rdmac(at)swbell.net Guest
Posted: Fri Feb 05, 2010 1:58 pm Post subject: Radio Noise |
I need some opinions from the List. I run a Rotax 912s in a model 7 and it has developed a noise in the radio every time I transmit. It would best be described as a crackling popping noise in the headset. It is connected some way with the engine sense it varies with the RPM of the engine and quits altogether when I shut the engine down. I was up flying the other day and after I landed I called the FBO and asked for a radio check and he said I was a little static’y but I was readable. Could I have a bad spark plug or plug wire? The engine seems to be running fine. Do I have a bad ground some where...opinions?
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
Float Flyr
Posted: Fri Feb 05, 2010 6:43 pm Post subject: Radio Noise |
Possible bad ground in the antenna system... but I doubt it because you would have very poor transmit strength and you didn’t mention that.
You can look for a bad ground on the shield that covers the mag P-Leads. That certainly would cause your problem... That shield should be well grounded at the base of the engine.
Finally look for a resistor plug that may have the resistor shorted. Or a plug cap that has arced inside. (It will be loose)
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Roger McConnell
Sent: February 5, 2010 6:26 PM
Subject: Radio Noise
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Guy Buchanan
Posted: Sat Feb 06, 2010 6:43 am Post subject: Radio Noise |
At 01:56 PM 2/5/2010, you wrote:
| Quote: | | I need some opinions from the List. I run a Rotax 912s in a model 7 and it has developed a noise in the radio every time I transmit. |
I have problems with the grounding of my antenna to the frame. A couple of times after getting the airframe washed the ground degraded and reception and transmission suffered. I simply cleaned up the connection, restoring the ground plane, and reception was great again.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Posted: Sun Feb 07, 2010 6:25 am Post subject: Radio Noise |
Guy and Noel,
Thanks for the advice. After old man winter eases up around here I will check these out. I really think it’s something to do with the ignition system or a bad ground on a P-lead.
DO NOT ARCHIVE
Paul A. Franz, P.E.
Posted: Mon Feb 08, 2010 4:49 am Post subject: Radio Noise |
On Sun, February 7, 2010 6:23 am, Roger McConnell wrote:
| Quote: | Guy and Noel,
check these out. I really think it's something to do with the ignition
That's a possibility, for sure. I'm certainly not a radio expert but from my reading
and personal experience, I'll put my money on a loose or corroded connection at one of
four places:
1) Radio power lead.
2) Radio ground wire.
3) Antenna ground connection to the ground plane.
4) Antenna cable connection especially at the end points of RG-58 coax.
Be sure to inspect crimped connectors for 1) and 2) carefully. Any corrosion at these
connectors introduces capacitance and can act as an amplifier to introduce ignition
noise into the power side of the radio.
My favored resource for help with this kind of problem is the Aeroelectric list. If
you are using the forum for this list (Kitfox), you can also read and post to the
Aeroelectric forum or any other Matronics forum.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
"We the People of the United States, in Order to form a more perfect
Union, establish Justice, insure domestic Tranquility, provide for
the common defence, promote the general Welfare, and secure the
Blessings of Liberty to ourselves and our Posterity, do ordain and
establish this Constitution for the United States of America. ...
Done ... the seventeenth day of September, in the year of our LORD
one thousand seven hundred and eighty seven."
-- George Washington and the Signers
"The Modern Liberal believes in the supremacy of the state, thereby
rejecting the principles of the Declaration and the order of the civil
society, in whole or part. For the Modern Liberal, the individual's
imperfection and personal pursuits impede the objective of a utopian
state. In this, Modern Liberalism promotes what French historian Alexis
de Tocqueville described as a soft tyranny, which becomes increasingly
more oppressive, potentially leading to a hard tyranny (some form of
totalitarianism). As the word 'liberal' is, in its classical meaning,
the opposite of authoritarian, it is more accurate, therefore, to
characterize the Modern Liberal as a Statist. ... The Statist ... knows
that despite his successful usurpations, enough citizens are still
skeptical and even distrustful of politicians and government that he
cannot force his will all at once. Thus he marches in incremental
steps, adjusting his pace as circumstances dictate. Today his pace is
more rapid, for resistance has slowed. ... The Conservative does not
despise government. He despises tyranny. This is precisely why the
Conservative reveres the Constitution and insists on adherence to it.
An 'effective' government that operates outside its constitutional
limitations is a dangerous government. ... The Conservative is alarmed
by the ascent of a soft tyranny.... He knows that liberty once lost is
rarely recovered. He knows of the decline and eventual failure of past
republics. And he knows that the best prescription for addressing
society's real and perceived ailments is not to further empower an
already enormous federal government beyond its constitutional limits,
but to return to the founding principles. A free people living in a
civil society, working in self-interested cooperation, and a government
operating within the limits of its authority promote more prosperity,
opportunity, and happiness for more people than any alternative.
Conservatism is the antidote to tyranny precisely because its
principles are the founding principles."
-- author and radio talk-show host Mark Levin in his book "Liberty and Tyranny"
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
dave
Posted: Mon Feb 08, 2010 5:37 am Post subject: Re: Radio Noise |
Roger I sent this on sunday but it bounced back form matronics mail server. looks like my ISP is blocked for mail
The original message was received at Sun, 7 Feb 2010 10:35:35 -0500
from node152.wl-a.pppoe.execulink.com [209.213.225.152]
----- The following addresses had permanent fatal errors -----
<kitfox>
(reason: 554 Service unavailable; Client host [smtp2.execulink.net] blocked using Barracuda Reputation; http://bbl.barracudacentral.com/q.cgi?ip=209.213.225.152)
Sent: Sunday, February 07, 2010 10:35 AM
Subject: Re: Kitfox-List: Radio Noise
Roger,
I common fault is using the chassis as a ground. Even though the chassic may be grounded to the ground bar or to the battery you can still have issues.
All grounds should be at one point . Don't ever consider the chassis ground to be perfect consistently.
Dave
no radio troubles here currently
----- Original Message -----
Sent: Sunday, February 07, 2010 9:23 AM
Subject: RE: Kitfox-List: Radio Noise
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
MDKitfox(at)AOL.COM Guest
Posted: Mon Feb 08, 2010 5:45 am Post subject: Radio Noise |
Paul,
Thank you for placing those two paragraphs at the end of your email. They caught my attention and I'm glad they did. I've heard of Mark Levin, but had no idea he was such a brilliant writer. I just may have to get his book!
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Feb 7, 2010, at 11:19 PM, Paul Franz - Merlin GT wrote:
| Quote: | --> Kitfox-List message posted by: "Paul Franz - Merlin GT" <paul(at)eucleides.com (paul(at)eucleides.com)>
four places:
Paul A. Franz
Bellevue WA
-- author and radio talk-show host Mark Levin in his book "Liberty and========================nbsp; - The Kitfox-List Email Fortronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitf========================p; ================================================nbsp; - List Contribution Web Site -http://www.matronics.com/contri=========================================
= [quote][b]
Float Flyr
Posted: Mon Feb 08, 2010 2:02 pm Post subject: Radio Noise |
Just to be sure... There should be a grounded shield on the P-Leads The only time the P-Leads themselves should be grounded is to shut off the mags. When the engine is in operation they should be adrift meaning they are actually like little transmitter antennas. It is important they be shielded.
Noel
Sent: February 7, 2010 10:53 AM
Subject: RE: Radio Noise
Guy and Noel,
DO NOT ARCHIVE
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List http://forums.matronics.com http://www.matronics.com/contribution | 0123456789 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 1 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 2 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 3 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 4 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 5 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 6 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 7
Kitfox III-A
Lynn Matteson
Posted: Mon Feb 08, 2010 3:12 pm Post subject: Radio Noise |
In the interest of opening a can of worms, Noel........shielding
grounded on one end or both? (ducking) : )
Lynn Matteson
Jabiru 2200, #2062, 849.1 hrs
Countdown to 1000 hrs~151 to go
Sensenich 62"x46" Wood (summer)
Sensenich 55.5" x 46" Wood (winter)
Rotec TBI-40 injection
Status: flying (and learning)
On Feb 8, 2010, at 4:58 PM, Noel Loveys wrote:
| Quote: | Just to be sure... There should be a grounded shield on the P-
Noel
Guy and Noel,
DO NOT ARCHIVE
forums.matronics.com http://www.matronics.com/contribution http://
www.matronics.com/Navigator?Kitfox-Listhttp://
forums.matronics.comhttp://www.matronics.com/contribution
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Mon Feb 08, 2010 4:42 pm Post subject: Radio Noise |
Wow, lots of food for thought, thanks fellows. I will for sure check my
radio power and ground connects and the RG-58 connection.
DO NOT ARCHIVE
Paul A. Franz, P.E.
Posted: Mon Feb 08, 2010 5:51 pm Post subject: Radio Noise |
On Mon, February 8, 2010 3:08 pm, Lynn Matteson wrote:
I've a lot of experience with RG-58 cabling with ethernet networks. The proper way is
a ground on one end and the last connection on the other should be a T with a 50 ohm
terminator. With ethernet, having the terminator on one or both ends seems sufficient,
i.e., no grounds at all. I believe you should ground only one end of the shielded coax
when used as an antenna lead. I don't know if a terminator should be used on the other
or not though.
Paul A. Franz
Bellevue WA
Per list moderators' directive my taglines will from here on out will be more limited
in scope and volume. Here's a couple though.
"The cause of America is in a great measure the cause of all mankind."
-- Thomas Paine, Common Sense, 1776
There is no such thing as society: there are individual men and women,
and there are families.
-- Margaret Thatcher
Bellevue WA
425.241.1618 Cell
Float Flyr
Posted: Mon Feb 08, 2010 6:24 pm Post subject: Radio Noise |
Shielding... grounded only to the end closest to the source.. If you ground
the shield at both ends what you have done is made an unbalanced conductor
like a piece of coax. As with coax there is a capacitance in the line when
it is grounded at both ends. This is why they say to only ground at one end
and that end usually has the best ground at the source end.
Years ago I was involved in a volunteer position at the local cable station.
We did several programs which were all recorded on 1/2" Beta video machines
and then edited down to the program length. Our editing suite had a problem
that after a video dub of five minutes we would get a glitch in our video.
The suite was in a room with a faraday screen that was connected to a close
to perfect ground ( a 4X8'piece of steel buried ten feet below the surface
of the ground... The steel had 20'radials attached to it) Sony was so
upset over this they actually sent technicians from Japan to check out our
installation. After a week of trying everything they could think of one of
the technicians attached an additional ground between the frame of the video
board and one of the audio boards and the glitch stopped. No one knows why
since both boards were properly grounded. The bond between the two boards
worked so well that future models of the Beta editing suite had the extra
ground included.
When it comes to electronics there are rules and just like everything else
there are exceptions that make the rules.
Noel
Kitfox III-A
Float Flyr
Posted: Mon Feb 08, 2010 7:02 pm Post subject: Radio Noise |
Antennae are a bit different they are unbalanced conductors where the
shielding carries up to half the power. Antennae should be grounded at both
ends. On a vertical antenna the shield should have a ground plane equal to
at least 1/4 the wave length being transmitted. The groundplane is located
at the base of the vertical radiator and 90 deg to it. On transmitting
coaxes generally the centre radiator is not in any way grounded... Note the
word "Generally". There are some antennas that may use a resistor between
the radiator and the shield.
Noel
Kitfox III-A
Paul A. Franz, P.E.
Posted: Mon Feb 08, 2010 7:54 pm Post subject: Radio Noise |
On Mon, February 8, 2010 7:02 pm, Noel Loveys wrote:
ends.
Noel, are you certain of that? I am looking at the installation guide for a Narco
VOR/COM given to me from the Paine Field Radio shop and it says to ground the Com coax
on one end only at the radio end of the shielding of the coax. I seem to recall
reading the same advice on the AeroElectric list. I'm not speaking from Engineering
knowledge just regurgitating so I definitely won't feel hurt if I'm corrected on this.
Paul A. Franz
Bellevue WA
"It is an object of vast magnitude that systems of education should
be adopted and pursued which may not only diffuse a knowledge of the
sciences but may implant in the minds of the American youth the
principles of virtue and of liberty and inspire them with just and
liberal ideas of government and with an inviolable attachment to
their own country."
-- Noah Webster, On Education of Youth in America, 1790
"Absolute power corrupts even when exercised for humane purposes. The
benevolent despot who sees himself as a shepherd of the people still
demands from others the submissiveness of sheep. The taint inherent in
absolute power is not its inhumanity but its anti-humanity."
-- American author Eric Hoffer (1902-1983)
"That [tyrannical government] power is absolute, minute, regular,
provident and mild. It would be like the authority of a parent if,
like that authority, its object was to prepare men for manhood; but
it seeks, on the contrary, to keep them in perpetual childhood: it
is well content that the people should rejoice, provided they think
of nothing but rejoicing. For their happiness such a government
willingly labors, but it chooses to be the sole agent and the only
arbiter of that happiness; it provides for their security, foresees
and supplies their necessities, facilitates their pleasures, manages
their principal concerns, directs their industry, regulates the
descent of property, and subdivides their inheritances: what
remains, but to spare them all the care of thinking and all the
trouble of living?"
-- French historian Alexis de Tocqueville (1805-1859)
Bellevue WA
425.241.1618 Cell
Lynn Matteson
Posted: Mon Feb 08, 2010 8:24 pm Post subject: Radio Noise |
This all boils down to my favorite thought:
If it don't work, try something else.
Lynn Matteson
On Feb 8, 2010, at 9:21 PM, Noel Loveys wrote:
everything else
Noel
N369LM |
Float Flyr
Posted: Tue Feb 09, 2010 6:34 am Post subject: Radio Noise |
Yes. Com transmitters on aircraft use a basic vertical design antenna.
They require a ground plane to direct the radio waves in a horizontal,
omni-directional direction. On metal aircraft the mounting lug for the
antenna has a place for the shield to be attached. At the transmitter end
it is grounded to the frame of the radio. On cloth planes there is usually
a steel support under the cloth for the mount to attach. Again the coax is
connected to the ground side of the mount.
On cloth planes it is recommended that a foil ground plane be installed on
the inside of the cloth. Many times operators who find they have poor range
on their com radios will have installations with no ground plane. When
attaching the ground plane to the inside of the cloth you really want to be
careful that the glue you use won't dissolve the dope on your cloth my
recommendation would be to install the ground plane when the fuselage is
being covered so it will be held in place with the dope.
Newer composite planes may have their antennae actually moulded into the
skins of the planes. For instance a jet liner may have the com antennae
moulded as a vertical dipole inside the leading edge of the vertical
stabilizer. In that case the ground plane may not be actually grounded but
the coax shield will be connected to a radiator equal in length to the
centre radiator. Gone are the days of the loop antennas and sense wires out
in the breeze where they slow down the plane and increase fuel consumption.
In all the vertical antenna types with the different feeds the one thing
that is consistent is the centre radiator of the coax must never be
grounded!
Jet liners may also have complex antenna for HF (high frequency) operation.
Smaller planes may have a wire which is extended out behind the plane for HF
operation. Designing ground planes for those antennae can be difficult.
Noel
Kitfox III-A
Float Flyr
Posted: Tue Feb 09, 2010 6:36 am Post subject: Radio Noise |
Right on!
Noel
Kitfox III-A
helili(at)chahtatushka.ne Guest
Posted: Tue Feb 09, 2010 7:00 am Post subject: Radio Noise |
DC ground, or RF ground???
John Hart
clint_bazzill(at)hotmail. Guest
Posted: Tue Feb 09, 2010 11:02 am Post subject: Radio Noise |
You have got to be joking.
Clint
[quote] From: noelloveys(at)yahoo.ca
Date: Mon C 8 Feb 2010 22:51:20 -0330
Float Flyr
Posted: Tue Feb 09, 2010 2:47 pm Post subject: Radio Noise |
I'm not too sure that I understand the question. The whole airframe should
be DC grounded in as much as it should be bonded to the negative lug on the
battery. All the cases of all the instruments should be grounded to this
and the it can also serve as the ground plane. Battery operated
transmitters that have vertical antennas need not have the ground planes
attached to the negative terminal of the battery other than through the
coaxial shielding.
The rubber duck antennae that a lot of hand held radios use are a separate
antenna on their own they use a coil to approximate a load to the radio
without having a ground plane however I have used the side of a trailer as a
signal reflector on a vhf radio to be able to transmit over a hundred miles
on 1/10th of a watt. The signal was strong enough to open a repeater site
and allow me to access an auto patch to make a phone call.
Noel
Kitfox III-A
