		partner14
				 Posted: Thu Feb 10, 2011 9:13 pm    Post subject: Exhaust Pipe Temps |
				Has anyone measured the temperature of the exhaust PIPES either as they exit the bottom cowl, or closer to the tips?  Not the egt, but the pipes themselves.
 Thanks, Don McDonald
40636 |
		martinaerodrome(at)gmail. Guest
				 Posted: Fri Feb 11, 2011 6:54 am    Post subject: Exhaust Pipe Temps |
				I had my exhaust pipes ceramic coated inside and out.  This resulted in a dramatic reduction in radiated heaat.
  Dick Martin
  RV8 N233M
  the fast one
  On Thu, Feb 10, 2011 at 11:13 PM, partner14 <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
  [quote]--> RV10-List message posted by: "partner14" <building_partner(at)yahoo.com (building_partner(at)yahoo.com)>
 Don A. McDonald
  40636
 http://forums.matronics.com/viewtopic.php?p=330555#330555
  ption,
  www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
  ronics.com/" target="_blank">http://forums.matronics.com
  Matt Dralle, List Admin.
		Kellym
				 Posted: Fri Feb 11, 2011 7:00 am    Post subject: Exhaust Pipe Temps |
				The downside to such coatings is that once coated they can never be weld
 repaired. Just one of the trade-offs we have to weigh and make our choices.
 On 2/11/2011 7:51 AM, Richard Martin wrote:
  	  | Quote: | 	 		   I had my exhaust pipes ceramic coated inside and out.  This resulted
  Dick Martin
  RV8 N233M
  the fast one
  <building_partner(at)yahoo.com <mailto:building_partner(at)yahoo.com>> wrote:
      Don A. McDonald
      40636
      ption,
KCHD |
		Lew Gallagher
				 Posted: Sat Feb 19, 2011 10:59 am    Post subject: Re: Exhaust Pipe Temps |
				Hey Don,
 I never saw a reply on your question re exhaust pipe temp, so today I aimed an infrared sensor at the exhaust pipes just as they clear the cowling.  250 F and it's 65 outside.  He had just landed and I took it as he stopped after taxi with the engine still running.  The numbers bounced around a bit (wind?) but 250 seemed about average.
 I'm curious what you'll do with this number?  If it's about protecting the fiberglass from heat, I've thought of using the same type of heat shield that is on motorcycle headers -- a strap clamp around the pipe that holds a metal shield off with an air gap in between.  But if the adhesive reflective tape works just as well, that may do the trick.
 Later, - Lew
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
