, so you need to use a box of rags to keep the fuel from getting all over the place.
So here is what I was thinking, I wished that when we built the airplane we would have installed an access panel on the bottom of the airplane that we could have reached up through to get at the fuel filter. This would have been much easier during construction.... An alternative would be to install a second fuel filter, and place both filters at the tank exits under the wing walk access panel.
I post this simply to get those who are still building to think about how they will service the fuel filter. Not sure how we will modify our airplane to simplify the task.
Thanks, Jason Kreidler
N44YH - Flying
4 Partner Build #40617
Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler
Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617
gengrumpy(at)aol.com
PostPosted: Mon Feb 01, 2010 5:59 am    Post subject: Fuel Filter Service - Access Panel Reply with quote
It's not that big of a deal to take it out, and you need to inspect inside the tunnel anyway at each annual.
Run the engine dry to check that the shut-off valve works, then a couple of paper towels soak up any residual (I put no insulation in my tunnel for just that reason.....did not want anything to soak up fuel should there be a leak or spill in there......
I wouldn't mess with cutting access panels in the floor......at least not before checking with Van's on what it might do to structural strength....
grumpy
N184JM flying, about to start #3 annual
On Feb 1, 2010, at 7:48 AM, jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com) wrote:
N44YH - Flying
tp://www.matronics.com/Navigator?RV10-List
nics.com
w.matronics.com/contribution
= [quote][b]
Tim Olson
PostPosted: Mon Feb 01, 2010 6:10 am    Post subject: Fuel Filter Service - Access Panel Reply with quote
I just did this yesterday...removed the tunnel cover and
disassembled the fuel filter. I was contemplating doing
a side access door like Scott to get to the filter. I think
that access door could be really handy in accessing the filter
to get tools in there. But, at the same time, even if you
have the door I don't think that makes it a great idea to
do any filter removal without the tunnel cover off.
I spilled plenty of fuel in that tunnel area and had to
wipe it up as you noted. I wouldn't want to completely do the
job through a side panel unless I knew I could get it
all 100% cleaned. So I think that unless there were a
bottom access panel as you noted, there isn't really
a good way to service the filter without removing
the tunnel cover completely, and also removing that SCAT
tube for better access. A side panel removal would
add to easier access.
But, when all is said and done, I think removal of the
entire tunnel cover is probably something you should all
be doing once a year anyway. And I mean the entire tunnel
cover back through the rear seats. It's the only way
you'll be able to inspect and lubricate the control rod
ends. It will still be a pain in the butt, but if it only
comes once a year during annual time then it's not much
worth complaining about....it's easier to annual an RV-10
than it is some of those other certified planes.
Tim Olson - RV-10 N104CD
N44YH - Flying
Phil.Perry(at)netapp.com
PostPosted: Mon Feb 01, 2010 6:24 am    Post subject: Fuel Filter Service - Access Panel Reply with quote
I’m not sure if it’s possible, but I’ve been thinking of adding one filter at each wing root.
I like the simplified access to the filter, but I also like the idea of having one fuel filter dedicated to each tank. This way if a filter should get blocked, I can flip to the other tank and access some fuel there.
Phil
From: jason.kreidler(at)regalbeloit.com [mailto:jason.kreidler(at)regalbeloit.com]
Sent: Monday, February 01, 2010 7:48 AM
Subject: Fuel Filter Service - Access Panel
N44YH - Flying
dlm46007(at)cox.net
If a builder decides to start cutting extra holes in the skin, I would advise getting a structural engineer's analysis of the proposal.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com
Sent: Monday, February 01, 2010 6:48 AM
N44YH - Flying
Tim Olson
I did insulate the tunnel, but only the side walls.
I don't think it does anything worthwhile to do the
sidewalls either. The forward firewall, sure.
And then the SCAT tube wrapped with insulation.
That would be all I'd do if I were doing it again.
My sidewall insulation doesn't go all the way to the
floor though so fuel spilling and soaking isn't
going to soak into it.
strength.....
grumpy
> the place.
> N44YH - Flying
> nics.com
Kellym
Is there any particular reason the filter needs to be in the tunnel?
Anyone considered relocating to front side of firewall?
> the place.
> N44YH - Flying
Kelly McMullen
KCHD
Tim Olson
PostPosted: Mon Feb 01, 2010 6:39 am    Post subject: Fuel Filter Service - Access Panel Reply with quote
I think under the seats would be an awesome location except
for one thing.....when you disconnect the lines, with
no valve to shut off, you're going to dump fuel all
over the place. So that would tempt you to add shutoffs
to each tank in front of the filter....and then that's
another point of leak/failure. Maybe with the right
valves I'd consider putting one filter per wing and
putting them under the seats. Not sure if it's worth
the hassle though once you're flying.
Phil
*Sent:* Monday, February 01, 2010 7:48 AM
*To:* rv10-list(at)matronics.com
*Subject:* Fuel Filter Service - Access Panel
N44YH - Flying
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
jkreidler
PostPosted: Mon Feb 01, 2010 6:43 am    Post subject: Re: Fuel Filter Service - Access Panel Reply with quote
I think there are times, especially when the airplane is new that you need to get into that area besides annual. During annual EVERY panel needs to come off, I don't think there are many or any exceptions this would not change that. I agree a person would need to think about the structure when cutting in access panels, but be aware cutting an access panel in the side of the tunnel requires the same thought.
Like I said, I am not sure how we will handle this, or if we will even make a mod. I just wanted to give those still building a chance to think about a possible mod while it was still fairly simple to implement. Knowing what I know now, I can promise that if we had known about this we would have done something (again not sure what) during construction.
Jason Kreidler
dlm46007(at)cox.net
PostPosted: Mon Feb 01, 2010 7:03 am    Post subject: Fuel Filter Service - Access Panel Reply with quote
Each tank , IIRC, already has a filter screen. Additionally one can see the fuel flows for various power settings on the EFIS, so some indication of a future problem may be evident. Lastly drain/flush the main tanks
after the build process. Mine were QB tanks but still had residual pieces of proseal which I flushed before sending any fuel to the filter.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Monday, February 01, 2010 7:18 AM
Subject: RE: Fuel Filter Service - Access Panel
Phil
N44YH - Flying
0 [quote][b]
dmaib(at)mac.com
PostPosted: Mon Feb 01, 2010 7:25 am    Post subject: Fuel Filter Service - Access Panel Reply with quote
I was dreading taking the fuel filter out during the first condition
inspection back in November. It was a PITA, but not as bad as I had
feared. Some certified airplanes have an access panel on the belly
just for this reason. I think this would be the best solution, but as
others have noted, some structural engineering support would be
required. I am not convinced that an access panel in the side of the
tunnel would make the task that much easier, and as Jason notes,
still has structural considerations. If I was doing it over again, I
would consider the belly access panel.
$.02 worth
David Maib
40559
flying
On Feb 1, 2010, at 9:43 AM, jkreidler wrote:
<jason.kreidler(at)regalbeloit.com>
thought.
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p 84343#284343
dmaib(at)mac.com
PostPosted: Mon Feb 01, 2010 7:36 am    Post subject: Fuel Filter Service - Access Panel Reply with quote
Drained and flushed my QB tanks during the build and did not have any appreciable debris. That was even after having to replace an end rib in one of the tanks due to a builder stupidity induced problem. I noted during the first condition inspection that my fuel filter was perfectly clean.
David Maib
4059
flying
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Perry, Phil
Phil
From: jason.kreidler(at)regalbeloit.com [mailto:jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)]
N44YH - Flying
rnewman(at)tcwtech.com
PostPosted: Mon Feb 01, 2010 5:03 pm    Post subject: Fuel Filter Service - Access Panel Reply with quote
Although I'm not flying yet, can't comment on how this will work out. However, I added an acces panel of my own doing. See attached link to picasa site. http://picasaweb.google.com/rcnewman64 click on folder for "fuel pump and access door" Note, I'm using the andair fuel pump and have moved the filters/gas colators to the wing. I'm not planning on needing to get into the pump area except for inspections.
Bob Newman
40176
johngoodman
PostPosted: Tue Feb 02, 2010 7:28 am    Post subject: Re: Fuel Filter Service - Access Panel Reply with quote
Phil
Phil, it is possible and I'm doing it. Take a look at this filter for $28.95 from Summit Racing. Very small and filters to 40 microns:
http://www.summitracing.com/parts/SUM-230101/
